Characteristics of a good winch site
Old December 29th 07, 07:16 PM posted to rec.aviation.soaring
Chris Reed[_1_]
Default Characteristics of a good winch site
Lots of interest in another thread from US readers in looking for good
winch sites. I thought it might be useful for those of us from countries
where winching is common to give our list of essential and desirable
characteristics for a good winch site.
From my UK experience I'd say there are two essentials:
1. A long enough run to consistently achieve launches (nil wind) of 1500
ft or more. For 10 years I was a member of a club where on a nil wind
day one would do well to get 1300 ft. That's the difference between a
thermal-finding ratio of 80% and around 60%, which makes a huge
difference to soaring pilots. That suggests to me a cable run of around
4,000 ft.
2. Enough space so that gliders waiting to be launched can remain
gridded without being in the way of those landing. The club above has
only a narrow runway, so that gliders waiting to be launched need to be
pushed off every time someone comes in to land. This often made
launching frustrating. For safety this suggests a wide field, at least
at both ends.
A nearby flat land club has both these characteristics and is very
successfully winch only.
As desirables I'd add some hilly bits to help with thermal generation,
but these are not essential, and that grass is kinder to winch cables
(though waterlogging can reduce use of the field, so perhaps a hard
track to run the cable retrieve vehicle would be good) and is the only
surface on which retrieve winches seem to be workable.
Finally, if the site is next to a ridge I'm far more comfortable if the
field is at the foot of the ridge, rather than on top, because landing
back at the field should be possible if the ridge is unworkable.
Old December 30th 07, 12:44 AM posted to rec.aviation.soaring
Brad[_2_]
Great info Chris.
There is a place I have in mind not terribly far from where I live
that meets these requirements. The fields are in flood plain, so they
will never be developed, but that does make them soggy and underwater
occasionally......but this is only during the winter/rainy months and
then only 1 every 2 years or so. Of course, global warming might
chance things..........
There is a nice ridge line that runs N-S and at the N end it rises to
over 1300' and makes a bend to the east, so now there is a north and
and east face!
Cheers,
BradOn Dec 29, 11:16*am, Chris Reed
*From my UK experience I'd say there are two essentials:
4,000 ft.
at both ends.
Old December 30th 07, 01:25 AM posted to rec.aviation.soaring
vontresc
On Dec 29, 6:44 pm, Brad wrote:
Great info Chris.
and east face!
Cheers,
BradOn Dec 29, 11:16 am, Chris Reed
4,000 ft.
at both ends.
All of this winch talk is great, and I would really love to take a
winch ride again (took a demo flight in Germany many years ago). Has
anyone compiled a list of winch sited in the states?
Pete
Old December 30th 07, 02:49 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
We have a fairly accurate database of US winch sites at the Yahoo Winch
Design Group:
http://groups.yahoo.com/group/winchdesign/
Unfortunately, Yahoo won't let me make the database accessible to
non-members. Post you location and I'll post the relevant entries, or
join up if you like...
Marc
Old December 30th 07, 03:21 AM posted to rec.aviation.soaring
vontresc
Design Group:
Marc
Cool I'll have to join the Yahoo Group....
and for the record I am in WI
Pete
Old December 30th 07, 03:27 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Design Group:
Marc
This is likely your closest option:
http://www.sandhillsoaring.org/
Marc
Old December 30th 07, 02:58 PM posted to rec.aviation.soaring
Del C
Can I add:
1) On high, well drained land, with hard runways, to
give good thermals - e.g. Lasham.
2) Approximately circular, so you can always launch
into wind - e.g. Bicester.
3) A variety of local ridges facing in various directions
- e.g. Portmoak.
4) Slightly concave in contour, to minimise cable drag
and so you can see the launch point from the winch
- e.g. Long Mynd.
5) All grass airfield to minimise cable wear - Bicester
again
It's just a shame that you can't combine the best points
from the above UK gliding sites!
Del C
in looking for good
and desirable
(nil wind) of 1500
on a nil wind
between a
makes a huge
cable run of around
4,000 ft.
can remain
The club above has
launched need to be
often made
field, at least
at both ends.
and is very
thermal generation,
to winch cables
perhaps a hard
and is the only
comfortable if the
because landing
unworkable.
Old December 30th 07, 08:49 PM posted to rec.aviation.soaring
Malcolm Austin
But could all get in this act!
How about Denbigh GC, with its 20 mile ridge directly behind the site.
(pity the site will close in June 2008)
"Del C" wrote in message
Can I add:
- e.g. Portmoak.
- e.g. Long Mynd.
again
Del C
in looking for good
and desirable
(nil wind) of 1500
on a nil wind
between a
makes a huge
cable run of around
4,000 ft.
can remain
The club above has
launched need to be
often made
field, at least
at both ends.
and is very
thermal generation,
to winch cables
perhaps a hard
and is the only
comfortable if the
because landing
unworkable.
Old December 31st 07, 08:04 AM posted to rec.aviation.soaring
Check out some of the flying sites in Germany (http://www.segelflug.de/
karte/d_karte.html). Most of the winch sites are about 1000 meters
(appx 3000 feet). I have winched from 4 different sites 3 of which
also had areotowing going on at the same time, all were about 1000
meters. At these sites I was able to thermal away with a launch height
of between 300 and 400 meters (900-1200 feet).
You don't need an "airport" to do winch operations just any old grass
field will do. Needs to be wide enough but 100 feet would do it. How
many private grass airfields are there in the U.S. that fit this bill?
I'd bet it is a lot.
Bob
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
ASW 20 SPIN CHARACTERISTICS Ventus B Soaring 79 July 21st 04 07:46 AM
Laister LP-15 Nugget characteristics Randy Cone Soaring 0 January 29th 04 01:43 AM
F105 ACM Characteristics Dudley Henriques Military Aviation 4 September 15th 03 03:19 PM
