comparing russian and US jet engines OH times
Old December 14th 03, 05:51 PM
old hoodoo
Default comparing russian and US jet engines OH times
I just read where Russian Su-30 engines are intended to operate 300 hours
before major overhaul. How do US engines compare? 300 hours seems awfully
short to a layperson like me.
Al
Old December 14th 03, 05:52 PM
Tarver Engineering
"old hoodoo" wrote in message
awfully
I can only speak to our J-75s, but it was teardown inspection and repair
every 400 hours; depo overhaul each 1200 hours.
Old December 14th 03, 06:15 PM
Larry
The J-52's currently flown in the Navy's EA-6B Prowlers go 1,000 between
overhauls.
Interestingly, I understand that motor was intended as a "disposable" motor
designed originally for a missile program.
(¯`·._.· £ărrÿ ·._.·´¯)
awfully
Al
Old December 14th 03, 06:57 PM
Smartace11
The whole engine doesn't get overhauled, just modules. Each module, ie fan,
compressor, turnine, fan drive turbine, etc has a different interval, usually
based on cycles, ie temperature excursions from cold to hot.
Fighter engines typically stay installed for 300-600 hours on average and come
off for repair not overhaul.
The Soviets/Russians have always made disposable fighter engines from what I
know. Run'em hot, burn'em up, then salvage/overhaul them. Eliminates most of
the logistics tail and cuts way down on traing requirements. Gues you can do
that when you own the world's supply of titanium ore and most of your troops
are illiterate.
Old December 14th 03, 10:52 PM
Smartace11
Sukhoi, MiG and others have been pushing the engine companies to to improve
engine TBOs, so that western and western-oriented airforces will be more
willing to
buy them. Many of the joint venture commercial transports have been offered
with
western engines, for the same reason. They've still got a ways to go, as
ISTR the
F100 has a TBO of 4,000 hours now, and IIRC the most modern engines are
intended to
have only on-condition maintenance between overhauls, but I'll leave it to
others
with more knowledge and experience to confirm or deny that.
Guy
Sounds about right for the turbine. At 2.0 - 2.5 thermal cycles per operating
hour, 4000 hours is about 8,000 - 10,000 cycles. The compressor and fan run
quite a bit longer, hence the modular maintenance approach. When one module
reaches its limit it iw replaced, not the entire engine. There are also
intermediate inspections up until the end of the life cycle, but those are
mostly for inspection, not replacement except for certain parts like shrouds
and combustors.
Pretty much the same aproach to maintenance in high bypass fans in the heavies,
too though they accumulate thermal cycles more slowly, something around 1.0 or
less because of far fewer throttle transients.
Different approach for engines like the TF33 in the B-52 and C-141 because
those are not mudular engines. The entire engine has a TBO on them, but in
those application it is almost more of a fly to failure.
Old December 14th 03, 11:06 PM
Smartace11
) to smash their way to the objective (the Ruhr?
The Channel?) they win. Same reason the tanks were only designed for
short lives... who cares, they'll be destroyed before then anyway.
Now, with hindsight that plan worked a lot better in theory than in
practice... but it worked for them in the Great Patriotic War, and the
West was hoping to "be the Germans but win" in a Central Front rematch.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
That worked okay when the technology wasn't so expensive. Now stuff is so
expensive that it can't be used as cannon fodder.
I suspect the main problem with the Russian engines is that they have the
turbine inlet temp cranked up really high to produce thrust but haven't gotten
around to using advanced metals and ceramics on the blades and vanes in those
areas so they lose efficiency quickly. Reducing TIT would give more life to
the engines but less thrust.
Same issue with the J79 in the 60s and 70s. They smoked like crazy. The TIT
could be turned up but the life of the engines would be reduced significantly.
There was a combuster mod in the 80s that reduced the smoke a great deal.
One thing about flying a "smoker" was that you had far less of a chance of
being mistaken for a MiG. On the other hand you were also MiG bait but with
numerical superiority in the theaters the F-4 operated, the problem wasn't that
significant.
Old December 15th 03, 06:19 AM
The Enlightenment
(Smartace11) wrote in message ...
are illiterate.
The Russians have a different maintenance philosophy. All of their
maintenance is meant to be done in the field. There is no return to
the depo or factory style maintenance at all therefore their field
maintenace looks more frequent compared to western methods which are
infrequent but then have a huge overhaul back at depo or factory
level.
There is a big difference in philosophy and you aren't comparing
apples with apples but rather apples with oranges.
It probably would require some scoreboarding on a spreadsheet.
I can understand the Russian reasoning: the USAs military and
procuremewnt philosophy is based on the assumption that CONUS and its
depos and factories will not come under air attack, and the US
airfields overseas will also be free due to US air superiority. The
Russians don't have that luxury becuase they are or were withing close
distance of lots of hostile nations in Eruope, Near East and Far East.
They have thus have to develop more autonomy andf built to lower
levels of skills and field equipement.
The Russian literacy is probably much better than US literacy.
Russian Arms (in Nizhniy Tagil) Dmitrij Military Aviation 0 November 25th 03 09:50 AM
11 Nov 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 November 11th 03 11:58 PM
RUSSIAN WAR PLANES IN ASIA James Military Aviation 2 October 1st 03 11:25 PM
18 Sep 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 19th 03 03:47 AM
Russian NAVY detected foreign subs near Kamchatka Michael Petukhov Military Aviation 39 September 17th 03 08:25 PM
