Tricky examiners
Old January 3rd 08, 08:12 PM posted to rec.aviation.piloting
Dallas
Default Tricky examiners
I've been greatly amused by examiner trick stories lately, like Dudley's
story of an examiner bringing in his child to have the CFI candidate teach
him lift. Or the one where the examiner failed the flaps and asked the
student to find the ground frequency of the airport at the same time to see
the reaction.
What other favorite examiner tricks are out there?
Dallas
Old January 3rd 08, 08:47 PM posted to rec.aviation.piloting
Robert M. Gary
him lift. * Or the one where the examiner failed the flaps and asked the
the reaction.
Its pretty common to ask the student to do something in order to
distract them from making a mandatory call or pull the gear breaker.
-Robert
Old January 3rd 08, 09:06 PM posted to rec.aviation.piloting
Ross
the reaction.
-Robert
On my commerical checkride, right after completing the unusual attitudes
under the hood, I was given the engine out emergency immediately. I did
all the prep work and set up for an empty field below me. The examiner
asked what was wrong with the airport about 2 miles at my 4 o'clock
position. I made the airport.
Regards, Ross
C-172F 180HP
KSWI
Old January 3rd 08, 10:01 PM posted to rec.aviation.piloting
Al G[_1_]
see
the reaction.
-Robert
Correct, ask the student to do something noisy so he can't hear the CB
get pulled. A 15A breaker makes a noticeable Pop. in my case, it was "Let's
go do some clean stalls", which got the gear and stall horns going.
Al G
Old January 3rd 08, 10:13 PM posted to rec.aviation.piloting
Jim Stewart
the reaction.
Not really an examiner trick. I was on my final
lesson for my Practical signoff. We were heading
home and the instructor did the obligatory "your
engine just failed" drill.
I did the glide setup, simulated restart, secure
and radio call, estimated and set up a pattern
leaving me a little high and was feeling a little
proud of myself.
The instructor looked at the field and said "I
don't think you can make it".
I looked again, decided again that I might be a
little high, if anything and told him I was pretty
sure I could make it.
He said, "no, I don't think you can make it"
I said, "I'm sure I can make it"
He said, "you can't make it"
I said, "yes I can"
He said, "ok, do it."
I turned to final, made a nice approach and about
20' above the deck he ended the drill.
I said, "you knew I could make it" He said
yeah, but if you ever have a planeload of
people and the engine stops, they will be
yelling and crying that "you're not going to
make it, we're all going to die". I wanted
to see what you'd do.
Old January 3rd 08, 10:17 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
After finishing my preflight on my PPL ride, I had to go back inside to
get a hood. While I was inside, the examiner reattached the tail tiedown.
Fortunately, an embarrasing incident as a student had taught me do a quick
review of the exterior before climbing in and firing up. I caught it. He
told me that about half of his examinees didn't catch it.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200801/1
Old January 4th 08, 12:08 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
teach
to see
the reaction.
proud of myself.
I said, "yes I can"
What is it the guy said?
"When I die I hope I go out peacefully like my father did, just passing
on silently in my sleep, not screaming and kicking like the passengers
in his car."
Dudley Henriques
Old January 4th 08, 12:56 AM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
Obviously he's never had to do it. I have, and trust me, they won't make a
sound.
mschnerdatcarolina.rr.com
Old January 4th 08, 01:27 AM posted to rec.aviation.piloting
Ron Natalie
Bear breaker? Har!
Old January 4th 08, 02:01 AM posted to rec.aviation.piloting
BT
You get yourself too high.. and you will not make it.. you'll dive with too
much speed.. and float in ground effect off the other end of a very short
runway.. seen it happen.
BT
How many US Glider Examiners-Answer Terry Soaring 0 April 15th 05 05:13 PM
How many Glider Examiners in the US? Terry Soaring 1 April 1st 05 07:09 AM
inspection of FAA examiners, ahhhhhh, long Mark James Boyd Soaring 1 March 1st 05 08:07 AM
Sport Pilot examiners Cub Driver Piloting 0 February 16th 05 10:43 AM
Is there a FAA Manual for Heli flight examiners? gps required? Eric D Rotorcraft 1 October 21st 03 04:38 PM
