Ham radio in aircraft
Old January 9th 08, 09:15 PM posted to rec.aviation.owning
Jay Maynard
Default Ham radio in aircraft
As my .signature attests, I'm also a ham radio operator. I'd like to be able
to use a 2 meter/440 MHz dual-band radio in the aircraft. While, ideally,
that radio would be an Icom IC-2820H, like the one in my car, practically
speaking it'll be a handheld. An external antenna would seem to be a useful
thing, with the cable brought forward to some convenient spot so I can hook
the radio up to it.
What are other hams doing in their aircraft?
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
http://www.hercules-390.org (Yes, that's me!)
Buy Hercules stuff at http://www.cafepress.com/hercules-390
Old January 9th 08, 09:46 PM posted to rec.aviation.owning
RST Engineering
It all depends on
a) if it is your aircraft and you can hang things permanently where you
want
and
b) how technically inclined you are.
WX6RST
Old January 9th 08, 11:03 PM posted to rec.aviation.owning
Jay Maynard
On 2008-01-09, RST Engineering wrote:
It all depends on a) if it is your aircraft and you can hang things
permanently where you want
Yes. I'm going to be buying an LSA some time this year.
and b) how technically inclined you are.
The ham radio part of this doesn't hold any mystery to me at all: I've been
a ham for 35 years, and do my own installation of stuff in cars and the
like. What I don't know is what's possible, good, or legal in an aircraft.
Old January 9th 08, 11:50 PM posted to rec.aviation.owning
Vaughn Simon
"Jay Maynard" wrote in message
I don't believe that there are any laws against operating a ham radio in an
aircraft. Permanent installations are a whole 'nother kettle of fish, but that
is not what you seem to have in mind.
I have also been a ham for over 40 years. My feeling has always been that I
can do all of the hamming on the ground that I want, but my time aloft is too
precious (and potentially dangerous) to do anything else but aviate. I have
never had any interest in mixing ham radio and aviation but YMMV.
Vaughn WB4UHB
Old January 10th 08, 12:02 AM posted to rec.aviation.owning
Jim Stewart
the radio up to it.
I'm going to be trying APRS in my plane,
but that's at least a couple months off.
Old January 10th 08, 01:07 AM posted to rec.aviation.owning
NW_Pilot
I put a Icom 706MKIIG With SGC 239 Tuner in aircraft all the time...
able
useful
hook
the radio up to it.
Old January 10th 08, 01:16 AM posted to rec.aviation.owning
NW_Pilot
Some Photos of a Temp 172 Temp Antenna Install... Use Quality Wire When
Making an Antenna.
http://www.aircraftdelivery.net/me/HF1ANT.JPG
http://www.aircraftdelivery.net/me/HF2ANT.JPG
http://www.aircraftdelivery.net/me/HF3ANT.JPG
http://www.aircraftdelivery.net/me/HF4ANT.JPG
able
useful
hook
the radio up to it.
Old January 10th 08, 01:43 AM posted to rec.aviation.owning
Doug Vetter
On Wed, 09 Jan 2008 16:02:32 -0800, Jim Stewart wrote:
I'm going to be trying APRS in my plane, but that's at least a couple
months off.
Funny you should mention that, as I'm building an APRS tracker for
airborne use right now. Hope to have it online in a couple weeks. Will
be totally self contained, and based on an old Kenwood KT-78A HT, a N1VG
OpenTracker, Garmin 18 GPS, Maldol AX75 1/2 wave 2M vertical and an AGM
battery. Should be fun to plot the data using Google Earth.
-Doug (N2WOL)
Doug Vetter, ATP/CFI
http://www.dvatp.com
Old January 10th 08, 02:25 AM posted to rec.aviation.owning
First you have to get permission from the pilot/owner/operator; that part
should be easy....
Basically, anything permanently installed needs to be done, or at least
"supervised", and signed off by someone with the appropriate FAA holy
papers.
To keep it simple, don't permanently mount the radio and power it from
the cigarette lighter plug.
Install a second COM antenna, which will work good enoungh for 2M even
without filing off a little on the end when no one is looking, with a
cable run to a convenient place, which could also double as the antenna
for an air band hand held back up. This is the part that needs the FAA
paper.
Or, build the A/C yourself and do anything you want.
Jim Pennino
Remove .spam.sux to reply.
Old January 10th 08, 02:48 AM posted to rec.aviation.owning
David Lesher
Years ago I helped put a Drake 2mtr rig in a friend's 172. He had another
stainless rod antenna in place and I trimmed it to 146 Mhz.
Big issue was the Drake lacked sidetone so it was hard to know how you
were sounding over the engine noise.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
VHF Aircraft band 2-way radio yooper Soaring 0 July 22nd 05 07:15 PM
FA: Pre-WWII Aircraft Radio Equipment. David Stinson Military Aviation 0 July 1st 04 07:20 PM
FA: Pre-WWII Aircraft Radio Equipment. David Stinson Restoration 0 July 1st 04 07:18 PM
AirCraft Radio Communications [email protected] Rotorcraft 0 November 13th 03 12:48 AM
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO Ron Restoration 0 October 26th 03 12:02 AM
