Comm Checkride Today
Old January 12th 08, 06:17 PM posted to rec.aviation.piloting
Judah
Default Comm Checkride Today
Congratulations!
I wonder if Checkride Jitters didn't play a part.
I wonder if the DE didn't wonder it also..
" wrote in news:686c926e-f399-4da4-
Today I earned my commercial pilot's license -- whew!
Old January 12th 08, 10:52 PM posted to rec.aviation.piloting
The morning started out less than ideal with low ceilings throughout
the area. But the TAFS suggested clearing, as did the satellite image.
The FAs were way off (again).
I called Don and said I'd be at EKN by noon. After preflighting and
adding 20 gallons of 100LL, I started up and headed south VFR.
I haven't flown much VFR lately so I had to think back on the correct
verbiage for Traffic Advisories. It came to me and I flew south past
MGW and the CKB.
I had to head west to avoid the ceilings low over the ridges to the
east. When I got near Route 33, I headed southeast towards the gap in
the mountains. They looked awfully close but a glance at the Terrain
view in the GPS said I'd be clear.
It was clearing inside the valley, and winds were calm. The flight
down was bumpy -- it felt like summer morning, with constant altitude
variations and bumps. I felt like I couldn't maintain altitude within
100' to save my life.
The landing was OK -- I flared a bit high. A touch of power fixed that
and then a gentle chirp. I'm not used to 150' wide runway.
I arrived prior to the examiner, so I laid everything out -- 8710,
check, logbooks, etc. Everything was in order and after about 15
minutes of paperwork we started the oral.
He focused on the POH but I've spent alot of time reading it so there
wasn't much I didn't know -- in fact, there was no question I couldn't
answer (down to the nose wheel tire pressure).
Then it was time to fly. I did another pre-flight and pointed out some
of the airplane details (vortex generators, etc).
We climbed in and I did my usual checklist, including PAX brief. We
taxied to 32 and did a soft field takeoff from there. There is no soft
field technique described in the POH, so all you do is keep rolling,
keep the yoke back, let it get light on the mains, pull up, and you're
off. An A36 doesn't need much time in ground effect as it has plenty
of power to accelerate.
We headed south down the valley, climbed to 4500, and started off with
steep turns. The turn to the left was fine, the one to the right he
covered to panel and I lost 500' foot in altitude. Ugh.
Next up chandelles. Both went well with the stall horn going off with
about 20 degrees remaining to turn. He mentioned that I was adjusting
pitch too much -- should set it and leave it to the 90 degree point,
then hold it. I think I was chasing the airspeed a bit too much.
Next were Lazy 8s. The first was OK, though I dropped the nose too
much and picked up too much airspeed. I had a habit of not letting the
nose drop enough during practice and so over compensated today. The
second iteration was better.
Next was a steep spiral, which went fine. He had me pull out after 2
1/2 turns and head over towards solos for 8s on pylons.
The first was a bit shaky, as we came really close to a ridge on one
side of the circuit, but after settling down they were fine. I was
able to keep the pylon on the reference point fairly consistently,
though the tip tanks make it a bit of a challenge.
On to the airport for a short field landing. I kept the pattern tight
and was on airspeed of 71 KIAS and about to flare when he said to go
around. The go around was a handful with 285 HP and full nose up trim.
I was able to keep the nose down, raise the flaps, and then the gear,
and accelerate to Vy.
He said "Do you always fly your patterns this tight?"
I said, "I've learned from my instructor that I need to be able to
land power off from anywhere in the pattern. To many Bonanza drivers
fly 3 mile wide downwinds -- you relaly don't need to."
Next was a No flap landing. When I checked the gear down indication
the green lights were not burning as expected. I glanced over and saw
the CB popped. I said I would abort the landing, climb, and get the
gear down manually. He said not to bother and reset the CB and I
landed no flap (I added 10 knots to handle the higher stall speed,
which gave me about 86-90 KIAS on base to final).
The landing was pretty poor with a drop in stall about 3 feet off the
runway -- ugh. I told him I hadn't had a landing like that in 50
hours.
We did a short field takeoff and then another landing, this one
better. On the takeoff I established VY and we were climbing and he
said "What about the gear?" I reached over and put the gear up and
said, "I need to pretend you're not here."
After a couple of more pattern landings with the winds variable up to
5 knots, so we had x-wind landings and takeoffs. Then we landed and he
said he'd seen enough. I can usually land with the gentlest of chirps
in that airplane, but for some reason today not one was a greaser. Go
figure.
We parked and went inside and he filled out my temporary certificate,
which is nestled snugly in my logbook pocket.
I really don't feel like I "had it" today -- I felt like I was off. I
have flown much more crisply and much more proficiently than I did
today. But I figure that if I can pass a commercial test on an off
day, then I must be reasonably prepared.
I am relieved and satisfied, though I wish I could have demonstrated
greater level of proficiency. Oh well.
On to the CFI!
Dan
Old January 13th 08, 12:03 AM posted to rec.aviation.piloting
MGW and the CKB.
of the *airplane details (vortex generators, etc).
hours.
figure.
On to the CFI!
Dan
Congrats to you.. Another milestone in your flying career.
Be safe out there.
Ben
www.haaspowerair.com
Old January 13th 08, 12:13 AM posted to rec.aviation.piloting
On Jan 12, 1:17 pm, Judah wrote:
Congratulations!
Thanks!
I'm sure it did...and apparently he must have figured the same!
Old January 13th 08, 12:15 AM posted to rec.aviation.piloting
B A R R Y
On Sat, 12 Jan 2008 14:52:38 -0800 (PST), "
High five!
I plan to do the same this spring, so I appreciated the post.
Old January 13th 08, 12:58 AM posted to rec.aviation.piloting
I'm happy to hear that... I felt prepared based on good instruction,
study (Gliem Commercial Flight Maneuvers and King Checkride test Prep
DVD rented through Avnac), and listening/reading other's checkride
stories.
Sweat the preparation and the test is much easier.
Dan
Old January 13th 08, 01:08 AM posted to rec.aviation.piloting
Blueskies
wrote in message ...
Sounds like a fun day! I'm sure you will look back and appreciate it...
Dan (also)
Old January 13th 08, 01:37 AM posted to rec.aviation.piloting
Robert M. Gary
Good job. For many people the biggest advantage of getting the
commerical is to relearn how to fly VFR.
-Robert, CFII
PASSED IFR checkride today. STICKMONKE Instrument Flight Rules 8 November 25th 05 07:02 PM
Comm in a bag? Richard Lamb Home Built 11 March 7th 04 01:15 AM
Pass my Instrument Checkride Today! Judah Instrument Flight Rules 12 February 19th 04 05:13 PM
Passed my IFR checkride today. [email protected] Instrument Flight Rules 5 February 8th 04 07:04 AM
Checkride Today Z Sten Piloting 9 October 30th 03 02:01 AM
