Air Travel Tip - How To Avoid And Deal With Airsickness
Old January 13th 08, 09:14 AM posted to rec.aviation.piloting
88059355
Default Air Travel Tip - How To Avoid And Deal With Airsickness
Air travel has come a long way since the Wright brother's first flight
in 1903. Planes are now works of technological and engineering genius,
screaming across the sky at 600 miles an hour while the passengers
inside enjoy in-flight movies and complimentary beverage service.
However, as advanced as air travel has become, there will always be
one thing that plagues some air travelers regardless of the in-flight
accommodations they have. That one thing is air travel sickness.
Airsickness, as it's frequently called, is a form of motion sickness
travelers experience when they fly. Motion/air travel sickness is
caused when your central nervous system receives conflicting messages
from your eyes, inner ear, and muscles. Because of high altitudes,
pressure differences, and turbulence experienced when flying, your
central nervous system can receive varying messages based on how each
part of your body is reacting to your surroundings and the altitude.
As a result, your equilibrium can be thrown off and lead to slight
nausea and dizziness, the two most common symptoms of air travel
sickness.
However, this imbalance doesn't always lead to airsickness. In fact,
most people don't experience any sort of nausea or dizziness when they
fly. But that's not to say they never will. That's why it's important
to know how to avoid and deal with airsickness.
How to Avoid Airsickness
Although it's not always feasible to avoid airsickness completely, it
is possible to lessen the likelihood of it. For starters, it's always
better to travel when you're in peak health. Colds and other ailments
can leave you vulnerable to slight changes in altitude and
temperature, making you more susceptible to air travel sickness.
Stress can also make you more vulnerable to airsickness. When you're
stressed, your body is not at peak performance, and flying can take a
lot out of you. So if you want to avoid the airsickness bag as best
you can, try to lower your stress levels before you fly.
Eating a large meal before you fly can also lead to air travel
sickness. The more food you eat, the more energy it takes for your
body to process it, slightly lowering your body's natural ability to
adjust to higher altitudes (it's too busy digesting that triple
cheeseburger you ate before takeoff). So, eat a light meal before you
fly. You should definitely eat something before you fly; just make
sure you eat in moderation.
How to Deal with Airsickness
For some people, there's no way to avoid airsickness. They're just
prone to motion sickness of any kind and can't avoid the nausea and
dizziness. However, that doesn't mean there's no hope for these
individuals. There are a few ways to deal with airsickness if you know
you're more susceptible to it.
Unfortunately, once you come down with airsickness, there's no real
solution to alleviating its symptoms. That's why you need to plan
ahead and attack airsickness before it attacks you. Here are some
simple solutions to dealing with air travel sickness:
- Don't read if you are prone to airsickness. The strain on your eyes
will only add to the imbalance caused by motion sickness.
- If you're a frequent victim of air travel sickness, take medication.
If you don't want to take medication, there are non-medicated
solutions available (such as motion sickness bands). In either case,
ask your local pharmacist or physician which medication/solution is
best for you.
- Keep yourself hydrated by drinking lots of water. Your body needs
water to maintain its bodily functions. If you're dehydrated, your
body won't function at peak performance.
Air travel sickness is one of the few downfalls of flying. It can
easily turn a simple flight into an excruciating experience. However,
there are simple ways to combat airsickness before it affects you. If
you're flying soon, plan ahead and heed the preceding advice on how to
avoid and deal with airsickness. It could drastically improve your
flying experience.
http://cncarrental.cn/html/art/20061002/47973.html
Old January 13th 08, 04:33 PM posted to rec.aviation.piloting
Tina
Default Re How To Avoid And Deal With Airsickness, and a different suggestion
One does not often die from airsickness, but people do from deep vein
thrombosis -- those nasty clots that form in your legs, then break
free.
It's our practice to take a couple of baby aspirin before we take off
on long flights, figuring a little anticoagulation action may make an
unlikely event even less likely. As far as I know, there are not
studies that directly prove this is helpful, but it makes sense to us.
Like all implied suggestions on the 'net, this one is worth exactly
what you paid for it.
sickness.
best for you.
flying experience.
Old January 13th 08, 06:47 PM posted to rec.aviation.piloting
Tina
Default Re How To Avoid And Deal With Airsickness, and a differentsuggestion
More deaths from DVT, Bertie, than from you guys flying into
mountains: we call it risk/benefit analysis in clinical trials..
I had a funny image -- Anthony, getting ready for a long simulated
flight by eating a couple of placebo aspirin.
I know that was really unkind, and here it is, Sunday, when we should
be especially charitable. I should not have posted it until tomorrow.
On Jan 13, 12:18*pm, Bertie the Bunyip wrote:
Tina wrote in news:c4734f94-ac8d-4506-975b-
free.
Might make you bleed to death more quickly if you crash, too.
Win-win.
Bertie
Old January 14th 08, 03:20 AM posted to rec.aviation.piloting
Dallas
A guilty pleasure I'm sure.. :- )
Dallas
See & Avoid Ol Shy & Bashful Piloting 27 August 2nd 07 01:27 PM
See and avoid... Ramy Soaring 22 January 30th 07 09:18 PM
Airsickness Jim Kelly Soaring 25 January 17th 05 02:52 AM
See and Avoid applies to both IFR and VFR Brad Z Piloting 14 July 17th 04 05:48 AM
See and avoid Kees Mies Piloting 39 March 22nd 04 08:31 PM
