Do 301's have water ballast as an option?
Thanks Al |
On Jan 14, 2:50*am, "
wrote: Do 301's have water ballast as an option? Thanks Al No, but some in the US have added water ballast to ships licenced in the experimental category. The Feds won't let you go over the 660 GW in standard category. JJ |
On Jan 14, 6:37*am, JJ Sinclair wrote:
On Jan 14, 2:50*am, " wrote: Do 301's have water ballast as an option? Thanks Al No, but some in the US have added water ballast to ships licenced in the experimental category. The Feds won't let you go over the 660 GW in standard category. JJ Thanks JJ. What ever happened to your 301 from doug and the full canopy franken libelle? Regards Al |
On Jan 14, 11:29*pm, "
wrote: On Jan 14, 6:37*am, JJ Sinclair wrote: On Jan 14, 2:50*am, " wrote: Do 301's have water ballast as an option? Thanks Al No, but some in the US have added water ballast to ships licenced in the experimental category. The Feds won't let you go over the 660 GW in standard category. JJ Thanks JJ. What ever happened to your 301 from doug and the full canopy franken libelle? Regards Al I gave it a good annual last year, it was in good shape except for blisters because the owner didn't open the trailer for a year. He said it was up for sale at 12ish, last I saw it was at Williams Soaring. You'd fit in the franken' cockpit real well, Al and your young enough to get in and out without shoulder pain. I had a cherry 301 that I flew in the Reese nats, but my shoulder hurt for 6 months afterwards. It's down at Tehachapi. The unmodified 301 is a good machine for sports class, climbs like stink, doesn't run all that well above 70 knots. Bet it could win in weak conditions. The Schuemanized Libelle goes well, but they knock off 5% on the handicap and I don't believe its all that good. Cheers, JJ |
| Thread Tools | |
| Display Modes | |
| Who first used water ballast and when? | John McCullagh | Soaring | 9 | October 18th 06 10:36 AM |
| Water Ballast Upgrade | P.Corbett | Soaring | 5 | December 5th 05 03:32 PM |
| water ballast leak | Robert Harvey | Soaring | 2 | May 27th 05 04:49 PM |
| water ballast leak | Robert Harvey | Soaring | 0 | May 26th 05 11:33 PM |
| Std 102 water ballast plug | Tom Dukerich | Soaring | 3 | April 12th 05 06:10 PM |
