Twist-on BNC connectors
Old January 14th 08, 11:53 PM posted to rec.aviation.owning
Jim Stewart
Default Twist-on BNC connectors
Are they acceptable for avionics use?
Old January 15th 08, 01:03 AM posted to rec.aviation.owning
dave
TNC connectors are fine.
The military uses them all the time.
Dave
John Smith wrote:
I wouldn't recommend them.
Maybe as a temporary emergency repair, but not for something you want to
depend on.
Old January 15th 08, 01:14 AM posted to rec.aviation.owning
Jim Stewart
No, I was referring to solderless BNC connectors
that twist onto the stripped coax.
Dave
to depend on.
Old January 15th 08, 01:57 AM posted to rec.aviation.owning
dave
Sorry, i misread the post. my Misteak.
John was 100% correct.
Dave
to depend on.
Old January 15th 08, 03:46 AM posted to rec.aviation.owning
Jay Maynard
They're not acceptable for any use, IMAO. I've never seen one that was
connected well enough to hold together for five minutes or work well enough
to get signal through. I've had too many bad experiences with them to ever
use one.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
http://www.hercules-390.org (Yes, that's me!)
Buy Hercules stuff at http://www.cafepress.com/hercules-390
Old January 16th 08, 05:33 AM posted to rec.aviation.owning
Dave[_5_]
I wouldn't use them for anything - let alone on an airplane.
My advice would be to get some RG-142 coax cable and the correct
connectors for it. Then invest in (or borrow) the correct crimpers,
and learn how to properly install the connectors. Then do the job in
your plane. You won't be sorry - the RF cables in my plane have been
working fine since about 1979.
David Johnson
Old January 16th 08, 08:53 PM posted to rec.aviation.owning
Jim Stewart
I'm going to do just that. I need a
dozen assorted jumpers for the lab anyway.
Thanks to all.
Old January 17th 08, 11:56 PM posted to rec.aviation.owning
Those connectors can be best described by this highly technical term:
utter ****e.
I have a handful of them that I once threw into my trash can. My trash
can threw them back at me.
Old January 19th 08, 03:42 PM posted to rec.aviation.owning
Robert M. Gary
depend on.
I always thought that the half turn connectors that are the standard
in avionics were called BNC. If not, what are they called?
-Robert
Old January 19th 08, 03:52 PM posted to rec.aviation.owning
On Sat, 19 Jan 2008 07:42:02 -0800 (PST), "Robert M. Gary"
depend on.
They are; the discussion is related to how the connectors are attached to the
cables themselves. The reference to "Twist-on" refers to connectors that are
merely jammed onto the cable by hand and are expected to keep electrical contact
by friction alone. Folks are recommending avoidance of these in favor of those
that attach using tools specifically designed for the task.
Me, I just go to the local computer store and buy some of the pre-made RG-58
cables with BNC connectors already attached.....
LLC ownership of airplane -- another twist xyzzy Owning 10 June 16th 07 04:34 PM
SR-22 Crash, with a twist john smith Piloting 47 March 20th 07 11:49 PM
Battery Connectors Paul Remde Soaring 9 April 9th 06 06:39 PM
A new twist on complaints Roger Piloting 37 November 11th 05 08:50 AM
Solid joystick (X-45 or HOTAS quality) with a *twist*? Zenin Simulators 3 January 26th 04 06:30 AM
