Garmin 430W autopilot operation
Old January 15th 08, 05:34 PM posted to rec.aviation.ifr
Glasair470
Default Garmin 430W autopilot operation
We have upgraded the Garmin 430 to WAAS in our homebuilt. We have the
Garmin talking to our STEC autopilot using its ARINC 429 roll steering
commands through the STEC GPSS interface. In the old 430 non-WAAS
unit, even if you selected an ILS approach on the Garmin and loaded
it, you would get roll steering commands down to the ground out of the
Garmin. Of course, you are using the VLOC receiver and the ground
stations for the approach but the autopilot would still fly the
magenta line on the screen that was provided "for guidance". I now
notice on the WAAS'd unit we got back that the roll steering commands
only seem to be provided until we get to the ILS final approach fix,
and then the STEC starts flashing to indicate that there is no more
roll steering. It drops out at the FAF.
We have to revert to HEADING mode if we still want to use the
autopilot on the approach or maybe NAV mode and track the localizer
needle, although I cut those wires figuring that roll steering is so
good I would never again want to track needles.
If we are flying a GPS or an RNAV approach on the 430W it does give
the roll steering signals all the way down to the ground or out to the
holding fix on the missed approach and will even fly the holding
pattern.
Anyone else can confirm this? I called Garmin technical support and
the guy really couldn't get what I was talking about. He was under
the impression that we should not be getting ANY roll steering on an
ILS approach but that was not the case with the 430 and semi-not the
case with the 430W.
Is this a deliberate feature programmed into the software to insure
that you are not flying the "guidance only" course line on an ILS
approach?
Old January 16th 08, 04:32 AM posted to rec.aviation.ifr
Harvey Spencer
Thanks to you guys for confirming my understanding of the problem. I only
flew 2 ILS approaches since I had the unit WAAS'd but
was familiar enough with the operation of the 430 before it got WAAS'd and
realized that at the FAF roll steering goes away with the
430W. I don't have GS coupling on my STEC so I have never had to worry
about that problem. It is incredible that with roll steering you
have to resort to the analog "fly the needles" with the autopilot.
Concerning the STC implications of the hookup of my Garmin to the autopilot
I chose to NOT hook it up according to the STC for the
430W, so GPSS is NOT disabled when the CDI is switched to VLOC. It is
because my autopilot flies like a pro with roll steering but
in NAV mode and following the needle, it S-turns like a drunken sailor.
To have GPSS roll steering active all the time, it just involves not hooking
up the inhibit wire on the autopilot
to the VLOC active line from the Garmin. If you hook up that line, then
when you switch the Garmin to VLOC it grounds that inhibit line which tells
the autopilot to forget about using roll steering.
I know that in my plane, roll steering is always following the magenta line,
because that is how I hooked it up. Pretty easy to remember. There are
actually very few times when my flight plan does not match where
I am going using the VLOC, so the magenta line is for all intents and
purposes the same as the VLOC radial or the LOC.
"Glasair470" wrote in message
pattern.
case with the 430W.
approach?
Old January 16th 08, 08:43 AM posted to rec.aviation.ifr
Thomas Borchert
Harvey,
Not many of us have that option. You're flying an experimental.
It is
Not many of us have that problem. You're flying an experimental.
gd&r
What I'm trying to say is: If the S-TEC installation is properly done in
an aircraft it is designed for, it will follow the localizer in approach
mode just fine - and it'll be the legal way to fly that approach.
Thomas Borchert (EDDH)
Old January 16th 08, 06:38 PM posted to rec.aviation.ifr
Glasair470
I agree that it would be nice for the STEC in my Glasair to do a
better job of flying the analog needle output. I have worked on the
sensitivity tailoring by hanging internal resistors under the
direction of the technical service personnel at STEC and can only get
it a little better than when I started. Also, tinkered with the roll
centering that is a user adjustment (hidden under a panel screw) to
try and null that out as best as possible. The Glasair just has too
much roll sensitivity to do a very good job with this particular
autopilot in NAV mode, but in roll steering mode where, yes, it is
"faked" into thinking it is in an everchanging HDG mode, it works
great.
I also agree with the poster that you can drive the autopilot any way
you want when doing an approach using terrestrial nav aids and as long
as you are watching the appropriate needles it is legal. One way is
to just put it in HDG mode and keep tweaking the heading bug. I guess
that is a "brain-driven" coupled approach. It doesn't matter where
the autopilot gets its intellengence from as long as the aircraft is
flying on the right path.
Old January 17th 08, 12:37 PM posted to rec.aviation.ifr
Ron Natalie
The STEC GPSS (at least my 55x) do not work with vnav.
When you're converging on the final course you need to
go into regular NAV+APR+ALT mode.
430W doubling in cost? bdl Owning 19 August 18th 07 11:11 PM
Garmin 430W holding help? Paul kgyy Piloting 1 April 10th 07 11:36 PM
XM Wx Garmin 430/430W with Garmin GDL-69? [email protected] Instrument Flight Rules 4 March 5th 07 03:52 AM
Garmin 430W/530W first impressions Viperdoc[_4_] Instrument Flight Rules 9 February 27th 07 02:10 AM
GNS 430W vs GNS 480 Ron Gordon Instrument Flight Rules 66 January 4th 07 06:45 PM
