Can a float plane land on a body of water inside a city, more
specifically, could one land he http://maps.google.com/?ie=UTF8&ll=3...&t=h&z=16&om=0 Note: the body of water is privately owned and in case you were wondering, that is the building in which I work. The land on the NW end of the lake is covered with bushes that are only 3-4 feet tall. |
es330td wrote:
Can a float plane land on a body of water inside a city, more specifically, could one land he http://maps.google.com/?ie=UTF8&ll=3...&t=h&z=16&om=0 Note: the body of water is privately owned and in case you were wondering, that is the building in which I work. The land on the NW end of the lake is covered with bushes that are only 3-4 feet tall. As far as the FAA is concerned yes. Local, county or state laws may not allow it though. |
Gig 601XL Builder wrote:
es330td wrote: Can a float plane land on a body of water inside a city, more specifically, could one land he http://maps.google.com/?ie=UTF8&ll=3...&t=h&z=16&om=0 Note: the body of water is privately owned and in case you were wondering, that is the building in which I work. The land on the NW end of the lake is covered with bushes that are only 3-4 feet tall. As far as the FAA is concerned yes. Local, county or state laws may not allow it though. And I am guessing that you don't own the building in which you work. If thats the case I think your employer might take a dim view of this. Or more correctly, your employers insurance carrier might take a very dim view of this. -- Frank Stutzman Bonanza N494B "Hula Girl" Boise, ID |
On Jan 31, 10:34*am, Frank Stutzman
wrote: Gig 601XL Builder wrote: And I am guessing that you don't own the building in which you work. If thats the case I think your employer might take a dim view of this. Or more correctly, your employers insurance carrier might take a very dim view of this. You are correct; I don't own the building though the building owner does own the land (and body of water.) I figured I probably couldn't land there, but if there was any possibility I could fly to work I should at least find out. |
On Jan 31, 12:20 pm, es330td wrote:
On Jan 31, 10:34 am, Frank Stutzman wrote: Gig 601XL Builder wrote: And I am guessing that you don't own the building in which you work. If thats the case I think your employer might take a dim view of this. Or more correctly, your employers insurance carrier might take a very dim view of this. You are correct; I don't own the building though the building owner does own the land (and body of water.) I figured I probably couldn't land there, but if there was any possibility I could fly to work I should at least find out. that pond looks awfully small. Looks like less than 1000 feet long and curved. You'd need to be a pretty skilled floatplane pilot to land and takeoff there. |
On Jan 31, 12:59*pm, xyzzy wrote:
On Jan 31, 12:20 pm, es330td wrote: On Jan 31, 10:34 am, Frank Stutzman wrote: Gig 601XL Builder wrote: And I am guessing that you don't own the building in which you work. If thats the case I think your employer might take a dim view of this. Or more correctly, your employers insurance carrier might take a very dim view of this. You are correct; I don't own the building though the building owner does own the land (and body of water.) *I figured I probably couldn't land there, but if there was any possibility I could fly to work I should at least find out. that pond looks awfully small. Looks like less than 1000 feet long and curved. *You'd need to be a pretty skilled floatplane pilot to land and takeoff there. I have no idea how much space it takes to land or take off in a floatplane. It would only be me in the plane and it would be some kind of lightweight kitplane so in the event it were permissable to land a plane there I would find the perfect plane to get me in and out. I didn't even know if this is something worth pursuing. It sounds like it isn't. As an aside, I ran into the facilities manager in the hallway this morning. He told me the pond is actually filling in and the owner has no plans to dredge it because someday after it fills in it will be usable land. Flying in there would be a temporary solution anyway. |
On Jan 31, 6:24 am, es330td wrote:
Can a float plane land on a body of water inside a city, more specifically, could one land hehttp://maps.google.com/?ie=UTF8&ll=3...9&spn=0.012551,... Note: the body of water is privately owned and in case you were wondering, that is the building in which I work. The land on the NW end of the lake is covered with bushes that are only 3-4 feet tall. The rule of thumb is that you can land a seaplane anywhere you can legally put a power boat. This rules out a few reservoirs but most bodies of water are OK. Some parts of some lakes are off-limits due to safety concerns for swimmers, etc. The Seaplane Pilots Organization http://www.seaplanes.org publishes a national directory with a lot of detail on landing sites all over the country. On private land, you'd just need permission from the landowner, assuming you can get there from the air without violating any FARs. What some ignorant, fearful local law enforcement type would think is another story. I wouldn't try it if the pond is much less than 3,000 ft. |
I think it's only about 1000 feet. Funny how things that look big on the ground look really small when you think about putting a plane down on it. |
On Feb 6, 1:14*pm, es330td wrote:
I wouldn't try it if the pond is much less than 3,000 ft. I think it's only about 1000 feet. *Funny how things that look big on the ground look really small when you think about putting a plane down on it. Depending on the plane and the winds (are you limited what directions you can take off) 1000 feet may be just fine. -robert |
Rules for interior modifications of Certified Aircraft (question). | EridanMan | Home Built | 1 | March 30th 06 11:34 PM |
State Record Rules Question | Gary Emerson | Soaring | 2 | February 22nd 05 03:30 AM |
Rules Question... | Gary Emerson | Soaring | 1 | February 8th 05 01:20 PM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
Question for any commericial airline rules experts out there | Ted Wagner | Soaring | 6 | February 7th 04 11:40 PM |
