PC power using aircraft ground
Old February 5th 08, 03:03 AM posted to rec.aviation.owning, rec.aviation.homebuilt
Default PC power using aircraft ground
I run a Motion LS800 for my EFB. I use a DC 12V to 19V power
converter to power my LS800 since I have a 12V aircraft system.
To minimize the number of wires, can I use a single wire to run +19V
from the power converter to LS800 and connect the ground from power
converter to LS800 thru the airfram ground?
Thanks in advance,
Robin Hou
FS: 60' Aircraft ground power cable, 6-conductor, copper - $480 [email protected] Aviation Marketplace 0 May 16th 06 02:55 AM
Permit to use aircraft radio frequencies on ground C. J. Clegg General Aviation 23 January 20th 05 08:23 PM
Permit to use aircraft radio frequencies on ground C. J. Clegg Restoration 1 January 1st 05 11:08 PM
Predicting ground effects on induced power Marc Shorten Soaring 0 October 28th 03 12:18 PM
NEEDED: Aircraft Ground Handling Information Jarry Clausing Products 0 August 9th 03 04:24 PM
