Hi,
I'm looking for a replacement Palm PDA to run SoaringPilot software. I have a Tungsten T and I'm very happy with it's display clarity even in bright sunlight, but it has a problem with touchscreen registration when it gets hot, and this often makes the software unusable. Anyone currently using other Palm devices, like the Tungsten E2 or TX? If so, have you had any problems with touch-screen registration and/or display glare/contrast? TIA, Frank(TA) |
I went for a monochrome display - found the colour screens not great
for soaringpilot. found a IBM PDA similar to a PALM VX which I have dedicated to soaring. It was cheap at about $100 eventhough new at the time - sure they can be found really cheap on e-bay. No problems running soaringpilot which has always been written with lower processing power in mind and is not very graphic. Have tried a few other solutions using my IPAQ but always go back to the trusty palm running soaringpilot with its monochrome screen - its just so easy to see and use. Clinton LAK 12 |
Hi Frank,
Frank schrieb: Hi, I'm looking for a replacement Palm PDA to run SoaringPilot software. I have a Tungsten T and I'm very happy with it's display clarity even in bright sunlight, but it has a problem with touchscreen registration when it gets hot, and this often makes the software unusable. Try disassembling the T and cleaning the flat-cable connectors. That did the trick for the 3 Tungsten-T models in our club. The "T" is still the Palm to go for. Cheap, really good display in the sun and fast. CU Markus |
Have you tried this?
http://www.palm.com/us/support/downl...digitizer.html Dave Markus Gayda wrote: Hi Frank, Frank schrieb: Hi, I'm looking for a replacement Palm PDA to run SoaringPilot software. I have a Tungsten T and I'm very happy with it's display clarity even in bright sunlight, but it has a problem with touchscreen registration when it gets hot, and this often makes the software unusable. Try disassembling the T and cleaning the flat-cable connectors. That did the trick for the 3 Tungsten-T models in our club. The "T" is still the Palm to go for. Cheap, really good display in the sun and fast. CU Markus |
On Feb 10, 9:44*pm, Dave Rolley wrote:
Have you tried this? http://www.palm.com/us/support/downl...digitizer.html Dave Thanks for the pointer, but yes, I have already tried this, and the connector cleaning also Frank |
OK, here is something else to try:
http://www.palmpowerups.com/news.php Look for PowerDiGi. Supposedly it can address some of the digitizer registration problems. Dave Frank wrote: On Feb 10, 9:44 pm, Dave Rolley wrote: Have you tried this? http://www.palm.com/us/support/downl...digitizer.html Dave Thanks for the pointer, but yes, I have already tried this, and the connector cleaning also Frank |
On Fri, 8 Feb 2008 19:25:25 -0800 (PST), Frank
wrote: Hi, I'm looking for a replacement Palm PDA to run SoaringPilot software. I have a Tungsten T and I'm very happy with it's display clarity even in bright sunlight, but it has a problem with touchscreen registration when it gets hot, and this often makes the software unusable. Anyone currently using other Palm devices, like the Tungsten E2 or TX? If so, have you had any problems with touch-screen registration and/or display glare/contrast? TIA, Frank(TA) I used a Tungsten W last year but haven't given it as much exercise as I'd like since then. The "W" has a cellphone in it (which you can turn off and ignore) and a small keyboard like a Blackberry. The screen was very clear in sunlight and I like the ability to use the keyboard to access the different screens directly. The "W" runs the older Palm v4 operating system (see the Wikipedia article on the subject) but runs SoaringPilot just fine. They appear on eBay quite often and dismantling to insert a new battery isn't too scary. Paul |
How to charge a Palm in C-172? | Marc | Piloting | 4 | June 28th 04 05:49 PM |
Nexrad for Palm | PaulH | Owning | 3 | May 15th 04 06:25 PM |
FS: PALM ® M105 $40 | Jaysen Underhill | General Aviation | 0 | December 11th 03 09:39 PM |
FS: PALM ® M105 $40 | Jaysen Underhill | Aviation Marketplace | 0 | December 11th 03 09:38 PM |
FS: PALM ® M105 $45 | Jaysen Underhill | Aviation Marketplace | 0 | October 17th 03 01:26 AM |
