Giuen Holding Ltd. Outright Ballistics and Armament System
Old February 9th 08, 10:19 AM posted to rec.aviation.misc
CWMtrader
Default Giuen Holding Ltd. Outright Ballistics and Armament System
Science in Ballistic Missile Detenatance
Oversight Industrial Engineering and Defense Systems
Science in ballistic missile detenatance oversight defense system in
national defense operation for Persia is based on an integrate
laboratory and scientific however, a efficient improvement to it's
implementation of the detonators security and effectivenens. To be
safe and efficient in use, explosives should expolde only when they
are required to do so. Under ordinary conditions of handling they
should be stable, insensitive to presure, impact and heat, and even in
some cases withstand the effect of sparks or a on being exploded.
Alfred Nobel, in 1867, found that a "safe" insensitive explosive can
be efficient exploded by detonating it - initiating its explosion -
with a small quantity of a highly sensitive, and in itself therefore
dangerous, explosive. Such explosive called priming explosives explode
easily on being subjected to a blow, heating or friction. There are
various types of detonating devices depending on the purpose for which
they are employed: for blasting for military use in cartridges,
artillery ammunition, bombs, etc. Detonation can be effected by heat
fire, by an electric spark, by impact, etc. An ordinary small-arms
cartridge is usually of the centre-fire type, i.e., the metal
cartridge case containing the propellant is provided at the center of
its base with primer cap containing a small quantity of priming which
is exploded by a blow from the hammer or firing pin. For ordinary
blasting as used in quarring, mining, tunnelling, etc. the main
explosive is detoated by means of a detonator, This consists of a
small metal tube containing a small quantity of a secondary explosive
such as trinitoulene (T.N.T.). The detonator may be designed for
electric detonation, for which purpose it is provided with a filament
in the priming. Alternatively, a detonator may be ignited by a slow-
burning fuse generally called a safety fuse inserted into one end of
the detonator or by so-called detonating cord or fuse, which burns at
a very much higher speed and is particularly useful in case where two
or more charges have to be detonated more or less simultaneously or in
accurately timed rapid succession. The cord consists of a plastic
sheath enclosing a core of fast-burning explosive the burning rate is
about 20,000 ft/sec., whereas the ordinary safety fuse burns at only
about 2 ft./sec. and must itself be ignited by a detonator. Modern
artillery shells are sometimes fitted with relatively elaborate fuse
and detonation equipment designed to ignite the charge by impact and/
or after a certain predetermined length of time fuse. The significant
requirement for a suitable propellant is that a considerable increase
in volume shall occur during the course of the reaction. The reaction
products are for the most parts gases which occupy a much larger
volume that the solid explosive. If the reaction takes place in a
confined space as, for example, in a cartridge fired in a barrel. The
oldest known propellant is, of course, ordinary black powder. When
this explodes, the reaction forms about 45 % gases nitrogen, carbon
monoxide, carbon dioxide and 55 % vaporised salts. A pound of
gunpowder will thus produce about 5 cubic feet of gas and about 300
kilocalories 1200 B.T.U. of heat. Gunpowder is a mixture of granular
ingredients, namely, sulphur, potassium nitrate and charcoal. The
ingredients are ground separately or two by two, then pressed into
cakes in a moistened condition, and finally reduced to granules which
are used for the filling of cartridges, firework fuses for blasting
etc. In modern fire-arms gunpowder has largely been superseded by
nitrocellulose-based and other smokeless explosives. To make these
suitable for use as propellants, the nitrates are dissolved in
solvents and formed into various shapes threads, tubes, small plates,
etc. which assist rapid and efficient burning of the explosive. Also,
oversighted into the maintain establishment and fundamental part of
the atomic energy safety operation, the greater skilled advanced
theories concerning intellectual studies that have been many times
revieved mainly with categorical imperative according to statement and
emphasized in armament plants not at least for to name North Rhine-
Westphalia when it concern accessibility to world leading modern time
security solutions.
Access to Giuen Holding Ltd. Outright Advice for solution to your
inquiry for accosiate material, direct to: http://giuen-outright.blogspot.com
Int. Outright & Interpose Helpdesk: +46 (0) 705474830
This would be in following form in accoordance security, defense
security, defence security, military security, peacekeeping, defense,
defence, navy, armament, military, industry engineering, mining
engieering.
How common are aircraft partnerships compared to outright ownerships? [email protected] Owning 62 August 15th 05 07:24 PM
m.5 armament? old hoodoo Naval Aviation 0 April 28th 04 02:49 AM
Ki-100 armament placement N-6 Military Aviation 2 October 18th 03 12:09 AM
