I'm trying to find out a formulae regarding the gap between Takeoff
Distances by POH and real-life measures. I did the maths for wind, temperature, pressure altitude, runway slope, weight, etc. It's quite detailled and effective... But... The only calculation I don't know how to "translate" is the difference, in feet, between the POH speed and the speed I did during the test. For example: If my airplane took off at 1050 feet on the initial roll, at 62 knots, how many feet will I need if left the runway at 56 kts ? POH states it requires only 699 feet at 56kts for the same factors (temp, press, etc)! Thank you Paul |
On Feb 13, 7:23*am, "Paul" wrote:
I'm trying to find out a formulae regarding the gap between Takeoff Distances by POH and real-life measures. I did the maths for wind, temperature, pressure altitude, runway slope, weight, etc. It's quite detailled and effective... But... The only calculation I don't know how to "translate" is the difference, in feet, between the POH speed and the speed I did during the test. For example: If my airplane took off at 1050 feet on the initial roll, at 62 knots, how many feet will I need if left the runway at 56 kts ? POH states it requires only 699 feet at 56kts for the same factors (temp, press, etc)! I think most of the POH takeoff figures are not theoretical calculations but the results of actual tests. As such they are affected by factors outside aerodynamics -runway surface roughness, tyre performance and pilot skill being factors in rolling distance. In other words I don't think a simple equation will give you the "right" answer. For a first order approximation consider kinetic energy build up. Cheers |
On Feb 13, 5:23*am, "Paul" wrote:
I'm trying to find out a formulae regarding the gap between Takeoff Distances by POH and real-life measures. I did the maths for wind, temperature, pressure altitude, runway slope, weight, etc. It's quite detailled and effective... But... The only calculation I don't know how to "translate" is the difference, in feet, between the POH speed and the speed I did during the test. For example: If my airplane took off at 1050 feet on the initial roll, at 62 knots, how many feet will I need if left the runway at 56 kts ? POH states it requires only 699 feet at 56kts for the same factors (temp, press, etc)! I think you will struggle to find a simple calculation ( or a difficult one for that matter) . why dont you just try testing your takeoff distance at the same speed as the POH reccomends? May I ask what aircraft you are flying? and what did you find with your mathematical studies, and did you read my earlier thread on "Confusion with Cessna take off distance " where I found that after converting pressure ht and temperature to density altitude that there was still a temperature effect on the take off distance required. I would be interested to know if you saw something similar wtih your data?. Terry PPL Downunder |
On 12 Feb, 18:23, "Paul" wrote:
I'm trying to find out a formulae regarding the gap between Takeoff Distances by POH and real-life measures. I did the maths for wind, temperature, pressure altitude, runway slope, weight, etc. It's quite detailled and effective... But... The only calculation I don't know how to "translate" is the difference, in feet, between the POH speed and the speed I did during the test. For example: If my airplane took off at 1050 feet on the initial roll, at 62 knots, how many feet will I need if left the runway at 56 kts ? POH states it requires only 699 feet at 56kts for the same factors (temp, press, etc)! I've got a couple at home and I'll check for you when I get there, but like I told you before, it all depends on the approach the engineer takes and you're not going to get any real precision out of them |
| Thread Tools | |
| Display Modes | |
| FA: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Derek | Aviation Marketplace | 0 | September 3rd 07 03:17 AM |
| FA: 1-Day-Left: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Jeff[_5_] | Aviation Marketplace | 0 | September 1st 07 01:45 PM |
| ENHANCED AVIATION SECURITY PACKAGE ANNOUNCED (All "General Aviation Pilots" to Pay $200.00 every two years!) | www.agacf.org | Piloting | 4 | December 21st 03 10:08 PM |
| where's the THRILL is flying, rec.aviation.balloon, rec.aviation.hang-gliding, rec.aviation.powerchutes, rec.aviation.soaring | BW | Rotorcraft | 0 | October 15th 03 12:42 PM |
