Reality-XP Garmin 530 GPS
Old February 12th 08, 11:16 PM posted to rec.aviation.simulators
wan2fly99
Default Reality-XP Garmin 530 GPS
Has anybody used this addon for any of the planes in FS9?
Is it easy to install?
Does it replace the default GPS?
Old March 5th 08, 07:45 PM posted to rec.aviation.simulators
akiley
Hi, I downloaded and installed for FS9 quite a while back. It's nice
because it does all the detailed stuff, the MSFS one does't. I don't
remember having any problem. One item was that the included HSI
didn't work right. Can't remember the details, but it wasn't really
needed. You can just turn the MSFS off by hitting the little GPS
icon, then use the Reality-XP one, no problems. There are some
interesting key strokes with this GPS. Like right clicking the bottom
edge for cursor mode.
Sorry, I can't remember much more because I fried my PC, and my new
one isn't up to speed yet. Also been spending lots of time with X-
Planes because I found a good Duchess panel for it. Getting my multi
engine rating in a real Duchess, so it's a major help. ... akiley
Old March 6th 08, 04:24 PM posted to rec.aviation.simulators
wan2fly99
Getting rating? Good I had gotten mine in a Seminole
Do yu have any material on hadnling an overspeed prop? Trying to
remember what I had learned
Might get the Garmin then Have that in a Navajo that I fly witht a
friend
Old March 8th 08, 03:59 PM posted to rec.aviation.simulators
akiley
friend
engine rating in a real Duchess, so it's a major help. ...akiley
For the Duchess, the procedure for overspeed prop is just to reduce
throttle, then check oil pressure, pull prop control back to try to
get it working again. If no joy, then keep rpm below 2700 with
throttle only and land sooner than later.
I also flew a Seneca I. There overspeed is close throttle, slow to
best rate of climb, pull prop to low rpm, slowly increase throttle
till govenor engaged, slowly increase prop and throttle.
.... akiley
VW Reality [email protected] Home Built 90 March 18th 08 10:44 PM
HondaJet a reality [email protected] Piloting 3 July 28th 06 01:50 AM
Pilot deviations and a new FAA reality Chip Jones Piloting 125 October 15th 04 07:42 PM
Pilot deviations and a new FAA reality Chip Jones Instrument Flight Rules 36 October 14th 04 06:10 PM
Reality of Tie Down (Tiedown) Space at SNA Tie Town Owning 1 May 6th 04 07:43 AM
