I just had a strange one. I have been balancing my rotor system using a DSS
balancer where I would get the ips and phase angle measurements, turn the rotor to the angle with respect to the photo cell described by the phase angle information, then sight over the velocimeter and add weight to the rotor system on the Opposite side of the mast. This Add Opposite has worked time and time again on the main rotor. Recently I did my annual condition inspection and went completely thru the controls, re-adjusting every thing and carefully zeroed out the lead/lag, checked the head shift and then did a hover check. Results 0.96 ips @ 270. Well with the arrangement I have with the velocimeter, the photo cell and the reflective tape on the swash plate this mean that most of the inbalance was chord wise. I added weight to the side Opposite and flew again. Results: 1.96 ips @ 274!!! I couldn't believe the datat. For giggles I reversed the weight to an Add Same condition and got the following results: 0.26 ips @ 184. What little inbalance that was left appeared to be span-wise. Question: What could cause the phase angle information to flip 180 degrees from what I was used to seeing? The only thing that I'm familiar with that causes the 180 flip with all things else being equal is to be operating above a critical speed and the rotation rate hasn't changed and the mass in the rotor mast and head hasn't changed. Further I added some washers to the blade indicated in the 0.26 ips measurement using the Add Opposite technique and it appears that I should have used the Add Same again. So there seems to be some strong consistancy in the mysterious 180 degree phase flip. I expect the Add Same on the tail rotor as I have checked it out and found a critical speed below the operational speed which will produce the velocimeter being on the side opposite of the inbalance weight. |
![]() "Stuart & Kathryn Fields" wrote in message .. . I just had a strange one. I have been balancing my rotor system using a DSS balancer where I would get the ips and phase angle measurements, turn the rotor to the angle with respect to the photo cell described by the phase angle information, then sight over the velocimeter and add weight to the rotor system on the Opposite side of the mast. This Add Opposite has worked time and time again on the main rotor. Recently I did my annual condition inspection and went completely thru the controls, re-adjusting every thing and carefully zeroed out the lead/lag, checked the head shift and then did a hover check. Results 0.96 ips @ 270. Well with the arrangement I have with the velocimeter, the photo cell and the reflective tape on the swash plate this mean that most of the inbalance was chord wise. I added weight to the side Opposite and flew again. Results: 1.96 ips @ 274!!! I couldn't believe the datat. For giggles I reversed the weight to an Add Same condition and got the following results: 0.26 ips @ 184. What little inbalance that was left appeared to be span-wise. Question: What could cause the phase angle information to flip 180 degrees from what I was used to seeing? The only thing that I'm familiar with that causes the 180 flip with all things else being equal is to be operating above a critical speed and the rotation rate hasn't changed and the mass in the rotor mast and head hasn't changed. Further I added some washers to the blade indicated in the 0.26 ips measurement using the Add Opposite technique and it appears that I should have used the Add Same again. So there seems to be some strong consistancy in the mysterious 180 degree phase flip. I expect the Add Same on the tail rotor as I have checked it out and found a critical speed below the operational speed which will produce the velocimeter being on the side opposite of the inbalance weight. If anyone out there is interested in rotor balancing other than me, this is a follow up to the previous post. The next day I ran another check and this time I used "Add Opposite" and have the balance down to 0.1ips. I talked to Murray Sweet of Canadian Home Rotors and he told me to disconnect the battery of the balancer and re connect it and it often cures the 180 degree phase flip. On the DSS balancer, I'm going to add a battery disconnect switch. Hopefully this will eliminate the funny phase data and save me one run up. |
![]() "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Wed, 27 Feb 2008 09:03:34 -0800, "Stuart & Kathryn Fields" wrote: I expect the Add Same on the tail rotor as I have checked it out and found a critical speed below the operational speed which will produce the velocimeter being on the side opposite of the inbalance weight. If anyone out there is interested in rotor balancing other than me, this is a follow up to the previous post. The next day I ran another check and this time I used "Add Opposite" and have the balance down to 0.1ips. I talked to Murray Sweet of Canadian Home Rotors and he told me to disconnect the battery of the balancer and re connect it and it often cures the 180 degree phase flip. On the DSS balancer, I'm going to add a battery disconnect switch. Hopefully this will eliminate the funny phase data and save me one run up. I'd be interested if I knew WTF "Add Opposite" etc was. ![]() Ok a little discussion of balancing. If you have a shaft rotating at a speed below it's "Critical speed" and it is out of balance, and you put a pencil up near the shaft, it will mark the heavy side and if you are going to correct for the out of balance condition, you need to put a weight on the "Oppisite" side of the shaft. Hence "Add Opposite". When running a balance check on my helicopter, the balancer reads rpm, ips and phase angle. I interpret the phase angle measurement to mean the position of the rotor with respect to a reflective tape where the max vibration point occurred. I position the rotor at that angle and look across the shaft from the velocimeter and Voila I "Add Opposite" and I have a balanced rotor after about three to 4 runs. However, the tail rotor is spinning at a speed that is above the "Critica Speed" and there is a 180 degree phase shift encountered. Back to the pencil it now marks a spot on the side opposite the heavy side so that corrective weights must be located by "Add Same". This techniqu has gotten me balancer readings down below 0.1 ips. (Military says anything below 0.4 is ok) Note if you run at the "Critical Speed" and it doesn't come apart, the pencil makes a mark 90 degrees behind the heavy spot. So if you are close to the "Critical Speed" your pencil is going to mark somewhere and if you try to "Add Opposite" or " Add Same" you are going to be chasing the little dots around your polar chart if you use one. Gawd I love helicopters they are an unending source of questions. Stu Fields |
Kevin: I sent you an e-mail with an attachment of an article I wrote for
the March issue of our magazine titled Rotor Rigging that goes into more details and has a graphic showing the relationship between the photo cell, the velocimeter and the reflective tape. Picture is worth 10,000 of my words. "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Wed, 27 Feb 2008 19:14:08 -0800, "Stuart & Kathryn Fields" wrote: Ok a little discussion of balancing. If you have a shaft rotating at a speed below it's "Critical speed" and it is out of balance, and you put a pencil up near the shaft, it will mark the heavy side and if you are going to correct for the out of balance condition, you need to put a weight on the "Oppisite" side of the shaft. Hence "Add Opposite". OK, figured it was probably something like that. When running a balance check on my helicopter, the balancer reads rpm, ips and phase angle. I interpret the phase angle measurement to mean the position of the rotor with respect to a reflective tape where the max vibration point occurred. I always understood phase angle to be the relationship between the feathering axis of a blade and the point at which its control link attaches to the swash (Advance angle - we use "phasing" in the RC world to describe the same thing) How do you determine where to put the reflective tape? Based on the pencil mark at the heavy side? I position the rotor at that angle and look across the shaft from the velocimeter and Voila I "Add Opposite" and I have a balanced rotor after about three to 4 runs. Might be lack of coffee after a whopping 3.5 hours of sleep, but ya lost me there. However, the tail rotor is spinning at a speed that is above the "Critica Speed" and there is a 180 degree phase shift encountered. Define "critical speed" and why the 180 degree shift? Back to the pencil it now marks a spot on the side opposite the heavy side so that corrective weights must be located by "Add Same". This techniqu has gotten me balancer readings down below 0.1 ips. (Military says anything below 0.4 is ok) I think you need to redo it until it's 0.0 ips. Job's not worth doin' unless it's done right! ![]() Note if you run at the "Critical Speed" and it doesn't come apart, the pencil makes a mark 90 degrees behind the heavy spot. So if you are close to the "Critical Speed" your pencil is going to mark somewhere and if you try to "Add Opposite" or " Add Same" you are going to be chasing the little dots around your polar chart if you use one. Ok, I'm off to get coffee 'cuz ya lost me again.... Gawd I love helicopters they are an unending source of questions. I know we do a LOT of tweaking/balancing on our RC helis, but at least I understand that. hehehe |
spin balancing a tail rotor | Stuart & Kathryn Fields | Rotorcraft | 7 | October 23rd 06 05:33 PM |
Balancing | [email protected] | Home Built | 3 | July 17th 06 11:08 PM |
balancing act | Stuart & Kathryn Fields | Rotorcraft | 10 | June 1st 06 01:42 AM |
Balancing act | Big John | Home Built | 1 | November 28th 03 04:33 PM |
Looking for out of service main rotor blades for testing new rotor | Wright1902Glider | Home Built | 9 | July 28th 03 06:06 AM |
