KX-99 antenna BNC loose
Old February 28th 08, 11:36 PM posted to rec.aviation.owning
Default KX-99 antenna BNC loose
The BNC connector on the top of my KX-99 has become very slightly
loose. Does anyone know how dangerous it is to open the case up and
try to tighten it? I assume it has a nut of some sort. I just don't
know how much has to be removed to get to it.
The radio has been great. It has worked perfectly since I bought it
new maybe 15 years ago. I don't want to mess it up.
Thanks
Kurt
Old April 10th 08, 04:26 PM posted to rec.aviation.owning
Thanks
Kurt
I have repaired several of these, no biggie, the nut comes loose and
usually breaks the wire soldered to the connector.
Al-- NM Radio Sales
Seaplane Base - 4 - Cut Him Loose-3.jpg (1/1) john smith[_2_] Aviation Photos 0 August 2nd 07 05:11 AM
Lycoming 0-320 Exhaust studs working loose Mike Spera Owning 9 May 26th 07 03:25 AM
GPS Antenna 150flivver Owning 14 December 11th 05 05:38 AM
ELT Antenna Gary Home Built 18 November 5th 04 02:17 AM
Found Loose Cylinder Bolt Greg Hopp Owning 21 February 19th 04 03:04 PM
