Power on the flareout.
Old January 10th 04, 04:37 AM
ArtKramr
Default Power on the flareout.
The B-26 Martin Marauder needed power poured on to execute the flareout. If
that was not done, the aicraft would not pull up and just plow into the ground.
Arthur Kramer
344th BG 494th BS
England, France, Belgium, Holland, Germany
Visit my WW II B-26 website at:
http://www.coastcomp.com/artkramer
Old January 10th 04, 04:57 AM
Dudley Henriques
"ArtKramr" wrote in message
If
ground.
I'd be surprised if this was not the case Art. Most high performance twins
with a wing loading like the 26 would be carrying a lot of power on final if
flown correctly, especially if you were heavy on approach. Normally you
could make it on the front side of the power curve, but you can drag them in
behind the curve as well. A lot of the guys did this on the back side, even
though you could really buy the farm if something coughed!! :-) You just had
to keep it out of coffin corner. Get back in there on final with no room to
decrease the angle of attack and it was kitty barred the door!! I'm sure you
remember!!! :-))))
Dudley
Old January 10th 04, 05:14 AM
Dudley Henriques
Subject: Power on the flareout.
Date: 1/9/04 8:57 PM Pacific Standard Time
Message-id: t
flareout.
If
ground.
twins
if
in
even
had
to
you
remember!!! :-))))
Dudley
I sure do remember on over 100 landings. The roar of those R-2800's on
flare
outs was eagerly awaited music to my ears. Ah memories of death defying
moments. (sigh)
I've had a few of those "moments" myself! :-) A real "death defying moment"
happens not so much when everything's "roaring", but if you happen to get
those 2800's running a bit too rich on final; let the bird go too deep
behind the curve; then get excited and pour it to her too fast.
SILENCE!!!!!! Now THERE'S a silence that will wake you up in a nano
second!!!! :-))
Dudley
Old January 10th 04, 05:22 AM
ArtKramr
Date: 1/9/04 9:14 PM Pacific Standard Time
Message-id:
Message-id: t
flareout.
If
ground.
twins
if
in
even
had
to
you
remember!!! :-))))
Dudley
flare
moments. (sigh)
second!!!! :-))
Dudley
Aaaaargh. When you have a moment read," Hold off the damn nose wheel Paul" on
my website.
Arthur Kramer
344th BG 494th BS
Old January 10th 04, 05:38 AM
Dudley Henriques
Message-id:
Message-id: t
flareout.
If
ground.
twins
final
if
you
them
in
even
just
had
room
to
sure
you
remember!!! :-))))
Dudley
flare
defying
moments. (sigh)
moment"
second!!!! :-))
Dudley
on
my website.
Read it! Good landing. Aerodynamic braking in that crate would have been
hard with full flaps and those engines sticking out there in front of the
cg. He did good!! :-)
I've sent you a back channel photo (from the new book) of a guy with a REAL
problem!! :-)))) This is what can happen if you fly under a bridge inverted.
He walked away believe it or not!
Dudley
homemade EFIS system and EMI jcpearce Home Built 75 February 22nd 05 02:07 AM
FS: 1988 "Air Power" Postcard J.R. Sinclair Aviation Marketplace 0 October 26th 04 06:28 AM
IO 360 Power down (danger, long, rambling post!) Jim Harper Home Built 24 July 11th 04 12:04 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 03:29 PM
