Free balloons and VFR flying
Old March 3rd 08, 04:41 AM posted to rec.aviation.piloting
Andrew Sarangan
Default Free balloons and VFR flying
I recently met some high altitude balloonists during a launch. These
are similar to weather balloons, roughly 6'-10' in size at launch
elevation. When released, they climb in excess of 1000 fpm. They seem
to be mostly colored white, so they would be hard to spot from an
airplane. I have been mostly unaware of these balloons during all my
flying. So my concern is how to avoid these balloons during VFR
flights. A collision with them could be catastrophic - the chords can
be tangled in the prop or other control surfaces, or the balloon can
simply obscure the cockpit window. They did call the local FSS just
before launch, but I am assuming this is only for IFR separation. I
just flew in in my airplane to the launch site, so I know there was no
NOTAMs about this. Even if there were a NOTAM it would have to cover a
huge geographic area, spanning several states. I have never seen such
NOTAMs. It would seem that making the balloons in bright pink or neon
color might be a better choice instead of white.
Old March 3rd 08, 04:53 AM posted to rec.aviation.piloting
Maxwell[_2_]
"Andrew Sarangan" wrote in message
Wouldn't this be a good reason to use flight following?
Old March 3rd 08, 11:50 AM posted to rec.aviation.piloting
Kyle Boatright
"Maxwell" luv^2^fly^99@^cox.^net wrote in message
Do balloons have a transponder? I kinda doubt it, since thesy are
disposable items.
Old March 3rd 08, 12:42 PM posted to rec.aviation.piloting
Dan Luke[_2_]
White is the highest visibility color for a broad range of lighting
conditions. There are colors that are slightly better in bright light, some
slightly better in dim light, but across the range no other color maintains
reflectivity as well as white.
Dan
T-182T at 4R4
Old March 3rd 08, 02:28 PM posted to rec.aviation.piloting
*It would seem that making the balloons in bright pink or neon
conditions. *There are colors that are slightly better in bright light, some
Dan
T-182T at 4R4
That means we have no broad range of lighting conditions over here.
Our mil. trainers are painted black.
-Kees
Old March 3rd 08, 04:02 PM posted to rec.aviation.piloting
Maxwell[_2_]
"Dan Luke" wrote in message
some slightly better in dim light, but across the range no other color
maintains reflectivity as well as white.
It could also just be the cheapest. White colored materials are often just
the absence of color pigments.
Old March 3rd 08, 04:10 PM posted to rec.aviation.piloting
Maxwell[_2_]
"Kyle Boatright" wrote in message
disposable items.
Why would they need a transponder? ATC wouldn't be giving traffic advisories
to an unmanned balloon.
Old March 3rd 08, 05:45 PM posted to rec.aviation.piloting
Larry Dighera
On Mon, 3 Mar 2008 10:10:36 -0600, "Maxwell" luv^2^fly^99@^cox.^net
wrote in :
It's doubtful ATC radar would paint much of a primary target of such a
nonmetallic object.
Old March 3rd 08, 06:49 PM posted to rec.aviation.piloting
Jim Stewart
And the least amount of solar warming.
In Bed! The Clown! With NO BALLOONS!!11! Michael Baldwin, Bruce[_2_] Products 0 August 19th 07 03:57 AM
Balloons G. Sylvester Piloting 28 February 6th 07 04:34 AM
Balloons Airships vintage book FA [email protected] General Aviation 0 July 16th 05 01:12 AM
Balloons maybe a new glider launch method NOT Mal Soaring 4 December 14th 04 05:19 AM
Questions about hot air balloons L. Hines Owning 9 February 1st 04 05:31 AM
