Hey, I read your topic concerning aircraft stopping in midair and
would like to ask another question that I hope isn't considered stupid. Here goes, "why" is it so hard to believe? I once went to an air show in New York when I was much younger and there was an airplane that did stunts in the air. It was a propeller plane which I don't know what kind and it did a whole string of fancy flying that had the crowd in awe. One of the flyer"s moves put the aircraft in a loop than a climb. We watched for the next trick but then the plane's motor cut out and he just stopped in the air. We all looked up and it just sat there for a minute, not moving. Is this considered really stopped or was the altitude making it an optical illusion? Was the flyer still slightly moving? Anyhow, he dropped down, restarted his engine, and then did more tricks. I'll never forget that sight though. I was so scared at first that an accident might happen but the sight of the plane in suspension was wonderful. Oh yeah, mister smarty-pants at my work said that the Reds can stop in the air. I had to write down the aircraft he listed and these comments, "one of the very first Su-27 aircraft discovered 0 IAS on a test flight after developing an inflight control problem. Nosing up into high AOA the aircraft stood on its tail and stopped in midair for an alarming 18 seconds at 8,000m before the aircraft dropped back down and rolled free". He said the flight occurance was reported and documented a long time ago. Can anyone disprove this guy? What is a Su-27, a prototype or what? James Dandy |
![]() "James Dandy" wrote in message m... One of the flyer"s moves put the aircraft in a loop than a climb. We watched for the next trick but then the plane's motor cut out and he just stopped in the air. We all looked up and it just sat there for a minute, not moving. Is this considered really stopped or was the altitude making it an optical illusion? Either it was still moving, or the prop was still turning at a rate high enough for it to prop-hang, being held up by thrust alone (i.e. zero aerodynamic lift from the airframe.) Gravity doesn't allow for any other alternative. Can anyone disprove this guy? What is a Su-27, a prototype or what? Su-27 is the Russian "Swan", or NATO designation Flanker. It can perform Pukachev's(sp?) Cobra manouever where the aircraft stalls at 90 degrees. Again, gravity will dictate that it then slides backwards, at which point the pilot points the nose down and increases power to regain controlled flight. It cannot hang stationary in the air if the engines are out. There was a prototype Su 27 variant that had thrust vectoring, which enabled it to hover in stable conditions for a short time. It's not in itself a useful capability, i.e. it cannot loiter, take of or land in that configuration, and it burns a consireable amount of fuel doing it, while completely ordnance-free. Si |
![]() "James Dandy" wrote in message m... Hey, I read your topic concerning aircraft stopping in midair and would like to ask another question that I hope isn't considered stupid. Here goes, "why" is it so hard to believe? I once went to an air show in New York when I was much younger and there was an airplane that did stunts in the air. It was a propeller plane which I don't know what kind and it did a whole string of fancy flying that had the crowd in awe. One of the flyer"s moves put the aircraft in a loop than a climb. We watched for the next trick but then the plane's motor cut out and he just stopped in the air. We all looked up and it just sat there for a minute, not moving. Is this considered really stopped or was the altitude making it an optical illusion? Its possible for an aircraft to have zero ground speed if its stall speed is lower than wind speed I recall seeing a Fiesler Storch apparently hovering at an air show but what was happening was there was a stiff breeze blowing so its airspeed was above the region where a stall would occur but it was basically standing still with regard to the ground. Keith |
Back in 1988 at an airshow at the Allegheny County Airport, Pittsburgh, Pa.,
I saw demonstration flight with a Piper Cup in a stiff breeze in which he did hover over a particular spot for about ten minutes going up and down and goosing the throttle.. "Keith Willshaw" wrote in message ... "James Dandy" wrote in message m... Hey, I read your topic concerning aircraft stopping in midair and would like to ask another question that I hope isn't considered stupid. Here goes, "why" is it so hard to believe? I once went to an air show in New York when I was much younger and there was an airplane that did stunts in the air. It was a propeller plane which I don't know what kind and it did a whole string of fancy flying that had the crowd in awe. One of the flyer"s moves put the aircraft in a loop than a climb. We watched for the next trick but then the plane's motor cut out and he just stopped in the air. We all looked up and it just sat there for a minute, not moving. Is this considered really stopped or was the altitude making it an optical illusion? Its possible for an aircraft to have zero ground speed if its stall speed is lower than wind speed I recall seeing a Fiesler Storch apparently hovering at an air show but what was happening was there was a stiff breeze blowing so its airspeed was above the region where a stall would occur but it was basically standing still with regard to the ground. Keith |
![]() Użytkownik "Keith Willshaw" napisał w wiadomo¶ci ... "James Dandy" wrote in message m... [snip...] Its possible for an aircraft to have zero ground speed if its stall speed is lower than wind speed Not only. THEORETICALLY every modern fighter could do this trick. With thrust-to-weight ratio more than 1, which is normal for modern fighters, they could (repeat: THEORETICALLY!) stand vertically on the fire. This would be flying circus trick rather than any usable manoeuver. And YES, there were experimental VTOL aircraft (the 'Tail Sitters': Convair XFY-1 Pogo, Locheed XFV-1, Ryan X-13 Vertijet) but the designs were abandoned as 'dangerous and unpractical'. Starting from the page http://www.airandspacemagazine.com/a...e/QT/menu.html you can see some QuickTime clips with these aircraft during start/landing/hovering. I recall seeing a Fiesler Storch apparently hovering at an air show but what was happening was there was a stiff breeze blowing so its airspeed was above the region where a stall would occur but it was basically standing still with regard to the ground. Not only. I recall a photo made in multiple-exposure mode in which Helio 550A Stallion (AU-24 for military pilots) took-off with head wind. After few minutes aircraft was some 500-600 feet ABOVE starting point nad had NEGATIVE ground speed. I saw this picture in Polish air-enthusiast's weekly 'Skrzydlata Polska' in late 60s or early 70s. I heared also a story about An-2 from roughly the same time. This could be urban legend, but is interesting. It happened at Warsaw Okecie airfield. The place is important, so I tell you that this airfield has 2 active runways (15/33 and 11/29 intersecting in the middle). The NW edge of the airfield (between runways 29 and 33) is shared by aircraft factory (PZL Okecie) and Aviation Institute (ILot). Third runway (and oldest one) runs east-west just off the PZL/ILot fence; it is not used for years and was degraded to taxi-way role. Test pilots of both firms rarely used regular runways; they used to take off from the oldest runway or from the grass across the airfield. One time an PZL test pilot was flying An-2 home from south. He contacted the tower, received approval and intended to land usual way i.e. on the grass. He was on final approach when tower ordered him to wait in the air until scheduled airliner made his landing. An-2 was first there and should have priority (one engine versus 2- or 4-engined airliner). There was strong headwind so the guy in An-2 flew to the runways' crossing, raised aircraft's nose, slats and flaps on - practically hovering 50 ft above ground, and reported to the tower 'OK, I'm waiting'. The tower was flabbergasted. Fortunatelly the captain of the other aircraft acted quickly and went around. The story don't tell the fate of An-2 pilot. Keith BTW the name of the airplane you saw is FIESELER Fi-156 Storch. Art Kramr usually spells that name Feisler. ;-( Regards JasiekS Warsaw, Poland |
