Speaking of tape...
Old March 7th 08, 04:36 AM posted to rec.aviation.owning
Jay Honeck[_2_]
Default Speaking of tape...
My fancy pants (a brand of wheel pant) have been done and re-done many times
over the years, going from dzu quick-connectors to phillips screws, having
fiberglass repairs, etc.
The halves firmly screw together just fine, and they're strong as a bridge
abutment, but the tight fit between the halves has been lost. They now have
a visible 1/3" to 1/2" gap at the seam that probably represents a fairly
significant aerodynamic drag under air loads. In fact, I've wondered if
that gap doesn't open up a bit under the load of a 140 knot wind, and has
maybe lead to some of the damage we've seen around the connectors.
It seems like a piece of tape (like is used in some aileron gap seals) over
the seam would take care of the problem. True, it would make removing the
wheel pants more of a pain, but we only remove them at annual, anyway.
What's the rule on something like this? Would this be considered an
owner-applied cosmetic modification, or something that needs some sort of
approval?
And does anyone have an on-line source for tape of his kind?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 7th 08, 11:36 AM posted to rec.aviation.owning
abutment, but the tight fit between the halves has been lost. *They now have
significant aerodynamic drag under air loads. *In fact, I've wondered if
the seam would take care of the problem. * True, it would make removing the
What's the rule on something like this? * Would this be considered an
approval?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993www.AlexisParkInn.com
1/2" gap... yeah it is most probably a source of drag. A stragically
placed piece of similar colored tape over the "offending" area falls
under the "owner applied cosmetic mod" in my eyes... YMMV. I guess my
question is,, What does Fancy Pants have to say about this poor mating
flaw?
Ben
Old March 7th 08, 05:54 PM posted to rec.aviation.owning
Jim Stewart
times over the years, going from dzu quick-connectors to phillips
screws, having fiberglass repairs, etc.
bridge abutment, but the tight fit between the halves has been lost.
They now have a visible 1/3" to 1/2" gap at the seam that probably
represents a fairly significant aerodynamic drag under air loads. In
fact, I've wondered if that gap doesn't open up a bit under the load of
a 140 knot wind, and has maybe lead to some of the damage we've seen
over the seam would take care of the problem. True, it would make
removing the wheel pants more of a pain, but we only remove them at
annual, anyway.
of approval?
The glider guys like this stuff...
http://www.cumulus-soaring.com/bowlus.htm
Speaking of POP OUT FLOATS SHIVER ME TIMBERS Rotorcraft 10 June 21st 05 07:08 PM
Speaking of dogs [email protected] Soaring 5 April 26th 05 05:18 PM
Speaking of Las Vegas Marty Piloting 1 December 26th 04 08:26 AM
Speaking of Gasoline TO THE GROUP Piloting 11 May 31st 04 06:57 PM
speaking of stats R. Hubbell Piloting 2 November 26th 03 04:56 AM
