alum tube ac construx hardware- saddles source
Old March 19th 08, 09:17 PM posted to rec.aviation.homebuilt
patrick mitchel
Default alum tube ac construx hardware- saddles source
I have a freind that wants to build aluminum tube type homebuilt. He wants
to use ultralight/ hanglider type fittings for the hardware. What are the
most common north american sources online for the hadware connectors
(saddles etc.) Thanks in advance Pat
Old March 19th 08, 10:22 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
"patrick mitchel" wrote in message
You might try:
http://store.leadingedgeairfoils.com/
Old March 20th 08, 12:08 AM posted to rec.aviation.homebuilt
patrick mitchel
"Maxwell" luv^2^fly^99@^cox.^net wrote in message
You might try:
Thank you
Old March 21st 08, 02:20 PM posted to rec.aviation.homebuilt
wright1902glider
I have a freind that wants to build *aluminum tube type homebuilt. He wants
(saddles etc.) * * * * * Thanks in advance Pat
Try the obvious - Wick's and AS&S. Saddles were in the catalogs a few
years ago when I was looking for them. Probably still there. Even
though there has been a lot of streamline tubing incorporated into the
newer topless HG's, all of the lower performance ships still use round
tubes and saddles, i.e. there's still a need for spares.
I would also expect to find all of the SS tangs, cable hardware, etc.
in there too. The last I bought was in 2003 from AS&S in Georgia. The
US Hang Gliding & Paragliding website might also be helpful if you
need something really special: www.ushpa.aero
Harry Frey
USHPA #79944
Source of large diameter thick wall tube Bill Daniels Home Built 6 November 2nd 06 10:21 PM
EFB Hardware [email protected] Products 0 July 27th 06 10:26 PM
6061-T6 2"x4" rect tube source? Mr.TwistAir Home Built 8 December 11th 05 04:59 AM
Hardware Lou Parker Home Built 10 January 31st 04 12:21 PM
Need help with hardware Paul Mennen Home Built 8 August 29th 03 03:54 AM
