I'm selling off a bunch of stuff a field mechanic would have need of.
AS350 Spares box with Orings starter brushes and nuts etc for As350, Honeywell switches, metric sockets. Line plug for particle separator for ground runs.1/4" socket set 206 Nozzle socket, ceco crowsfoot and idle wrench, 7/32 wrench, 1/2x 9/16 ratchet wrench 90 degree grease gun end , fitting to allow grease to purge to a bag when doing head.11/16 x 3/4 thin wrench for L fuel line ..starter spline socket. spare hyd filter. special handled syringe for oil pump (doesn't swell) wobble Phillips bit for baggage hold, Proper facet test tool for bypass check. Special Ford model A 90 degree adjustable wrench great for big lines and PC filter removal. (probably 80 yrs old) and rare as hens teeth small camera size black light for oil leak checking, 500 thin wrench for Damper and tail rotor, 716 and 9/16 allen wrench pieces to make sockets up snap on stuff torque wrench cases for 3/8 , 1/4" drive long handle plastic case.10 piece std wrenches plus a 7/32 thread cleanup file (correct angle) sheet metal microstop with 12 bits bucking bars some clecos. 24 volt test light , micronta true rms multimeter cresent duck bills, and alot more as time progresses, REMOVE NO SPAM FROM EMAIL ec120guyNOSPAM at gmail dot com |
Best spark plug cleaning tool? | Dan Luke | Owning | 5 | August 10th 05 07:08 AM |
A-65 mechanic question | Michael Horowitz | Home Built | 24 | May 30th 05 11:08 PM |
AS350 B3 lands on top of Everest | Guy Alcala | Rotorcraft | 0 | May 26th 05 11:36 AM |
Mechanic in MN | [email protected] | Piloting | 2 | March 24th 05 03:09 AM |
I need an MD500 electrical schematic | mlminnich | Rotorcraft | 1 | October 1st 03 12:38 AM |
