ATC
Old March 28th 08, 11:00 AM posted to rec.aviation.piloting
Mike Gilmour[_2_]
Default ATC
Listening to Boston ATC at various times the Tower controller asks a flight
if they 'have got their numbers" (?) or a flight will say they're not ready
to proceed because they "don't have their numbers".
What does this mean as it doesnt translate here in the UK?
TIA
Old March 28th 08, 11:07 AM posted to rec.aviation.piloting
Jay Maynard
Default ATC
This refers to the flight performance data (primarily, weight and balance)
that the flight crew needs to enter into the flight management system. The
crew usually has that before they push back from the gate, but occasionally
the airline doesn't get it to them until later. They can't take off without
it, because they can't verify that the aircraft is within its center of
gravity range or that the accelerate-stop distance is shorter than the
available runway length.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
Old March 28th 08, 11:55 AM posted to rec.aviation.piloting
Mike Gilmour[_2_]
Default ATC
"Jay Maynard" wrote in message
flight
ready
occasionally
without
Thanks Jay, it now makes perfect sense. It's interesting to know of the
variations in ATC speak in different locations.
Old March 28th 08, 04:05 PM posted to rec.aviation.piloting
Thomas Borchert
Default ATC
Jay,
Hmm. First I heard that explanation.
I would have thought they were referring to the ATIS as "the numbers" (not
"their"). It's quite common in the US to say "We've got the numbers" or "do
you have the numbers" when in ICAO English it should be "Information Quebec
(or whatever) received". But luckily, every holder of a US certificate is
ICAO English proficient by FAA definition.
Thomas Borchert (EDDH)
Old March 28th 08, 05:49 PM posted to rec.aviation.piloting
Jay Maynard
Default ATC
"their").
Thats why I was careful to see what the original query was. The ATIS doesn't
count as "their numbers"; the weight and balance info does.
FWIW, I was always taught to indicate I had the ATIS with, for example,
"Ellington Tower, Zodiac five five Zulu Charlie, inbound from the southeast
for landing with Foxtrot." "I have the numbers" is not sufficiently precise:
it doesn't tell them *which* numbers you have, and if the ATIS changes, they
need to know if you got the right ones.
Old March 28th 08, 08:18 PM posted to rec.aviation.piloting
Bob Gardner
Default ATC
AIM 3-9-1, Jay.
Bob Gardner
balance)
(not
"their").
doesn't
southeast
precise:
they
Old March 28th 08, 10:24 PM posted to rec.aviation.piloting
Bob Gardner
Default ATC
How about the Air Traffic Control Handbook instead of the AIM:
3-9-1. DEPARTURE INFORMATION
Provide current departure information, as appropriate, to departing
aircraft.
a. Departure information contained in the ATIS broadcast may be omitted if
the pilot states the appropriate ATIS code.
b. Issue departure information by including the following:
1. Runway in use. (May be omitted if pilot states "have the numbers.")
2. Surface wind from direct readout dial, wind shear detection system, or
automated weather observing system information display. (May be omitted if
3. Altimeter setting. (May be omitted if pilot states "have the numbers.")
Bob Gardner
"Bob Gardner" wrote in message
AIM 3-9-1, Jay.
Bob Gardner
balance)
(not
"their").
doesn't
southeast
precise:
they
Old March 28th 08, 09:12 PM posted to rec.aviation.piloting
Thomas Borchert
Default ATC
Jay,
The ATIS doesn't
True enough.
Agreed.
Old March 28th 08, 05:16 PM posted to rec.aviation.piloting
Jim Logajan
Default ATC
flight if they 'have got their numbers" (?) or a flight will say
they're not ready to proceed because they "don't have their numbers".
balance) that the flight crew needs to enter into the flight
management system. The crew usually has that before they push back
from the gate, but occasionally the airline doesn't get it to them
until later. They can't take off without it, because they can't verify
that the aircraft is within its center of gravity range or that the
accelerate-stop distance is shorter than the available runway length.
The poster said these were ATC transmissions, not internal company
communications. Since ATC doesn't concern itself with weight, balance,
or any other flight performance factors, your explanation is almost
certainly wrong.
ATC does, however, need to know if the pilot has the current ATIS
(Automated Terminal Information Service) information: ceiling,
visibility, wind, altimeter setting, runway in use, and any special
airport information.
The use of "have numbers" is mentioned in AIM section 4-1-13:
http://www.faa.gov/airports_airtraff...4/aim0401.html
"While it is a good operating practice for pilots to make use of the
ATIS broadcast where it is available, some pilots use the phrase "have
numbers" in communications with the control tower. Use of this phrase
means that the pilot has received wind, runway, and altimeter
information ONLY and the tower does not have to repeat this information.
It does not indicate receipt of the ATIS broadcast and should never be
used for this purpose."
Old March 28th 08, 05:33 PM posted to rec.aviation.piloting
Dave S
Default ATC
certainly wrong.
So if a flight was ready to push back,.. or number 2 or 3 for takeoff,
they wouldnt possibly decline a departure clearance or takeoff clearance
in the manner described?
Because we all know how people stick to exactly what the AIM and the
pilot controller glossary.. right?
Use of this phrase
If they didn't have the numbers, as referenced in this manner, ATC could
just GIVE em the numbers and clear em anyways.. because we all know that
"have numbers" doesnt subsstitute for "having information alpha" or
bravo or whatever..
