Tie Wrap on Ventus Fin???
Old March 28th 08, 11:19 AM posted to rec.aviation.soaring
Gary Emerson
Default Tie Wrap on Ventus Fin???
I've got a Ventus b. On the top of the fin (under the horizontal
stabilizer) is a single tie wrap that appears to hold something to the
underside. Just curious, anyone know what that item might be? Seems to
high to be a support for the TE probe tubing. There is no tail tank
installed. Antenna perhaps???
Old March 28th 08, 02:38 PM posted to rec.aviation.soaring
On Mar 28, 5:19�am, Gary Emerson wrote:
I've got a Ventus b. �On the top of the fin (under the horizontal
underside. �Just curious, anyone know what that item might be? �Seems to
high to be a support for the TE probe tubing. �There is no tail tank
installed. �Antenna perhaps???
It could easly be to support the TE tubing. Normally the tubing is
routed up from the mount and then back down through the fin. This
upward route is to prevent water from getting into the tube. If the
water has to go up as soon as it gets into the mount then it is not
likely to accumulate in the tubing.
Robert Mudd
Moriarty, New Mexico
Old March 28th 08, 08:53 PM posted to rec.aviation.soaring
Andy Smielkiewicz[_2_]
It holds a "spare" tube- it is not connected to anything, just tied.
That is if your probe is a twin probe.
Andy
On Mar 28, 5:19?am, Gary Emerson wrote:
I've got a Ventus b. ?On the top of the fin (under the horizontal
underside. ?Just curious, anyone know what that item might be? ?Seems to
high to be a support for the TE probe tubing. ?There is no tail tank
installed. ?Antenna perhaps???
Robert Mudd
Old March 28th 08, 10:32 PM posted to rec.aviation.soaring
Brad[_2_]
wish I had read that before I installed my TE and Pitot sockets.....
Brad
Robert Mudd
Old March 28th 08, 11:40 PM posted to rec.aviation.soaring
Gary Emerson
Andy
Robert Mudd
ah, that makes sense - probably holds two in my case as I have two
"open" tubes going into the tail...
Old March 30th 08, 08:18 PM posted to rec.aviation.soaring
One can install a "triple probe" socket there. I did that few years ago. Can
be done withought cutting holes, through the top, but it is a VERY hard
work. If you are willing to cut a 3-4" hole in the side of your vertical
stab it is very easy. Erwin Salzinger makes great triple probes and sockets
as well.
Andy
"Gary Emerson" wrote in message
. net...
Andy
Robert Mudd
ah, that makes sense - probably holds two in my case as I have two "open"
It's time to wrap up & keep warm ~ G-TBIO Andrew B Aviation Photos 6 December 23rd 06 01:45 AM
It's time to wrap up & keep warm ~ G-OGES Andrew B Aviation Photos 0 December 22nd 06 05:19 PM
It's time to wrap up & keep warm ~ G-ARVU Andrew B Aviation Photos 0 December 22nd 06 05:18 PM
It's time to wrap up & keep warm ~ G-BTRS Andrew B Aviation Photos 0 December 22nd 06 05:18 PM
It's time to wrap up & keep warm ~ G-???? Andrew B Aviation Photos 0 December 22nd 06 05:18 PM
