Definition of CFIT?
Old March 29th 08, 10:46 PM posted to rec.aviation.misc
Roy Smith
Default Definition of CFIT?
I know CFIT means "Controlled Flight Into Terrain", but does an obstacle
such as a radio tower count as "terrain"? My guess is that it doesn't, but
I can't find anything that says authoritatively one way or the other.
Old March 29th 08, 10:55 PM posted to rec.aviation.misc
Gene Seibel
such as a radio tower count as "terrain"? *My guess is that it doesn't, but
Not sure how you'd log that one.
Gene Seibel
Hangar 131 - http://pad39a.com/gene/plane.html
Because I fly, I envy no one.
Old March 29th 08, 11:01 PM posted to rec.aviation.misc
B A R R Y
My guess is yes.
Old March 30th 08, 01:58 PM posted to rec.aviation.misc
Steven P. McNicoll[_2_]
Yes.
From AC 61-134 General Aviation Controlled Flight Into Terrain
Awareness:
Controlled Flight into Terrain (CFIT). CFIT occurs when an airworthy
aircraft is flown, under the control of a qualified pilot, into
terrain (water or obstacles) with inadequate awareness on the part of
the pilot of the impending collision.
Old March 31st 08, 04:00 PM posted to rec.aviation.misc
John Szalay
Roy Smith wrote in
obstacle such as a radio tower count as "terrain"? My guess is that
it doesn't, but I can't find anything that says authoritatively one
way or the other.
How about this ?
Aviation Safety Team (CAST) Common Taxonomy Team has published a definition
of CFIT accepted by many in the field (including the National
Transportation Safety Board in the United States and ICAO) similar to that
used by the CFIT JSAT. Specifically, the ICAO/CAST defined CFIT as an
"inflight collision with terrain, water,
or obstacle without indication of a loss of control."
http://www.hf.faa.gov/docs/508/docs/cami/0304.pdf
FAA Powered Glider Definition Mike Schumann Soaring 4 July 20th 07 06:26 PM
Jeremy-What is your definition of competitor? Stewart Kissel Soaring 1 March 28th 07 08:39 PM
Definition of a Veteran? Otis Willie Naval Aviation 0 March 26th 07 10:49 PM
Need A Definition Jay Beckman Piloting 4 May 11th 04 04:41 PM
definition of "dual controls" Lee Elson Instrument Flight Rules 4 April 24th 04 02:58 PM
