Big Q for the Prop Experts?
Old April 1st 08, 05:38 AM posted to rec.aviation.piloting
Default Big Q for the Prop Experts?
Take a look at these photos let me know what you think? Note only 43
hours on bird found when diagnosing the CHT probe failure. MT Prop On
SMA diesel.
http://www.internationalferryflights...l/PIC-0078.jpg
http://www.internationalferryflights...l/PIC-0079.jpg
Old April 1st 08, 07:00 AM posted to rec.aviation.piloting
SMA diesel.
Sorry all should have said prop spacer.
Old April 1st 08, 11:59 AM posted to rec.aviation.piloting
Mike Isaksen
wrote ...
SMA diesel.
What's your issue? The only thing that jumps at me is the cowling rub on the
prop hub extender. Could be the cowling or the engine mount is shifting in
flight at different rates. I would go back to the airframe
engineer/designer.
Old April 1st 08, 05:02 PM posted to rec.aviation.piloting
On Apr 1, 3:59 am, "Mike Isaksen" wrote:
wrote ...
SMA diesel.
engineer/designer.
The Gouges in the prop hub are deep!
Interesting that they say "Damage" is not a problem?
From SMA,
I confirm that this damage is probably due to a contact with the lower
cowling (there should be a mark on the cowling).
The cowlings have a tendency to drift upwards during flight and come
into contact with the propeller hub because of soft shock mounts.
We are currently certifying new shock mounts that will be less
flexible and less sensitive to aerodynamic efforts submitted to the
cowlings.
As specified by MTPropeller, the damage is not a problem.
Best regards,
Cyrille DEAU
SMA (Société de Motorisations Aéronautiques)
SAFRAN GROUP
Customer Services
Tél. +33 (0)2 48 48 05 31
Fax +33 (0)2 48 50 01 41
SMA Bourges- Aéroport
10-12 rue Didier Daurat
F- 18000 BOURGES
Old April 2nd 08, 05:42 PM posted to rec.aviation.piloting
wrote ...
SMA diesel.
engineer/designer.
From SMA,
cowlings.
Best regards,
Cyrille DEAU
SAFRAN GROUP
Customer Services
Tél.+33 (0)2 48 48 05 31
F- 18000 BOURGES
Better Photo of prop Hub damage..
wrote ...
SMA diesel.
engineer/designer.
From SMA,
cowlings.
Best regards,
Cyrille DEAU
SAFRAN GROUP
Customer Services
F- 18000 BOURGES
Better Photo Of Prop Hub Damage.
http://www.internationalferryflights...%20hub%202.jpg
Old April 4th 08, 12:58 AM posted to rec.aviation.piloting
wrote ...
SMA diesel.
engineer/designer.
From SMA,
cowlings.
Best regards,
Cyrille DEAU
SAFRAN GROUP
Customer Services
F- 18000 BOURGES
http://www.internationalferryflights...Folder%202...- Hide quoted text -
- Show quoted text -
Thats just downright scary. !!!!!!!!!!!!!!!!!!!!!!!
Ben
Old April 4th 08, 03:40 AM posted to rec.aviation.piloting
wrote ...
SMA diesel.
http://www.internationalferryflights.../PIC-0078..jpg
http://www.internationalferryflights.../PIC-0079..jpg
engineer/designer.
From SMA,
cowlings.
Best regards,
Cyrille DEAU
SAFRAN GROUP
Customer Services
F- 18000 BOURGES
http://www.internationalferryflights...der%202...Hide quoted text -
Ben
Ok, found out prop was on another airplane where damage was done then
prop was placed on this airplane. No inspection was noted in log books
of damage etc for return to service.
Old April 3rd 08, 05:46 PM posted to rec.aviation.piloting
On Apr 3, 9:11 am, The Visitor
Have you ever said "no" to certain aircraft?
John
SMA diesel.
You Bet... I do
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
GNS 530... Any experts? [email protected] Piloting 7 August 30th 06 04:38 PM
Any P51 experts out here? Dudley Henriques Naval Aviation 18 February 15th 05 08:27 AM
Are There Any P-47 Experts Out There Too? Schlomo Lipchitz Naval Aviation 10 February 15th 05 03:06 AM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 05:54 PM
