injected planes, no more owner oil changes, contact AOPA
Old April 1st 08, 06:04 PM posted to rec.aviation.piloting
Robert M. Gary
Default injected planes, no more owner oil changes, contact AOPA
AD 2008-06-51 prohibits injected (mostly Lycoming) aircraft owners
from changing their own oil (really makes the plane unairworthy after
an oil change until you get an A&P sign off).
Talking to AOPA about this I really don't get the impression that they
think this is very important. I would encourage everyone to send a
quick email to AOPA and let them know that the FAA needs to find
another way to do this AD other than restricting oil changes.
-Robert
Old April 1st 08, 08:18 PM posted to rec.aviation.piloting
Jim Burns[_2_]
Huh? The way I read that AD, it has nothing to do with oil changes. The
repetitive inspection portion of it will be a PITA, which states :
At every engine oil change or within every 50 hours of engine run time,
whichever occurs
first, repeat the inspection and remedial steps specified in paragraphs (f)
through (h)(9) of this AD.
It in no way makes oil changes by the owner prohibited. If you have other
info, please post it.
-Robert
Old April 1st 08, 08:34 PM posted to rec.aviation.piloting
Jim Burns[_2_]
As a side note, if you obtain a new updated gasket for the servo plug, your
A&P can install it and eliminated the repetitive portion of that AD.
-Robert
Old April 1st 08, 08:57 PM posted to rec.aviation.piloting
Robert M. Gary
On Apr 1, 12:18*pm, "Jim Burns" wrote:
Huh? *The way I read that AD, it has nothing to do with oil changes. *The
whichever occurs
It in no way makes oil changes by the owner prohibited. *If you have other
The AD says "At every oil change...". There for when you go out to
your plane to change the oil you can no longer fly it and must wait to
schedule an A&P to sign the AD. Draining the oil makes the plane
unairworthy.
-Robert
Old April 1st 08, 08:59 PM posted to rec.aviation.piloting
Robert M. Gary
Legally, the A&P can do it. However, there are two issues with this...
1) The fuel shops say retorquing the nut requires a new flow test. The
torque on the nut affects flows. They recommend never allowing an A&P
to touch the servo.
2) The safety wire used on the nut has "tamper evident" attachment. If
the A&P cuts the wire there is no warranty on the servo.
On the Mooney its a major buger of a job to R&R the servo.
-Robert
Old April 1st 08, 10:21 PM posted to rec.aviation.piloting
Peter Clark
On Tue, 1 Apr 2008 10:04:55 -0700 (PDT), "Robert M. Gary"
The only thing that AD does is require an inspection of a fuel servo
plug for security. It takes 10 minutes (most of which is getting at
the thing, which if you've already gotten it open for the oil change
makes it take 5 seconds) and if you can't get the nearest mechanic to
sign an entry saying that they complied with the job then you're not
doing something right. It doesn't stop you from changing your oil in
any way, shape, or form.
Old April 1st 08, 10:22 PM posted to rec.aviation.piloting
Peter Clark
Is there a new version of the AD? I don't see anything in there under
alternative methods of compliance showing a method other than the
inspection to comply.
On Tue, 1 Apr 2008 13:34:14 -0600, "Jim Burns"
-Robert
Old April 1st 08, 10:46 PM posted to rec.aviation.piloting
Jim Burns[_2_]
http://www.precisionairmotive.com/Pu...107%20Rev2.pdf
Gives warranty info, including a $100 offer to have the work performed.
Precision's website has a warranty claim form.
No mention of a flow test being required or recommended, but I don't doubt
that your fuel shop would recommend it, certainly can't hurt.
The plug serves as a cover to the internal mixture adjustment mechanism of
the servo, however, the gasket under the plug also seals the plug hole which
is on the "air" side of the servo. If the plug does not seal, it can suck
air and the mixture will be leaner than desired, however, it seems Precision
feels that an A&P is more than qualified to replace the gasket.
your
to touch the servo.
-Robert
Old April 1st 08, 11:07 PM posted to rec.aviation.piloting
Robert M. Gary
On Apr 1, 2:21*pm, Peter Clark
*It takes 10 minutes (most of which is getting at
doing something right. *It doesn't stop you from changing your oil in
A couple things you probably have not considered...
1) Before this AD I could change my oil on the weekend or earily AM
before work (which is when I usually do it), now you have to
coordinate the time when the shop is open (take the AM off work)
2) No A&P is going to bill you for 5 minutes. You'll be billed at
least 30 minutes, meaning you might as well have the A&P change the
oil. The benefit of changing your own oil is gone.
If you don't see the above points as a lose in ability/freedom then I
can't help you. If the AD had something to do with oil I would be ok
with it but it doesn't. Making the aircraft unairworthy because the
pilot changed the oil doesn't in anyway make the AD any more
effective.
-Robert
Old April 1st 08, 11:31 PM posted to rec.aviation.piloting
Jim Burns
The AD is specific to a specific part numbered gasket. The Precision SB
indicates a new gasket that, if installed, eliminates this AD.
"Peter Clark" wrote in message
your
-Robert
A week ago I became a new co-owner bdl Owning 16 April 9th 05 12:37 AM
172RG are any injected or are all carburated? Daniel L. Lieberman Piloting 2 September 30th 04 02:06 AM
Corporation or LLC as Owner? robin Owning 1 March 26th 04 01:05 AM
Fuel-Injected Continental O-200 Calvin R. Walker Home Built 1 November 22nd 03 02:50 PM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
