Junkers Ju86R-1 high altitude recce aircraft
Old January 24th 04, 12:10 PM
Dave Eadsforth
Default Junkers Ju86R-1 high altitude recce aircraft
Good day, good people,
I wondered if anyone might be able to help with a couple of questions on
the Junkers Ju86R-1 high altitude reconnaissance aircraft that was in
service between 1943 and 1944?
I have a reference that states that these were operated by a Luftwaffe
unit called the 1./Versuchsverband Ob.d.L. Can anyone tell me in which
theatre this unit operated, and if at all possible, which base(s)?
Is there any (accessible) record of the operations they carried out?
Also, the Ju86P that preceded the Ju86R-1 was given a single rear-firing
machine gun after the first ones were shot down by specially prepped
Spitfire Vs. (It didn't help!) Was the Ju86R-1 given any defensive
armament?
There was also the Ju86R-2, which was a bomber version; did that have
any defensive armament?
Thanks very much!
Cheers,
Dave
Dave Eadsforth
Old January 24th 04, 05:07 PM
robert arndt
Dave Eadsforth wrote in message ...
Forty Ju-86Ps were delivered to Versuchsverband Ob.d.l.,
2.(F)/Aufkl.Gr.33, and Kommando Rowehl in 1940. Most were P-2 recon
a/c but there were also P-1 bomber aircraft. The P-2 was unarmed at
first but the P-2 could carry four SC250 bombs. It was used in the
same recon role but also performed bombing missions on occasion. The
aircraft operated over England as a nuisance raider before being used
to take photos of the Soviet Union prior to the invasion of June 1941.
When the Ju-86R became available in 1941 it was used again against
southern England until by September 1942 the Spitfire IX was able to
reach it. After that, the a/c operated mostly on the eastern and
southern fronts.
I haven't seen any...
armament?
Not that I can see from the photographic record; however, if a single
MG was mounted it most likely was in a dorsal position... the dustbin
mount having ben removed and no photos of a nose gun. I'll look around
to see if I can find a pic with armament.
Probably not, just the four SC250 bombs as in the P-version. The
bombers were only used "on occassion"...
Thanks very much!
Cheers,
Dave
Rob
Old January 24th 04, 11:36 PM
Dave Eadsforth
In article , robert
arndt writes
Dave Eadsforth wrote in message news:$P6suhAzKlEAFwML
southern fronts.
armament?
Thanks very much!
Cheers,
Dave
Rob
Hi Rob,
Thanks very much for all that - very much appreciated!
Cheers,
Dave
Dave Eadsforth
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
