My Rotax 912 has begun to stumble intermittently at low and high power
settings. I believe that I isolated the stumbling problem to the left ignition system and removed the double ignition coils, wires and boots. I checked everything for proper resistances according to the Rotax manual. Everything checked out fine. I did install a fresh set of spark plugs at this time. I should add that I was getting erratic indications on my tach. I did find that my tach lead from its trigger coil had a bad crimp connector which I replaced and solved that problem. Upon reinstallation of the left ignition system, I began to experience starting problems. My normal start up procedure utilizes the choke to enrichen the mixture (I have no primer), with the throttle completely closed. After a couple of blades, the engine will normally catch and I'll slowly add throttle and simultaneously close the choke for a smooth and reliable engine start. Now, whenever I attempt to add throttle or close the choke or both, the engine immediately dies. I checked the integrity of the "slider" diaphrams on the Bings to make sure there was not an artificial leaning condition. The rubber "couplers" to the intake manifold appear to be in good shape, so I would not anticipate any vacuum leaks there. Any suggestions would be greatly appreciated. Tom |
electronic ignition | Philippe Vessaire | Home Built | 0 | September 21st 07 03:50 PM |
Hot Spark Ignition | Larry Smith | Home Built | 26 | November 19th 03 08:24 PM |
WTB: Ignition terminals | Juan E Jimenez | Aviation Marketplace | 0 | September 28th 03 06:18 AM |
DIY ignition shielding? | Michael Horowitz | Home Built | 3 | September 11th 03 04:28 AM |
Electronic Ignition | Andre | Home Built | 1 | September 5th 03 06:15 PM |
