Hi,
a friend and I are unable to identify the WW2-era aircraft on this photo (no caption or context available): http://www.designation-systems.net/mystery.jpg We think that the aircraft (obviously a glider) is connected to the U.S. Navy's GLOMB ("Glider Bomb") program for remotely controlled gliders used as surface-attack missiles. Several types of gliders were used in this program, some (heavily??) modified from existing types, others newly-designed. Unfortunately, the information on GLOMB in out sources is incomplete and partially inconsistent, and we couldn't come up with a really plausible ID for the aircraft. So, any input would be much appreciated. Perhaps someone has that same photo _with_ a caption ;-). Thanks in advance! Andreas |
In article , Andreas Parsch
wrote: http://www.designation-systems.net/mystery.jpg No glider bomb there! The a/c pictured is a training glider, used to train glider pilots. Several types of training gliders were improvised from light planes, where the engine was removed and a seat/controls substituted. The plane pictured is not a Cub or Aeronca or T-craft -- maybe a Commonwealth? |
Orval Fairbairn wrote:
No glider bomb there! The a/c pictured is a training glider, used to train glider pilots. Several types of training gliders were improvised from light planes, where the engine was removed and a seat/controls substituted. That's entirely correct, but doesn't necessarily contradict the Glomb idea. The USN used several of these gliders in modified form for the Glomb test program. Documented types are the XLNT-1 (Taylorcraft TG-6), XLNP-1 (Piper TG-8), XLNR-1 (Aeronca TG-5) and XLRW-1 (Waco CG-4A). I don't know much details about the extent of the airframe modifications, but the XLNT-1 (and probably others as well) was modified with a tricycle gear. The plane pictured is not a Cub or Aeronca or T-craft -- Indeed, and that's exactly the problem ;-). Although the aircraft _superficially_ looks like, say, an XLNT-1/TG-6 modified with a tricycle landing gear, it isn't (unless major parts of the rest of the airframe were rebuilt as well). maybe a Commonwealth? I don't think any Commonwealth aircraft were used by the USAAF and/or USN. Do you think of a specific type? Andreas |
wrote: Hi, a friend and I are unable to identify the WW2-era aircraft on this photo (no caption or context available): http://www.designation-systems.net/mystery.jpg We think that the aircraft (obviously a glider) is connected to the U.S. Navy's GLOMB ("Glider Bomb") program for remotely controlled gliders used as surface-attack missiles. Several types of gliders were used in this program, some (heavily??) modified from existing types, others newly-designed. Unfortunately, the information on GLOMB in out sources is incomplete and partially inconsistent, and we couldn't come up with a really plausible ID for the aircraft. Possibly an LNT-2. I Google search for Glomb turned up this one little tidbit...couldn't find a photo. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
![]() "Andreas Parsch" wrote in message ... Hi, a friend and I are unable to identify the WW2-era aircraft on this photo (no caption or context available): http://www.designation-systems.net/mystery.jpg We think that the aircraft (obviously a glider) is connected to the U.S. Navy's GLOMB ("Glider Bomb") program for remotely controlled gliders used as surface-attack missiles. Several types of gliders were used in this program, some (heavily??) modified from existing types, others newly-designed. Unfortunately, the information on GLOMB in out sources is incomplete and partially inconsistent, and we couldn't come up with a really plausible ID for the aircraft. Andreas, the thing appears to resemble the Taylorcraft XTG-5 training glider, albeit with a tricycle undercarriage. See: http://www.ww2gp.org/training.htm. The Navy/Marine Corps had a similar aircraft (the LNR-1, also LNT-1), which is referenced at http://www.aero-web.org/specs/taylorcr/xlnt-1.htm, but no picture was available. Note that Taylorcraft did manufacture the LBT-1 GLOMB (http://www.history.navy.mil/avh-1910/APP21.PDF). Forgive me if you already knew all of this... Brooks So, any input would be much appreciated. Perhaps someone has that same photo _with_ a caption ;-). Thanks in advance! Andreas |
Kevin Brooks wrote:
Andreas, the thing appears to resemble the Taylorcraft XTG-5 training glider, albeit with a tricycle undercarriage. "appears to resemble" is exactly the problem here ;-) (see also my other reply on this thread), because at a closer look, it differs in all essential details. Most notably the tailplane and wing strut arrangement, which would most likely remain essentially unmodified in a landing gear modification. See: http://www.ww2gp.org/training.htm. The Navy/Marine Corps had a similar aircraft (the LNR-1, also LNT-1), which is referenced at http://www.aero-web.org/specs/taylorcr/xlnt-1.htm, but no picture was available. Note that Taylorcraft did manufacture the LBT-1 GLOMB (http://www.history.navy.mil/avh-1910/APP21.PDF). Forgive me if you already knew all of this... I did, but no problem at all - if the a/c isn't immediately identified, it show at least that I was not completely blind :-). Andreas |
"Kevin Brooks" wrote in message ...
"Andreas Parsch" wrote in message ... Hi, a friend and I are unable to identify the WW2-era aircraft on this photo (no caption or context available): http://www.designation-systems.net/mystery.jpg Similar to a TG-6A training glider: http://www.pointvista.com/WW2GliderP...TG6caption.jpg Rob |
![]() "Andreas Parsch" wrote in message ... Hi, a friend and I are unable to identify the WW2-era aircraft on this photo (no caption or context available): http://www.designation-systems.net/mystery.jpg We think that the aircraft (obviously a glider) is connected to the U.S. Navy's GLOMB ("Glider Bomb") program for remotely controlled gliders used as surface-attack missiles. Several types of gliders were used in this program, some (heavily??) modified from existing types, others newly-designed. Unfortunately, the information on GLOMB in out sources is incomplete and partially inconsistent, and we couldn't come up with a really plausible ID for the aircraft. Doesn't look like that one would be a contender for the job: appears to be a two-three man trainer, not near enough pay load to make it worth while I would think; remote control gear would probably account for a quarter to half that thing's pay load. As to IDing it, I don't know. General appearance reminds me of a Taylorcraft or Aeronca. The armed forces bought up a bunch of gliders owned by individuals -even to include home mades- and you could spend a long time tracking down a minor variation of a home build. The Navy glider program was generally tacked on to the Army's so look there too. So, any input would be much appreciated. Perhaps someone has that same photo _with_ a caption ;-). Thanks in advance! Andreas |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
