PIK-20 Ballast Fill Fitting
Old April 26th 08, 01:23 AM posted to rec.aviation.soaring
Glen Kelley
Default PIK-20 Ballast Fill Fitting
Folks, could anyone tell me what the part number/description is for the
fitting that screws into the bottom of the PIK-20 ballast dump tube for
filling. My PIK's ballast system appears to be in good repair but I can't
seem to find what fitting to use. I'm sure it is some kind of metric
fitting w/25mm or so threads?
Thanks.
Glen Kelley PIK-20 "HL"
Old April 26th 08, 07:03 AM posted to rec.aviation.soaring
Geoff Vincent
On my PIK 20B the fill tube thread fitting is 3/4 inch water pipe. I
use the plastic garden hose fittings with the internal bore drilled
out to provide a slightly greater water flow. These screw-in fittings
then accept the push-on hose fittings that connect to 1/2 inch bore
hose. All very cheap, convenient and readily available, at least in
Australia.
Regards,
Geoff Vincent
Grampians Soaring Club
Sat, 26 Apr 2008 00:23:28 GMT, "Glen Kelley"
Thanks.
Brass Compression Fitting Brass Thread Fitting Sale on good price valvetom Piloting 0 November 28th 06 02:26 AM
$640.00 to fill the tanks... Jay Honeck Piloting 304 August 29th 06 02:16 PM
$640.00 to fill the tanks... Jay Honeck Piloting 53 August 21st 06 07:22 PM
New Orleans, fill it with dirt Doug Piloting 18 September 2nd 05 01:52 AM
How to fill out a logbook. Scott Soaring 3 February 8th 04 05:41 PM
