LS3a Airbrake question
Old April 28th 08, 09:45 AM posted to rec.aviation.soaring
Default LS3a Airbrake question
I have a problem with my LS3a. During flight, from 90 km/h, on both
wings the airbrakes comming out from the wings slightly (some
millimeters), a little bit higher during ircling flight, during pull-
up and at higher g-loads.
Yesterday I have tried the following during flight:
I have pulled the airbrake handle very slowly back from closed and
locked position untill to the point that I felt resistance and looked
the airbrake covercaps on the wings.
It was interesting that fulling back the airbrake handle 5-I0 mm the
airbrake covercaps went back on both wings to their good positionthe.
I think it means that the over-center (self-closing) is not correct.
Does it mean that the ocer-center is incorrect ? Is there any way to
set the over-center ?
Old April 28th 08, 01:36 PM posted to rec.aviation.soaring
JJ Sinclair
It sounds like your spoilers aren't set correctly. They should fully
seat and then pull down on the little springs (under the spoiler cap)
about 1mm or about one dime width. You can check this by pulling up on
the spoiler cap and sliding in a dime. Do this at 4 places along the
spoiler. Then close and lock the spoiler. Now look at the closed
cap.............if it is sticking up anywhere, it did NOT pull down
the required 1mm (dime width). Adjust the linkage, probably at the
spoiler box to make the spoiler pull down more. This adjustment is
made on the rod that goes from the over-center mechanism to the
spoiler, NOT on the rod going TO the over-center mechanism.
JJ
Oh, yeah, remove the dimes from your spoiler box :)
Old April 28th 08, 02:03 PM posted to rec.aviation.soaring
Andy[_1_]
If, as the OP suggests, if the over center mechanism is not set
correctly the spoiler caps may pull down the correct amount and then
relax as the linkage goes further over center.
I had a discussion with Waibel about the airbrakes on my ASW-28. Mine
go much further over center than the factory specs say they should.
The solution is to shim the pad where the over center bell crank
contacts the spoiler box. To find out how much over center there is
at the current adjustment you can put temporary shims on the pads.
Slowly increase the thickness of the temporary shims until the
airbrakes just stay locked. Then remove the temporary shims, measure
them, subtract the factory spec over center measurement, and fix
appropriate thickness shims in place. I used aluminum shims
sandwiched with double sided tape for the temporary shim stack.
I am not familiar with the LS linkage so the specifics for changing
the over center adjustment may be different. However, all over center
mechanisms must use an over center stop and the position of the stop
controls the amount the mechanism relaxes after passing the over
center point.
You will need to know how much over center is required. Reduce it too
much and the airbrakes will come unlocked in flight.
Andy
Old April 28th 08, 05:20 PM posted to rec.aviation.soaring
Thanks for your answer, unfortunately I do not understand fully you:
"Then close and lock the spoiler. Now look at the closed
the required 1mm (dime width). "
It would be nice to discuss it with you off-line, I have a drawing
about the airbrake mechanism from LS, I could send it you.
Old April 28th 08, 05:27 PM posted to rec.aviation.soaring
Sorry, I forgot to mention my email:
Old April 29th 08, 03:10 AM posted to rec.aviation.soaring
JJ Sinclair
Recommend you take your LS-3 to a mechanic that understands
sailplanes. Probably not a good idea for unskilled hands to be
adjusting the spoiler caps or over-center stops. Copy the responses
you got, it may help with the adjustment process.
Cheers,
JJ
Wanted: LS3A or LS3A-17 (USA) Uniform Zulu Soaring 1 November 21st 07 07:36 PM
LS3A performance Rob Dunning Soaring 7 July 7th 07 03:38 PM
airbrake position while tied outside CK Soaring 18 January 19th 04 02:34 PM
FS - LS3a Simon Waddell Soaring 0 January 17th 04 04:05 PM
airbrake question miso Military Aviation 17 December 4th 03 04:27 AM
