LS-4a
Old May 6th 08, 04:08 AM posted to rec.aviation.soaring
Default LS-4a
I completed a weight and balance on my LS-4 and want to put
additional weight in the rear. The weight and balance included the
5.5 lb battery that is in the tail. Anyone have any advice or
experience?
Don (CX)
Old May 6th 08, 04:56 AM posted to rec.aviation.soaring
Adam
Default LS-4a
experience?
Don (CX)
My tailwheel is filled with lead. Works fine for me.
There are brass wheels available commercially from Tost (2kg with
tire)
http://www.wingsandwheels.com/page32.htm
I may also make some molded lead weights and glass them in at the top
of the stab. Or lose some body mass...
/Adam
Old May 6th 08, 05:09 AM posted to rec.aviation.soaring
noel.wade
Default LS-4a
experience?
Don (CX)
tire)http://www.wingsandwheels.com/page32.htm
/Adam
Top of the stab? I'd check with an authority before installing
something like that - the bending moment you could put on the vertical
stab and the twisting force you're applying to the tail-boom with that
arrangement might not be within the designed limits/loads of the
manufacturer (think about what happens with that weight when you roll
the aircraft). I'm not a manufacturer so I can't say for sure, but I
would think the base of the vertical stab / tail-boom would be a much
better place to put it. *shrug*
--Noel
Default LS-4a
experience?
Don (CX)
/Adam
Don't know exactly what you mean by "glass" them in? I see the brass
wheel - a little pricey. Do you mean that you put lead in the actual
wheel? I hear that replacing the tail battery with more than the
original 5.5 lbs is risky?
Don
Old May 6th 08, 05:34 AM posted to rec.aviation.soaring
BT
Default LS-4a
Don our LS 4 has lead added above the tail wheel just forward of the
rudder.You have to remove the rudder to get it out.
BT
experience?
Don (CX)
/Adam
Don
Old May 6th 08, 02:07 PM posted to rec.aviation.soaring
JJ Sinclair
Default LS-4a
Noel makes a good point on keeping any added weight as low as
possible. Think about what your tail will experience in a ground-
loop........a large twisting moment, the higher the added weight, the
more twisting.........pretty soon you will twist the tail right off. I
believe the LS-4 has a provision to add tail weight on the lower
rudder hinge bracket, I know the LS-6/7/8 has this. All weight MUST be
secured, as in bolted or glassed in. If you pour in lead shot, the
resin should be thickened with micro-balloons and even then the resin
will tend to pool at the bottom. Adding more resin after the first has
cured and a layer of cloth over the lead shot will keep everything in
place.
Hope this helps,
JJ
experience?
Don (CX)
/Adam
--Noel
Old May 6th 08, 03:06 PM posted to rec.aviation.soaring
Bob Salvo
Default LS-4a
Placing a groove in the middle of the lead weight allows its
installation/removal without having to remove the rudder. (Just place the
rudder in its neutral position so that its tab/seam lines up with the
groove.)
Bob
"BT" wrote in message
BT
Old May 6th 08, 03:11 PM posted to rec.aviation.soaring
Adam
Default LS-4a
I completed *a weight and balance on my LS-4 and *want to put
additional weight in the rear. *The weight and balance included the
5.5 lb battery that is in the tail. *Anyone have any advice or
experience?
Don (CX)
/Adam
Top of the stab? *I'd check with an authority before installing
the aircraft). *I'm not a manufacturer so I can't say for sure, but I
better place to put it. **shrug*
--Noel- Hide quoted text -
- Show quoted text -
In my case the sailplane is a Jantar Standard 2. Indeed it is better
to put it as close to the boom axis as possible. As far as real world
experience, the Brazilians have been putting as much as 8 pounds of
lead at the top of the stab on their fleet of Jantars for 20 years
with no ill effect. They also place lead strips on a fin rib accecible
when the rudder is removed. And some have 3 liter water tanks
installed.
In the case of my tailwheel, molten lead was simply poured in the rim
recesses on both sides. No epoxy/lead shot was used.
/Adam
Old May 6th 08, 07:11 PM posted to rec.aviation.soaring
Ramy
Default LS-4a
place.
Hope this helps,
JJ
experience?
Don (CX)
/Adam
I flew years with 3 pounds of lead shot secured in a bag at the top of
the vertical fin above the battery cover (removed the black foam to
make more space). My local authority was ok with that and I never had
a problem, but also never ground looped.
Ramy
Old May 6th 08, 11:24 PM posted to rec.aviation.soaring
noel.wade
Default LS-4a
Ramy
The bottom line is that cantilevering that kind of weight on the top
of the tail is just not something that the aircraft designers and
engineers anticipated. The structure wasn't designed for it - so just
because it has worked doesn't mean that it won't fail in the future,
or that it works on all gliders.
Disregarding structure, there are performance reasons to keep the mass
concentrated down in the fuselage. The closer to the center of
rotation that you place some mass, the less force it takes to put that
mass into motion.
Here's a thought-experiment: Imagine rolling the aircraft. Imagine
looking at the airplane from behind as it executes a perfect aileron
roll. If you put the weight down low in the tail-boom, the rest of
the tail rotates *around* that mass and it doesn't have to travel very
far or move very fast. If it was way out at the tip of the tail, it
would move through a much bigger circle over the same time period.
That means it travels farther and has to move faster. It takes energy
to start and stop the movement of that mass.
In short: Handling is going to be less crisp and it will be harder to
make subtle attitude corrections with a bunch of mass out at the tip
of the tail (or the tip of a wing, or any extreme end of the glider).
Take care,
--Noel
