I'm trying to use LXasBrowser.exe (from LX Nav's web site) to load
existing airspace file(s) (OpenAir(TM), Tim Newport-Peace, etc) and export them to SeeYou binary (.cub) files. The documentation and help files for the software are not helping. I'm able to load the existing airspace files but when I try to export to a .cub file it gives an error saying that no region is defined ("Region is empty!"). My LXASBrowser version is 2.2.0.10, Apr 16 2008. -ted/2NO |
Hi Ted,
Give me a call and I can walk you through the process. It is not well documented but it is not tough when you know how. But it is tough to describe in an e-mail. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Tuno" wrote in message ... I'm trying to use LXasBrowser.exe (from LX Nav's web site) to load existing airspace file(s) (OpenAir(TM), Tim Newport-Peace, etc) and export them to SeeYou binary (.cub) files. The documentation and help files for the software are not helping. I'm able to load the existing airspace files but when I try to export to a .cub file it gives an error saying that no region is defined ("Region is empty!"). My LXASBrowser version is 2.2.0.10, Apr 16 2008. -ted/2NO |
Thanks Paul. Left you a voicemail
![]() Replying here for the benefit of anyone following -- the trick to getting a region defined, I discovered, is to hold down the Ctrl key while using the left mouse to click and drag a rectangle on the map display (which must be brought up using the red "AS" button). Right- clicking on the map and selecting "Regions" brings up a dialog in which you can give the newly defined region a name and add it to the internal region list. After loading the exported .CUB files in SeeYou, I further discovered that the Tim Newport-Peace (.sua) file format is not a friendly source for LXasBrowser -- almost all of the controlled airspace regions came up with incorrect class names! ("Class A" for the Tucson Class C, e.g.) (Tim, Crtomir, any clues?) Using the OpenAir(TM) (.txt) format worked fine, however. The procedure I was looking for in my OP goes like this: 1) Run LXasBrowser.exe and click File | New Workspace. 2) Click File | Open and load your source file (for me, that's one of the OpenAir files from justsoar.com). 3) Click on the "New Data" button in the toolbar below the main menu. 4) Click on the red "AS" button to view the airspace and set or create the region to use (as described above). 5) In the main LXasBrowser window, click on Transform | To CUB. In the Airspace Info dialog that comes up, specify the name that will be shown in the LX instrument and click Ok. 6) Specify a disk file name (.CUB) and click Save. You're done (except for getting it into the instrument without letting any of the smoke out, of course). ~ted/2NO |
| Thread Tools | |
| Display Modes | |
