prepreg fiberglass question
Old May 12th 08, 05:56 AM posted to rec.aviation.homebuilt
Andrew Sarangan
Default prepreg fiberglass question
I've heard of prepregs which have the resin and hardener separated
within the fabric, which can be activated by applying pressure with a
squeegee or similar tool. I searched the internet but I can only find
the standard premixed prepregs which need to be kept in a refrigerator
and cured at elevated temperatures. Anyone know what I am talking
about or where I can buy this thing?
I am basically looking for a way to avoid having to hand make long
lengths of fiberglass tapes for noncritical applications. But it has
to cure fast at room temperature like any standard epoxy so the
premixed ones won't work.
Thanks!
Old May 12th 08, 02:58 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Thanks!
Prepregs are literally pre-impregnated with catalyzed resin.
They are kept from hardening by being kept at low temperature.
It has nothing to do with pressure - certainty not from
something as flimsy as a squeegee.
Sounds like you need to hit the books.
There are LOTS of tehm.
Try Amazon?
Richard
(remove the X to email)
Old May 12th 08, 03:05 PM posted to rec.aviation.homebuilt
Andrew Sarangan
Thanks!
Try Amazon?
Richard
I am very familiar with the standard prepregs and how to work with
them (as I indicated on the original post). But the type I am thinking
of is an unusual type. It has the resin and hardener separated by a
thin membrane inside the glass, and when you squeeze it hard the
membrane ruptures and mixes the two components (I think the color
also changes to indicate proper mixing). If you have a reference or
vendor for this item, I would appreciate any info.
Old May 12th 08, 03:28 PM posted to rec.aviation.homebuilt
Thanks!
Try Amazon?
Richard
Sorry, Andrew, never heard of them in private hands,
Richard
Now just why the HELL do I have to press 1 for English?
John Wayne
Old May 12th 08, 04:28 PM posted to rec.aviation.homebuilt
BobR
*I've heard of prepregs which have the resin and hardener separated
Thanks!
Try Amazon?
Richard
membrane ruptures and mixes the two components *(I think the color
vendor for this item, I would appreciate any info.- Hide quoted text -
- Show quoted text -
I have seen what you are discussing in a clay like form but never in
an impregnated glass. The concept sounds great but I can't see how
you would ever achieve a good and consistant mixture.
Old May 13th 08, 01:07 AM posted to rec.aviation.homebuilt
Bob Kuykendall
On May 11, 9:56*pm, Andrew Sarangan wrote:
...I am basically looking for a way to avoid having to hand make long
For that application I'd be inclined to consider pre-pregging chunks
of cloth with UV-curing vinylester, and sandwiching it between two
sheets of one-mil nylon sheet. Chuck it into a ziploc bag in a dark
cabinet. Then cut strips of tape off the edges and use them at need.
After applying, zap with UV light or just point at the sun.
Thanks, Bob K.
Old May 14th 08, 01:52 AM posted to rec.aviation.homebuilt
T.L. Davis
On Sun, 11 May 2008 21:56:48 -0700 (PDT), Andrew Sarangan
Thanks!
If this stuff doesn't exist, based on the responses, I would suggest
patenting the concept. Imagine a two (or greater) sandwich of S
glass, with encapsuated layers of resin and catalyst. The fabric is
draped over a male plug (permanent or removable). It is then vacuum
bagged. The compressive force of the vaccuum ruptures the
encapsulations and the binary system begins to mix. A vibrating or
centrifugal base could be used to acheive optimal mixing of the
components. What you could wind up with is a near perfect composite
structure,not dependent on squeegee force or perfect application of
squeegee pressure (impossible given time constraints and the stress
from time pressure).
If it does exist, I'd like to know how to obtain it also.
T.L. Davis
Old May 14th 08, 02:06 AM posted to rec.aviation.homebuilt
Maxwell[_2_]
"T.L. Davis" wrote in message
Thanks!
T.L. Davis
Something sensitive enough to be ruptured by a vacuum bag would be real
susceptible to handling damage. A single blem in a large panel could scrap a
lot of expensive material. The UV-curing vinylester would seem more user
friendly.
Fiberglass revisited Lou Home Built 3 October 31st 06 12:50 PM
Aluminized fiberglass Dan, U.S. Air Force, retired Home Built 2 May 3rd 05 08:35 AM
Fiberglass/gelcoat repair question Kilo Charlie Soaring 9 April 19th 05 03:30 PM
Help understanding how to work with prepreg Chris Home Built 4 April 1st 04 02:13 PM
Fiberglass Tip Tanks Question Jay Honeck Owning 7 September 26th 03 04:23 AM
