For some reason I can't reply to the old thread that discussed adding
new ratings to sport pilot without a flight test. The reply option is not available. Anyway... It seems FAA has had second thought on this and has issued an NPRM. Some of it reads as follows: "Currently, to obtain additional aircraft category and class privileges at the sport pilot level, the holder of a pilot certificate must complete a proficiency check administered by an authorized instructor. Upon successful completion of that proficiency check, that person receives a logbook endorsement from the instructor who administered the proficiency check. That endorsement permits the person completing the proficiency check to exercise sport pilot privileges in the category and class of aircraft in which the proficiency check was administered. Consistent with the FAA’s system for issuing all other pilot certificates and ratings, the FAA is proposing to require a person seeking privileges to operate an additional category and class of lightsport aircraft as a sport pilot to obtain the appropriate category and class rating. These ratings would be issued after the completion of a practical test typically administered by an FAAdesignated pilot examiner (DPE). The practice of obtaining privileges to operate a light-sport aircraft after completion of a proficiency check by an authorized instructor would be discontinued. Privileges to operate lightsport aircraft would be indicated as ratings on a person’s pilot certificate rather than by an endorsement in a person’s logbook." Note the requirement for a flight test with an FAA designated examiner. (DPE) The full NPRM can be seen at http://edocket.access.gpo.gov/2008/pdf/08-1127.pdf Andy |
Andy.. that is standard for anyone moving from a glider rating to an
airplane rating. They are finally covering their tracks for the Sport Pilot level. BT "Andy" wrote in message ... For some reason I can't reply to the old thread that discussed adding new ratings to sport pilot without a flight test. The reply option is not available. Anyway... It seems FAA has had second thought on this and has issued an NPRM. Some of it reads as follows: "Currently, to obtain additional aircraft category and class privileges at the sport pilot level, the holder of a pilot certificate must complete a proficiency check administered by an authorized instructor. Upon successful completion of that proficiency check, that person receives a logbook endorsement from the instructor who administered the proficiency check. That endorsement permits the person completing the proficiency check to exercise sport pilot privileges in the category and class of aircraft in which the proficiency check was administered. Consistent with the FAA’s system for issuing all other pilot certificates and ratings, the FAA is proposing to require a person seeking privileges to operate an additional category and class of lightsport aircraft as a sport pilot to obtain the appropriate category and class rating. These ratings would be issued after the completion of a practical test typically administered by an FAAdesignated pilot examiner (DPE). The practice of obtaining privileges to operate a light-sport aircraft after completion of a proficiency check by an authorized instructor would be discontinued. Privileges to operate lightsport aircraft would be indicated as ratings on a person’s pilot certificate rather than by an endorsement in a person’s logbook." Note the requirement for a flight test with an FAA designated examiner. (DPE) The full NPRM can be seen at http://edocket.access.gpo.gov/2008/pdf/08-1127.pdf Andy |
On May 14, 7:14*pm, "BT" wrote:
Andy.. that is standard for anyone moving from a glider rating to an airplane rating. They are finally covering their tracks for the Sport Pilot level. BT The context of my post was perhaps not clear since I was unable to continue the original thread. I should have prefaced it by quoting my comment from the old thread: "I am certainly confused and surprised that an SP gliderpilot can get SP airplane without a knowledge or flight test since, as a pvt gliderpilot, I had to take both the knowledge and flight test to get private ASEL on my certificate." A search of this group for "sport airplane" will find the thread. Andy |
Andy, the "Reply" button is now at the bottom of the page
instead of the top. It appears this might be a gentle nudge to post replys below the message instead of at the top, as has been our standard practice. At 02:18 15 May 2008, Andy wrote: >For some reason I can't reply to the old thread that discussed adding >new ratings to sport pilot without a flight test. The reply option is >not available. Anyway... > >It seems FAA has had second thought on this and has issued an NPRM. >Some of it reads as follows: > >"Currently, to obtain additional aircraft >category and class privileges at the sport >pilot level, the holder of a pilot >certificate must complete a proficiency >check administered by an authorized >instructor. Upon successful completion >of that proficiency check, that person >receives a logbook endorsement from >the instructor who administered the >proficiency check. That endorsement >permits the person completing the >proficiency check to exercise sport pilot >privileges in the category and class of >aircraft in which the proficiency check >was administered. >Consistent with the FAA=92s system for >issuing all other pilot certificates and >ratings, the FAA is proposing to require >a person seeking privileges to operate an >additional category and class of lightsport >aircraft as a sport pilot to obtain >the appropriate category and class >rating. These ratings would be issued >after the completion of a practical test >typically administered by an FAAdesignated >pilot examiner (DPE). The >practice of obtaining privileges to >operate a light-sport aircraft after >completion of a proficiency check by an >authorized instructor would be >discontinued. Privileges to operate lightsport >aircraft would be indicated as >ratings on a person=92s pilot certificate >rather than by an endorsement in a >person=92s logbook." > >Note the requirement for a flight test with an FAA designated >examiner. (DPE) > >The full NPRM can be seen at >http://edocket.access.gpo.gov/2008/pdf/08-1127.pdf > >Andy > > |
Nyal-
Interesting that you should try to dictate convention when your posts are coming through with quotes so butchered that they are illegible. This is "Usenet", you are posting to, and has no reply buttons. Any buttons you see come from the software which you personally are using for posting and there are no rules as to where a person may put their reply. Only, "your" personal taste as to where you would like to see the reply. Clean up your own act before dictating to others how they should post. I am posting to the top in this instance, not to spite you, but so that you may see an example, below, as to how your posts are coming through a "normal" newsreader program for Usenet. Nyal Williams wrote: Andy, the "Reply" button is now at the bottom of the page instead of the top. It appears this might be a gentle nudge to post replys below the message instead of at the top, as has been our standard practice. At 02:18 15 May 2008, Andy wrote: >For some reason I can't reply to the old thread that discussed adding >new ratings to sport pilot without a flight test. The reply option is >not available. Anyway... > >It seems FAA has had second thought on this and has issued an NPRM. >Some of it reads as follows: > >"Currently, to obtain additional aircraft >category and class privileges at the sport >pilot level, the holder of a pilot >certificate must complete a proficiency >check administered by an authorized >instructor. Upon successful completion >of that proficiency check, that person >receives a logbook endorsement from >the instructor who administered the >proficiency check. That endorsement >permits the person completing the >proficiency check to exercise sport pilot >privileges in the category and class of >aircraft in which the proficiency check >was administered. >Consistent with the FAA=92s system for >issuing all other pilot certificates and >ratings, the FAA is proposing to require >a person seeking privileges to operate an >additional category and class of lightsport >aircraft as a sport pilot to obtain >the appropriate category and class >rating. These ratings would be issued >after the completion of a practical test >typically administered by an FAAdesignated >pilot examiner (DPE). The >practice of obtaining privileges to >operate a light-sport aircraft after >completion of a proficiency check by an >authorized instructor would be >discontinued. Privileges to operate lightsport >aircraft would be indicated as >ratings on a person=92s pilot certificate >rather than by an endorsement in a >person=92s logbook." > >Note the requirement for a flight test with an FAA designated >examiner. (DPE) > >The full NPRM can be seen at >http://edocket.access.gpo.gov/2008/pdf/08-1127.pdf > >Andy > > |
Nyal's Usenet reader is reading/posting in HTML format, he likely
doesn't see anything wrong, as the '>' sequences translate to '' and the '"' sequences translate to '"'. Nyal, check your settings and change the posting format to text, which is the Usenet standard... Marc Russ wrote: Nyal- Interesting that you should try to dictate convention when your posts are coming through with quotes so butchered that they are illegible. This is "Usenet", you are posting to, and has no reply buttons. Any buttons you see come from the software which you personally are using for posting and there are no rules as to where a person may put their reply. Only, "your" personal taste as to where you would like to see the reply. Clean up your own act before dictating to others how they should post. I am posting to the top in this instance, not to spite you, but so that you may see an example, below, as to how your posts are coming through a "normal" newsreader program for Usenet. Nyal Williams wrote: Andy, the "Reply" button is now at the bottom of the page instead of the top. It appears this might be a gentle nudge to post replys below the message instead of at the top, as has been our standard practice. At 02:18 15 May 2008, Andy wrote: >For some reason I can't reply to the old thread that discussed adding >new ratings to sport pilot without a flight test. The reply option is >not available. Anyway... > >It seems FAA has had second thought on this and has issued an NPRM. >Some of it reads as follows: > |
Russ, and others,
I have no interest in dictating convention; I merely observed what was the usual practice, recalled that there had been been some discussion and criticism of posting at top or bottom (probably two years ago) and surmised that moving the button to the bottom might have been a nudge. There are arguments for posting at top and at bottom and I take no position on this. I only wanted to point out that someone who needed a button for reply had overlooked it. Now, turns out that my reader needs adjusting and that not everyone sees what I see. I'm not all that savvy about internet communications. I'm using Thunderbird at someone else's suggestion and I'm not sure what to do to it. It was not my intent to influence practices or to ruffle feathers. Thanks, Marc Russ's post did not even show up on my list of downloaded messages. At 16:09 18 May 2008, Marc Ramsey wrote: >Nyal's Usenet reader is reading/posting in HTML format, he likely >doesn't see anything wrong, as the '>' sequences translate to '>' and >the '"' sequences translate to '"'. Nyal, check your settings and >change the posting format to text, which is the Usenet standard... > >Marc > >Russ wrote: >> Nyal- >> Interesting that you should try to dictate convention when your posts >> are coming through with quotes so butchered that they are illegible. >> This is "Usenet", you are posting to, and has no reply buttons. >> Any buttons you see come from the software which you personally are >> using for posting and there are no rules as to where a person may put >> their reply. Only, "your" personal taste as to where you would like to >> see the reply. >> >> Clean up your own act before dictating to others how they should post. >> >> I am posting to the top in this instance, not to spite you, but so that >> you may see an example, below, as to how your posts are coming through a >> "normal" newsreader program for Usenet. >> >> Nyal Williams wrote: >>> Andy, the "Reply" button is now at the bottom of the page >>> instead of the top. It appears this might be a gentle nudge to post >>> replys below the message instead of at the top, as has been our standard >>> practice. >>> >>> At 02:18 15 May 2008, Andy wrote: >>> >For some reason I can't reply to the old thread that discussed >>> adding >>> >new ratings to sport pilot without a flight test. The reply option is >>> >not available. Anyway... >>> > >>> >It seems FAA has had second thought on this and has issued an NPRM. >>> >Some of it reads as follows: >>> > > |
Ah, here's your post.
Russ, I tried to answer you privately by email but you have obscured your address. This came to me completely clean, unbutchered, uncluttered, and clear as a bell. I don't know what the problem is. Sorry! At 11:01 18 May 2008, Russ wrote: >Nyal- >Interesting that you should try to dictate convention when your posts >are coming through with quotes so butchered that they are illegible. >This is "Usenet", you are posting to, and has no reply buttons. >Any buttons you see come from the software which you personally are >using for posting and there are no rules as to where a person may put >their reply. Only, "your" personal taste as to where you would like to >see the reply. > >Clean up your own act before dictating to others how they should post. > >I am posting to the top in this instance, not to spite you, but so that >you may see an example, below, as to how your posts are coming through a >"normal" newsreader program for Usenet. > >Nyal Williams wrote: >> Andy, the "Reply" button is now at the bottom of the page >> instead of the top. It appears this might be a gentle nudge to post >> replys below the message instead of at the top, as has been our standard >> practice. >> >> At 02:18 15 May 2008, Andy wrote: >> >For some reason I can't reply to the old thread that discussed >> adding >> >new ratings to sport pilot without a flight test. The reply option is >> >not available. Anyway... >> > >> >It seems FAA has had second thought on this and has issued an NPRM. >> >Some of it reads as follows: >> > >> >"Currently, to obtain additional aircraft >> >category and class privileges at the sport >> >pilot level, the holder of a pilot >> >certificate must complete a proficiency >> >check administered by an authorized >> >instructor. Upon successful completion >> >of that proficiency check, that person >> >receives a logbook endorsement from >> >the instructor who administered the >> >proficiency check. That endorsement >> >permits the person completing the >> >proficiency check to exercise sport pilot >> >privileges in the category and class of >> >aircraft in which the proficiency check >> >was administered. >> >Consistent with the FAA=92s system for >> >issuing all other pilot certificates and >> >ratings, the FAA is proposing to require >> >a person seeking privileges to operate an >> >additional category and class of lightsport >> >aircraft as a sport pilot to obtain >> >the appropriate category and class >> >rating. These ratings would be issued >> >after the completion of a practical test >> >typically administered by an FAAdesignated >> >pilot examiner (DPE). The >> >practice of obtaining privileges to >> >operate a light-sport aircraft after >> >completion of a proficiency check by an >> >authorized instructor would be >> >discontinued. Privileges to operate lightsport >> >aircraft would be indicated as >> >ratings on a person=92s pilot certificate >> >rather than by an endorsement in a >> >person=92s logbook." >> > >> >Note the requirement for a flight test with an FAA designated >> >examiner. (DPE) >> > >> >The full NPRM can be seen at >> >http://edocket.access.gpo.gov/2008/pdf/08-1127.pdf >> > >> >Andy >> > >> > > |
Now, turns out that my reader needs adjusting and that not everyone sees what I see. I'm not all that savvy about internet communications. I'm using Thunderbird at someone else's suggestion and I'm not sure what to do to it. It looks like you may be posting via this web site: http://www.gliderpilot.net/ You might try contacting the webmaster for that site via the info in that site's contact page and point out the problem. Alternatively you could try posting via Google Groups: http://groups.google.com/group/rec.a.../topics?lnk=sg |
This came to me completely clean, unbutchered, uncluttered, and clear as a bell. I don't know what the problem is. Sorry! Nyal, Sorry about that, I realized after I posted the quote that your newsreader probably would clean the quote up the same as it munged it. I suspect, now, that it is a combination of html text and Gilderpilot.net, and Google news that your messages go through. It was a disastrous combination of the internet providers and some texting characters that prevent the message from being translated to plain text for a Usenet newsreader. http://tinyurl.com/5vlay4 This shortened link should take you to a Google Groups version of your Spoilers or Airbrakes message, which first set me off. It might give you a view of the munging of the text that made it unreadable. Your messages are fine as long as nothing is quoted. After trying to read the above message I falsely perceived, in your next message in the "Sport pilot from pvt glider" thread, that you were then directing Andy to follow a convention that was not followed in the spoiler/airbrake correction attempt. I am blaming my short fuse for it all, on the rainy weekend, here. Russ |
Adding an airplane rating to private pilot glider | gmcd05 | Soaring | 35 | April 25th 08 01:43 AM |
sport airplane from private glider | Andy[_1_] | Soaring | 5 | November 28th 07 01:29 AM |
Sport Pilot and Glider Questions | Ralph Steiner | Soaring | 17 | February 22nd 06 11:34 AM |
Light-Sport Aircraft / Sport Pilot group | gilan | Piloting | 0 | November 13th 05 04:53 PM |
Light-Sport Aircraft / Sport Pilot group | gilan | Owning | 0 | November 13th 05 04:53 PM |
