LS4 battery install
Old May 15th 08, 07:38 PM posted to rec.aviation.soaring
klie
Default LS4 battery install
I am looking to put a battery behind the seat, on the rear deck of an
LS-4. Any experience or advice?
Don K.
Old May 15th 08, 08:01 PM posted to rec.aviation.soaring
JS
In my old LS-4 (#4008) there were three hard points installed in the
luggage compartment for a Winter barograph.
You can bolt your battery box to them.
(Made mine out of glass, with a webbing strap to secure the battery.
The cable run was easy.)
Don K.
Old May 16th 08, 03:59 AM posted to rec.aviation.soaring
BT
that's where ours is.. as JS described
BT
"JS" wrote in message
Don K.
Old May 16th 08, 07:17 PM posted to rec.aviation.soaring
Papa3
LS-4. *Any experience or advice?
Don K.
In the LS-4 maintenance manual, there are specific instructions for
mounting a battery (or other equipment) on the luggage deck.
Briefly, it involves drilling up through the gear well and using a
bolt with spacers between the top of the gear well and the thin cover
over the well. There's an LS newsgroup on Yahoo Groups where you
might find someone who actually has a copy of the manual if you
don't.
Erik Mann
LS8-18 P3 (formerly LS4)
Can't install FSX Blue Simulators 6 November 22nd 06 09:42 PM
X52 install problems Gian Simulators 0 June 21st 05 07:47 AM
A-65 Baffles - when to install? Michael Horowitz Home Built 0 March 27th 05 06:26 PM
337 to install a transponder? Jay Honeck Owning 25 December 22nd 03 10:31 PM
Can I install on more than one computer? FCY-SAM Simulators 1 August 2nd 03 06:07 PM
