Look at the link for a picture of my manual aviation computer. It has two
different places to put in pressure altitude and temp to get density altitude and convert airspeeds. Can anyone explain the correct use of these two similar functions? http://flickr.com/photos/26467772@N05/2508589733/ |
On May 21, 4:55*am, "Danny Deger" wrote:
Look at the link for a picture of my manual aviation computer. *It has two different places to put in pressure altitude and temp to get density altitude and convert airspeeds. *Can anyone explain the correct use of these two similar functions? http://flickr.com/photos/26467772@N05/2508589733/ There is an instruction manual that comes with those things. Have you ever tried to read it? |
"Mr.Smartypants" wrote in message ... On May 21, 4:55 am, "Danny Deger" wrote: Look at the link for a picture of my manual aviation computer. It has two different places to put in pressure altitude and temp to get density altitude and convert airspeeds. Can anyone explain the correct use of these two similar functions? http://flickr.com/photos/26467772@N05/2508589733/ There is an instruction manual that comes with those things. Have you ever tried to read it? The one on the top/left is to correct indicated altitude to true altitude -- a function I have no use for. The one on the right is the one for density altitude/airspeed correction -- a very useful function. And mine didn't have a users manual. It was issued to me by the Air Force and I was given training on how to use it. I didn't keep all of my training material. Danny Deger Read my story, "Houston You Have a Problem" at www.dannydeger.blogspot.com |
On Tue, 20 May 2008 13:55:43 -0500, "Danny Deger"
wrote: Look at the link for a picture of my manual aviation computer. It has two different places to put in pressure altitude and temp to get density altitude and convert airspeeds. Can anyone explain the correct use of these two similar functions? http://flickr.com/photos/26467772@N05/2508589733/ Density altitude converts the current altitude to a "performance" altitude, based on temperature and pressure. For instance, if my local field (250 MSL) has the correct conditions to create a 1250 MSL density altitude, I would use the performance charts for 1250 ft. to predict my airplane's behavior and limits. Here is the calculation: http://en.wikipedia.org/wiki/Density_altitude The airspeed conversion is used to convert indicated airspeed to true airspeed by compensating for lower air density and temperature at altitude. http://en.wikipedia.org/wiki/True_airspeed The instructions for the unit in the photo are actually printed on it. Here's a link to a manual for a similar unit that may help better explain: http://www.asa2fly.com/files/support/E6B_Manual.pdf Some aircraft have such converters built into the airspeed indicator. http://en.wikipedia.org/wiki/Airspeed_indicator The top photo has an instrument with rings allowing the pilot to set the temperature and altitude, then the TAS is read from bottom of the outside ring. |
wrote: Look at the link for a picture of my manual aviation computer. It has two different places to put in pressure altitude and temp to get density altitude and convert airspeeds. Can anyone explain the correct use of these two similar functions? http://flickr.com/photos/26467772@N05/2508589733/ Way too simple---read the print on the disk beneath the input windows for each section--one place gives you density altitude as the product, the other gives you airspeed and some other things listed which my aging eyes could not make out in the picture. Now, turn it over and figure out how to do a point-to-point using the square grid in the bottom third of the slide on that side.... Drift and heading stuff using the back side of the disk is too easy. Typical driver today probably never even gets one of those issued. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Palace Cobra" www.thunderchief.org |
Ed Rasimus wrote: Typical driver today probably never even gets one of those issued. Yah. My first thought was that he'd found this one in the attic and couldn't find the directions for it. I use mine to calculate TAS once in a while. Sometimes I yank the slide out because it's got mileage scales on the edges. That's about it. -- -Ed Falk, http://thespamdiaries.blogspot.com/ |
| Thread Tools | |
| Display Modes | |
| density altitude calculator and wind calculator on web site and asGoogle gadget | Howie | Piloting | 3 | August 6th 07 12:52 AM |
| density altitude calculator and wind calculator on web site and asGoogle gadget | virtuPIC[_2_] | General Aviation | 0 | August 4th 07 06:55 PM |
| Sporty's E6B density altitude disparity | Dallas | Piloting | 30 | May 1st 07 11:31 PM |
| Student needs assistance density altitude calcs | hellothere.adelphia.net | Rotorcraft | 4 | August 19th 04 08:25 AM |
| Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 11:48 AM |
