Twin Astir water ballast tanks
Old May 24th 08, 01:44 AM posted to rec.aviation.soaring
Nick Kennedy
Default Twin Astir water ballast tanks
Does anyone out there know how to get the water ballast tanks caps off/open
to fill? They have a 1/8 inch hole in them to spin the around, but several
us have tried to get them off/open but no luck..
TIA
Nick Kennedy
Old May 27th 08, 10:08 PM posted to rec.aviation.soaring
to fill? *They have a 1/8 inch hole in them to spin the around, but several
TIA
Nick Kennedy
If they will turn, they should be able to be lifted out. The only
thing holding it in is a nylon 'cage' below the cap, that should flex
inward to allow removing the cap. It requires a stud to fit the hole
without much slop. Be careful because the 'cap' is somewhat fragile.
Old May 27th 08, 10:51 PM posted to rec.aviation.soaring
Bill Daniels
off/open
TIA
Nick Kennedy
If it's like S-H gliders, the 1/8" hole is really a threadded hole into
which a tool (or metric bolt) can be threadded to form a handle with which
to pull the cap out of the hole. The cap is likely to be just disk of ~1/8"
(3mm) thick plexiglas which can be replaced easily.
BTW, what are you guys in Telluride up to?
Bill D
Old May 27th 08, 11:36 PM posted to rec.aviation.soaring
toad
TIA
Nick Kennedy
If it's the same cap as a single Astir, which I have.
I use a L shaped piece of coat hanger wire to lift the cap out. I
then tape the plug down, making sure that the hole is not covered.
If it's the same system as the G102, then there is no valve in the
wing and there is a pipe in the wing that fits into the fuselage (with
a Volkswagen shaft seal) and a dump valve in the fuselage. This
means that the water will cross fill between wings and you have to
keep them level before launch.
Todd Smith
Antifreeze that is safe with integral water ballast tanks Tim Taylor Soaring 7 October 14th 07 05:15 AM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
astir cs-77 water ballast pete83 Soaring 4 May 27th 04 05:21 AM
