Power LEDs
Old May 29th 08, 08:18 PM posted to rec.aviation.homebuilt
Default Power LEDs
JIm Weir,
I noted your article in the current issue of KP on LEDs.
I have purchased a small quanity of these. hard to find as they were
recalled - lens were coming off in production. 160 lm @ 1000ma
http://lumileds.com/pdfs/DS60.pdf
My plans are to create a Rudder TE light bar and strobe them.
Currently on the shelf with another project ahead of it.
Jim Heffelfinger
Sacramento
Old June 2nd 08, 04:06 PM posted to rec.aviation.homebuilt
RST Engineering
Default Power LEDs
Much better, more light for the same current, LedEngin from Mouser. Less
expensive and the packaging is far superior. Coming up September issue, as
I recall.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
JIm Weir,
Jim Heffelfinger
Sacramento
Old June 2nd 08, 06:26 PM posted to rec.aviation.homebuilt
Default Power LEDs
Jim,
I flew a Bonanza G-36 that the new owner had spent bazillions on. A
truly elegant
feature it had was some sort of strip of blue white LEDs under the
edge of the glare shield.
Overall effect was like the old 727s that had some flourescent lamp
under there.
So of course, I was wondering where one could find a few feet of
something similar
without paying what Beech paid for it!!
LEDs are the obvious solution for this one.
BIll Hale
On Jun 2, 9:06*am, "RST Engineering" wrote:
Much better, more light for the same current, LedEngin from Mouser. *Less
expensive and the packaging is far superior. *Coming up September issue, as
I recall.
* * * * --Aristotle
JIm Weir,
I have purchased a small quanity of these. *hard to find as they were
recalled *- lens were coming off in production. *160 lm @ 1000ma
Jim Heffelfinger
Sacramento- Hide quoted text -
- Show quoted text -
Old June 2nd 08, 08:39 PM posted to rec.aviation.homebuilt
RST Engineering
Default Power LEDs
Works and looks excellent.
Cheap.
Easy to get or build.
Pick any two. {;-)
--Aristotle
" wrote in message
Jim,
truly elegant
under there.
something similar
BIll Hale
I recall.
--Aristotle
JIm Weir,
Jim Heffelfinger
Old June 3rd 08, 01:47 AM posted to rec.aviation.homebuilt
Mike Isaksen
Default Power LEDs
" wrote ...
...it had some sort of strip of blue white LEDs under
the edge of the glare shield.
feet of something similar without paying what Beech paid for it!!
About ten years back I saw a vendor at the shows who sold those strips. Not
cheap! Can't remember the name, but they also made custom cutout panel
covers IIRC.
Also, try a google for "electroluminescent strip", should find something in
the electrical hobbie arena.
Or, look about halfway down this link page for EL Products:
http://www.dansdata.com/glowthings.htm
Tangent:
They (linking further to the chinese vendor), these guys make luminescent
dial faces! How COOL would that make your panel look???
Old June 3rd 08, 02:07 AM posted to rec.aviation.homebuilt
Jay Maynard
Default Power LEDs
On 2008-06-03, Mike Isaksen wrote:
" wrote ...
covers IIRC.
Different stuff. EL wire/strips aren't LEDs; they use an inverter to produce
a signal of about 100 volts at a couple of kilohertz to drive the EL
portion. I'd be a little nervous about putting that in an aircraft: seems
like a good way to generate lots of RF hash.
EL wire is also a royal pain to work with. I should know: that's the glowing
stuff on the TRON costume.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 10 June)
Old June 3rd 08, 02:20 AM posted to rec.aviation.homebuilt
Mike Isaksen
Default Power LEDs
"Jay Maynard" wrote ...
seems like a good way to generate lots of RF hash.
Yeah, I was wondering about that when I saw the $7 12vdc inverter.
But the 1 inch by 12 inch strips are cheap enough to try:
http://www.glowhut.com/el-strip--el-panel.html
And here's a homebuilder's site that came up:
http://www.aircraftextras.com/EL-Panel1.htm
from a google "electroluminescent strip airplane".
that's the glowing stuff on the TRON costume.
I yield to a Master when I see one! ;-)
Hey where are you at in the countdown?
Old June 2nd 08, 10:27 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Power LEDs
"RST Engineering" wrote in message
m...
as I recall
Wow, they have some monster LED's!
I didn't see how they deal with getting rid of the heat produced, by say, a
15 watt emitter. It would be a pretty large issue, I'm sure.
Old June 2nd 08, 11:59 PM posted to rec.aviation.homebuilt
RST Engineering
Default Power LEDs
It's really pretty easy. One version of the device has the LED bonded to a
PC board and through the PC board to an aluminum puck about a quarter inch
in diameter which (and this is the trick) is electrically INSULATED from the
diode. Since you generally are going to mount this sucker on the last rib,
or another hunk of aluminum out in the wingtip, all you do is bolt the
diode/pc board/puck assembly to the aluminum with a very thin layer of
thermal grease between the puck and the aluminum. I used a representative
scrap of aluminum about 30 square inches and the diode rise over ambient was
about 20°C. The allowable rise is well over 90C, so I think I just about
sunk it well enough. This was for two 5-watt diodes on the same sink.
--Aristotle
"Morgans" wrote in message
a 15 watt emitter. It would be a pretty large issue, I'm sure.
Old June 3rd 08, 12:36 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Power LEDs
m...
a PC board and through the PC board to an aluminum puck about a quarter
inch in diameter which (and this is the trick) is electrically INSULATED
from the diode. Since you generally are going to mount this sucker on the
last rib, or another hunk of aluminum out in the wingtip, all you do is
bolt the diode/pc board/puck assembly to the aluminum with a very thin
layer of thermal grease between the puck and the aluminum. I used a
representative scrap of aluminum about 30 square inches and the diode rise
over ambient was about 20°C. The allowable rise is well over 90C, so I
think I just about sunk it well enough. This was for two 5-watt diodes on
the same sink.
Cool! Well, cool enough, anyway! g
I figured there must be a requirement to have it bonded to some external
heat sink, or something that will help get rid of the heat. In a wood
airplane, it would require a bit of added metal, I suppose.
Thanks.
KX-155 LEDs Steven Barnes Owning 21 July 11th 13 09:04 AM
LEDs Hilton Piloting 15 August 21st 07 04:36 AM
Nav Lights using Luxeon LEDs Andrew Sarangan Home Built 28 March 7th 06 09:18 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
LEDs Morgans Home Built 6 August 19th 03 03:49 AM
