What Radio Should I Pick????
Old May 30th 08, 06:45 AM posted to rec.aviation.owning
Charles Talleyrand
Default What Radio Should I Pick????
I have a KX-170 that's *sometimes* just not working right in my VFR
Cessna 150.
For the same price (about $1,300) I could get either
A McCoy MAC-1700 as a slide in replacement for the 170b
-or-
An Icom 200 as an additional radio (with the flaky KX170b as backup).
Any recommendations?
-Charles Talleyrand
P.S. I did look into www.kx170.com. But he does not give yellow tags
with his repair and chooses not to be certified, so I don't think I
can go that way.
Old May 30th 08, 11:54 AM posted to rec.aviation.owning
Stealth Pilot[_2_]
On Thu, 29 May 2008 22:45:53 -0700 (PDT), Charles Talleyrand
Cessna 150.
-or-
-Charles Talleyrand
can go that way.
The Icom A200 would be the gold standard in radios.
beautiful little things.
I rely on one all the time.
Stealth Pilot
Old May 30th 08, 02:31 PM posted to rec.aviation.owning
Gig 601Xl Builder
Cessna 150.
-or-
-Charles Talleyrand
can go that way.
I don't know a thing about the McCoy but I've been studying up on the
Icom line as I make the decision as to what I will put into my plane.
At first I was 100% decided on the Garmin SL40 mainly because of it's
ability to monitor the standby freq. That was until the A210 came out.
In a side by side comparison of the SL40 and the A210 the A210 whips the
SL40 in almost every way and cost about $300 less.
Old May 30th 08, 02:45 PM posted to rec.aviation.owning
Jay Honeck[_2_]
-or-
Third option: MX-170B. We've used this radio in two planes, and love it.
It's a "slide-out/slide-in" affair. No muss, no fuss. (Assuming your
wiring isn't the issue!)
Here's one for $1295: http://www.bennettavionics.com/mx170b.html
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 30th 08, 05:59 PM posted to rec.aviation.owning
Robert M. Gary
*-or-
Third option: MX-170B. * We've used this radio in two planes, and love it.
Old May 31st 08, 01:41 PM posted to rec.aviation.owning
*-or-
It's a "slide-out/slide-in" affair. *No muss, no fuss. *(Assuming your
I agree. I replaced my backup radio with an MX-170B and love it.
HOWEVER, most B's are no longer supported. If you call for support
they will just offer you the C. I'm ****ed off that they will not
support the B radio anymore but I do enjoy the product.
-Robert
Robert, contact Tom at Bevan Rabell (Google it) he still works on
"all" the MX series radio. There is no difference in a MX170B and C.
The straight MX170 (as you know) is a different animal.
Old May 30th 08, 02:56 PM posted to rec.aviation.owning
Jay Maynard
-or-
I own a bunch of Icom ham radios. (Eight, to be precise.) I also have an
IC-A24. Icom makes fine gear that's never given me a moment of trouble, and
I wouldn't hesitate to get one. (The only reason N55ZC has an SL40 instead
of an IC-A210 as COM2 is because the rest of the stack is Garmin, and I
wanted a sole source solution.)
OTOH, have you considered installation costs? The MAC-1700 (or the MX-170B)
will cost you less to install, just because they *are* slide-in
replacements; the IC-A200 will require some rewiring and a new tray. That
may tip the balance.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 10 June)
Old May 30th 08, 06:17 PM posted to rec.aviation.owning
Charles Talleyrand
On May 30, 9:56 am, Jay Maynard
-or-
I have considered this. The Icom price includes installation.
-Charles Talleyrand
Old May 30th 08, 06:44 PM posted to rec.aviation.owning
Jay Maynard
If that's an installed price, grab it. You'll be very pleased.
Old May 30th 08, 07:11 PM posted to rec.aviation.owning
Ronnie
Charles,
I have a pair of KX-170Bs in my 172. When I had an issue with
the NAV receiver in one of the units, I just bought a used KX-175B
via EBay for about $300 and slid it in. Problem solved. No wiring
or mounting changes required. With all the upgrades to Garmins, it
is easy to find good working KX-170B or KX-175B radios for not
a lot of money. You can find a working replacement for less than the
shop cost to troubleshoot and repair one.
Before you take that route, make sure the problem is in the radio
and not in the installation. I once had a Escort 110 which some-
times works and sometimes didn't. I initially thought the problem
was the radio, but it turned out to be a broken connection in the
antenna balun. Find a known good KX-170B loaner that you can
side into your panel and check the installtion.
I also have an ICOM A200 in my Aztec. The only issue I've ever had
was the need to have the LCD replaced recently. The A200 has given
good service except for one, very strange phenomenon which has cropped
up within the last year. Austin approach changed their east side frequency
from 118.8 to 127.22 a while back. Ever since, I've been unable to make
them hear me when using the Icom. I can hear them fine on the Icom, but
they can't hear me. The KX-155 in the same panel works in both transmit
and receive. When I sent the Icom in for the LCD replacement, the work
order indicated it was slightly off frequency and had been adjusted. I
thought
that would explaing the issue and fix it. It did not. I still have that
problem.
The Icom works fine everywhere else, but not east of KGTU trying to talk to
AUS on 127.22. I'm not saying it is the radio itself, but an odd
combination of
antenna placement and direction of travel and maybe a slight frequency
offset.
"Charles Talleyrand" wrote in message
Cessna 150.
-or-
-Charles Talleyrand
can go that way.
pick your poison on tow [email protected] Soaring 8 April 1st 06 07:42 AM
Chuck Slusarczyk please pick up the white courtesy phone... Richard Lamb Home Built 8 February 13th 06 12:58 PM
Where to pick up passengers at HPN? Roberto Waltman Piloting 8 August 22nd 04 05:52 PM
Thanks for your opinions - Going to pick up plane tomorrow!! Larryskydives Owning 0 February 13th 04 04:44 AM
Air Force asking some NCOs to pick new fields Otis Willie Military Aviation 0 January 27th 04 12:57 AM
