BFR?
Old June 9th 08, 07:07 PM posted to rec.aviation.soaring
Scott[_7_]
Default BFR?
Here's a question. I'm a private pilot, ASEL. If I get my glider
rating, will I have to do a separate BFR for each (powered and glider)?
If not, is would it just be a matter of currency (3 takeoffs and
landing within past 90 days if I want to take passengers)?
Scott
Old June 9th 08, 07:50 PM posted to rec.aviation.soaring
Default BFR?
Scott,
I'm not a CFI; however, I believe the answer to the first question is "no"
and the second question is "yes."
"Scott" wrote in message
Here's a question. I'm a private pilot, ASEL. If I get my glider rating,
will I have to do a separate BFR for each (powered and glider)? If not, is
would it just be a matter of currency (3 takeoffs and landing within past
Scott
Old June 9th 08, 08:04 PM posted to rec.aviation.soaring
sisu1a
Default BFR?
On Jun 9, 11:50 am, "Wayne Paul" wrote:
Scott,
Scott
Getting your glider add on COUNTS as a BFR though of course...
Paul
Old June 9th 08, 10:37 PM posted to rec.aviation.soaring
Scott[_7_]
Default BFR?
Scott,
Scott
Paul
Yes, that's good for the first time, but what about subsequent BFRs?
Scott
Old June 9th 08, 11:01 PM posted to rec.aviation.soaring
Vaughn Simon
Default BFR?
Yes, you cn take all of your future BFR's in the Category, Class or Type
aircraft of your choice. "One size fits all".
That said, I worked in a commercial glider operation for a few years and I
can tell you that we actively discouraged giving BFRs to any power pilots who
were not also frequent glider pilots, particularly those who expressed a desire
to take a glider BFR because it was "easier".
Vaughn
cfinn
Default BFR?
Subsequent flight reviews may be done in any aircraft that you are
qualified for, however the practical requirements are different. For a
glider you may substitute three flights in lieu of the one hour
requirement. There is also a requirement for one hour of ground
instruction. The review must be given by a CFI, DPE, or FAA inspector.
Here's a short blurb that describes the requirements:
Requirements Of FAR §61.56
FAR §61.56(a) states that a flight review consists of a minimum of one
hour of flight training and one hour of ground training. However,
glider pilots may substitute a minimum of three instructional flights
in a glider, each of which includes a flight to traffic pattern
altitude, in lieu of the one hour of flight training.
The training must include a review of the current general operating
and flight rules of FAR Part 91 and a review of those maneuvers and
procedures that are necessary for the pilot to demonstrate the safe
exercise of the privileges of the pilot certificate. The authorized
instructor giving the flight review has the discretion to determine
exactly what maneuvers and procedures are included in the flight
review.
FAR §61.56(c) goes on to say that the flight review must have been
accomplished within the twenty-four calendar months preceding the
month in which a pilot acts as pilot in command in an aircraft for
which that pilot is rated. The authorized instructor must also endorse
the pilot's logbook certifying that the pilot has satisfactorily
completed the flight review. A pilot's demonstration of competency in
any aircraft satisfies the requirements for all other categories or
classes of aircraft for which the pilot is rated.
If a pilot performing a flight review with an authorized instructor is
denied a satisfactory endorsement for flight review, the pilot may
continue to exercise certificate privileges provided the twenty-four
month period has not elapsed since the last flight review. However, if
a pilot performs a flight review with an FAA inspector and does not
receive a satisfactory endorsement, the pilot would not be able to
exercise the certificate privileges until successfully completing a re-
examination practical test under 49 USC 44709 (the "709 re-
examination" formerly called the "609 re-examination").
Old June 9th 08, 08:11 PM posted to rec.aviation.soaring
Todd
Default BFR?
I am a CFI. The definitive answer is that a Flight Review
(14CFR61.56) is not tied to Category, Class or Type so do it once
every 24 months (in an aircraft...note rule does not require a rating
in the category or class) and you are set to go in anything you fly.
Flight Currency (14CFR61.57) is another matter. 3 takeoffs and
landings within past 90 in Category, Class and Type is required to
carry passengers.
On-line FAR's available he
http://www.access.gpo.gov/cgi-bin/cf...i?title=200547
Old June 9th 08, 08:13 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
Default BFR?
Any BFR covers the requirement for any class or category in which you have
a license. Currency requirements apply.
Scott
Old June 10th 08, 05:27 AM posted to rec.aviation.soaring
BT
Default BFR?
Completing the Glider additional rating with a checkride from either the FAA
or an FAA Rep, (DPE) will count as a Flight Review and covers all ratings
you may have.
Subsequent Flight Reviews may be completed in any aircraft you are qualified
for and it's good for all aircraft. Most instructors (and FSDO) suggest that
the Flight Review be completed in the most complex aircraft you fly. But
there is no legal requirement to do so.
90 day currency for carry of passengers, must be completed in "category and
class", so 3 landings in the last 90 days in ASEL and 1 landing in the last
90 days in gliders.. you can carry pax in the airplane but not the glider..
you need two more glider flights to carry pax in gliders.
BT
Scott
Old June 10th 08, 03:37 PM posted to rec.aviation.soaring
jb92563
Default BFR?
Here is another spin on the BFR question:
If I get a Self Launch endorsement in my log book for my glider
rating, is that
considered a flight review for the purposes of the BFR requirements?
In other words can I substitute a Self Launch Endorsement for a
regular BFR?
Ray
