DG-505 cracked canopy repair
Old June 11th 08, 04:10 AM posted to rec.aviation.soaring
haven
Default DG-505 cracked canopy repair
Any suggestions for the repair of a 10-inch crack emanating from the
aft frame member top-center along with a 4-inch crack 3 inches below
and 3 1-inch cracks spaced 1 inch apart further down?
Does anyone have a repair manual with instructions?
thanks, Haven
Old June 11th 08, 05:37 AM posted to rec.aviation.soaring
Craig[_2_]
thanks, Haven
Just search this group for "canopy repair". Lots of threads and
suggestions.
Craig
Old June 11th 08, 01:28 PM posted to rec.aviation.soaring
JJ Sinclair
I never had much luck repairing cracks, but you can stop the
progression with a red-hot piece of wire shoved in just ahead of where
the crack stops. I have used a straightened out paper clip held with
vice-grips and heated to red-hot with a cigarette lighter, then shove
it right through the plexiglass about 2mm ahead of where the crack
stops. This method sears over (melts) the plastic and does a good job
of preventing crack creep. Canopy repairs are legal as long as the
crack isn't in the pilots view when landing.
JJ
thanks, Haven
Just search this group for "canopy repair". *Lots of threads and
suggestions.
Craig
Old June 12th 08, 03:24 PM posted to rec.aviation.soaring
jb92563
thanks, Haven
I read a great article in an EAA magazine on how a guy fixed a B-17
top gunners turret bubble canopy that was extensively cracked and had
missing pieces using
a product called Plastifix.
This stuff looks like just what you need as fixing a crack should be a
breeze and produce excelent results, plus it is not expensive as a
bonus.
Check out this link: http://www.urethanesupply.com/step3f.php
Ray
Canopy repair products [email protected] Soaring 3 December 30th 06 02:46 PM
Cracked ribs Jack Allison Piloting 17 April 1st 06 09:14 AM
Cracked ribs Jack Allison Owning 6 April 1st 06 09:14 AM
Cirrus canopy frame repair Louw Pieters Soaring 0 May 29th 04 06:09 AM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
