Winter Vario # 5493
Old June 15th 08, 03:09 AM posted to rec.aviation.soaring
Default Winter Vario # 5493
Anyone know what size flask is requied with this unit. I have one and
can not find specs on Winter's web site. Also, is the flask size
critical to the accuracy of the unit? Instrument is 57mm and +/- 10
knots. S Nr. 05493. Instrument was purchased by me second hand.
Old June 15th 08, 04:47 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Jun 14, 9:09*pm, wrote:
Anyone know what size flask is requied with this unit. *I have one and
can not find specs on Winter's web site. *Also, is the flask size
critical to the accuracy of the unit? *Instrument is 57mm and +/- 10
knots. *S Nr. 05493. *Instrument was purchased by me second hand.
Look to Wings and Wheels. If it is a linear scale, normal response
rate vario, it need a .45 liter flask. If it is logarithmic or fast
response, it will take a .90 liter or 1.8 liter flask. The model
number and the look of the face of the instrument will tell you what
you have got. It may also have the flask size requirement printed on
the back of the vario.
My guess is you have a standard repsonse rate, linear vario. .45
liter flask. If you use a flask that is too small, the vario will
show less vertical than what you are doing. If you use too large a
flask, it will say you are doing more than you really are. So, yes.
Flask size does matter! :-)
Hope this helps!
Steve Leonard
Wichita, KS
Old June 15th 08, 05:11 AM posted to rec.aviation.soaring
Paul Remde
Hi,
According to the data on my web site, there is no such thing as a 5493.
http://www.cumulus-soaring.com/winter/varios.htm
But my web site was created using a recent catalog which may not have been
100% complete.
Yes, the flask size is critical.
Is there a model number on the unit. That may help nail down whether it is
a standard, or sensitive, or logarithmic unit.
Paul Remde
Old June 15th 08, 05:18 AM posted to rec.aviation.soaring
Paul Remde
Hi,
Also, the Winter web site does not list that model number.
http://www.winter-instruments.de/eng...belle_mit.html
Neither does their catalog.
http://www.winter-instruments.de/dat...nstruments.pdf
It must be an out of production model number, or an incorrectly written down
number.
Paul Remde
"Paul Remde" wrote in message
news:sD05k.208986$yE1.157376@attbi_s21...
Hi,
100% complete.
is a standard, or sensitive, or logarithmic unit.
Paul Remde
Old June 15th 08, 01:38 PM posted to rec.aviation.soaring
On Jun 15, 12:18*am, "Paul Remde" wrote:
Hi,
Also, the Winter web site does not list that model number.http://www.winter-instruments.de/eng...meter/v_tabell...
Neither does their catalog.http://www.winter-instruments.de/dat...nstruments.pdf
number.
Paul Remde
Hi,
100% complete.
Is there a model number on the unit. *That may help nail down whether it
Paul Remde
knots. *S Nr. 05493. *Instrument was purchased by me second hand.- Hide quoted text -
- Show quoted text -
Thanks for the responses. The number is 05493 and is printed on the
face of the unit. This must be an out of production unit. It says
1,8 Ltr on the back which I suppose means 1.8 liter. I was hoping it
took less. Looking at Winter's cataloge it seems the 1.8 liter units
are not the most common. That is quite a bit of capacity for such a
small instrument (57mm)! This vario looks just like a 05483. Maybe
the company will get back to me on Monday as to just exactly what the
specs are on this unit.
Old June 15th 08, 02:11 PM posted to rec.aviation.soaring
Tim Mara
you're listing the Ser# of the vario, not the model #
MOST will use .45L (roughly pint size)
if it is standard linear scale it will be the .45L, other types Logarithmic
and fast rate vario's may use .9L and even a few 1.8L capacities.
the actual part # will be 5StV ______
see my website http://www.wingsandwheels.com/page19.htm with a link to
Winter Catalog http://www.winter-instruments.de/
look under products for Table variometers incl. easa Form One
best regards
Tim Mara
Please visit the Wings & Wheels website at www.wingsandwheels.com
Looking for used SN-10 and Winter Vario Pov Soaring 0 October 8th 06 07:38 PM
Resetting Winter Vario to Zero? ContestID67 Soaring 16 April 4th 06 02:44 PM
Winter Vario [email protected] Soaring 2 August 17th 05 08:24 AM
Winter vario repair in the UK Ian Johnston Soaring 3 July 8th 05 09:21 AM
[For Sale] Winter Vario Ludovic Launer Soaring 0 March 21st 05 08:40 AM
