Aeronca 11AC Chief Project FS
Old June 20th 08, 07:50 AM posted to rec.aviation.marketplace,rec.aviation.homebuilt
Victor Bravo
Default Aeronca 11AC Chief Project FS
Aeronca 11AC Chief groundloop project just received. Have flying
Taylorcraft so this is surplus to my needs. Groundlooped, but welding
is 90+% done already. Fabric removed. Needs engine, struts, possibly
spars. Some paperwork is there, but it is pretty light. Have good bill
of sale, no ownership chain problems. Airplane has the large vertical
fin, possible to convert up to 100 or 115HP. Was flying a couple of
years ago, stored indoors in dry AZ heat. LSA compliant. Asking $6000
OBO. Contact me at 818-701-6801. Los Angeles area.
Bill Berle
Old June 21st 08, 04:59 PM posted to rec.aviation.marketplace,rec.aviation.homebuilt
RST Engineering
Wow, there's a hell of a deal. "Welding done" implies that the fuselage was
severely tweaked, and busted up so bad it needs an engine, struts and
"possibly" spars. Not a hell of a lot of paperwork. Sounds like it was
"groundlooped" into a bridge abutment.
I'll bet you've got 'em standing in line for this one, eh Berle?
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
"Victor Bravo" wrote in message
Bill Berle
Old June 22nd 08, 10:10 PM posted to rec.aviation.marketplace,rec.aviation.homebuilt
Victor Bravo
You really are a putz, Mr. Weir.
The airplane was groundlooped without any bridge abutments nearby.
Most any groundloop will do some damage to a steel tube fuselage. If
you had been around old airplanes to any degree you would already know
that. You'd also know that the damage from a groundloop RANGES from
"severely tweaked" to just a few tubes bent around the gear mounting.
This one's not severley tweaked.
The struts were bent. One or two may be usable, I'll see when I get
them. I figured that I would just position it as needing struts to be
conservative. An idiot or a dishonest person would not mention bent
struts in a for sale listing, and an honest person would mention it.
The engine was removed for use on another airplane.You do know that
engines get removed and reinstalled occasionally, don't you?
The spars are probably save-able but will need some repairs. An honest
person reports this. You know, minor spar damage happens when you drag
a wingtip in a groundloop.
If you had been around old airplanes for a while, you know that the
majority of them have less then perfect paperwork. An honest guy
reports this up front. There is an airworthiness certificate, a clean
bill of sale, and some paperwork, but not all logs and papers.
As far as a hell of a deal, if you didn't already know it the 11AC
Chief meets the LAS rules at the same time as being a classic, at the
same time as being a certified aircraft, at the same time as being a
very economical aircraft to operate. The new cookie-cutter plastic
LSA's go for $80K to 150K. A good rebuilt Chief goes for $25-30K, uses
LESS fuel and has LESS engine troubles than the Rotax powered euro
LSA's.
At anything less than six or seven thousand, for a fairly easy to fix
one, the Chief is a very reasonably priced project.
Have a look at the Zenair 601XL, where an airframe KIT costs you $20K.
Now look at the unfortunate and tragic problems the 601 is having with
the wings folding in flight, and compare it to an airplane with a 60
year safety record, full commercial FAA certification, and tell me
that this is not a reasonable bargain.
Before I insulted any of your statements or products for sale with
regard to aviation electronics, I'd have made sure I had my facts
straight.
If you want to challenge me to a duel with words, I think you'd better
bring some more class, brains, and aviation experience to the game.
This is not a debate about Ohm's Law, you might be out of your depth.
Bill Berle
Old June 22nd 08, 10:38 PM posted to rec.aviation.marketplace,rec.aviation.homebuilt
cavelamb himself[_4_]
No need to get huffy, Bill.
A while back we got a nice Chief with a questionable engine for just
over $10k.
No airframe damage - the airplane was flyable - and indeed I flew it
from Florida to Texas.
$8k for a bent airframe and questionable wings? No engine?
Sounds like, like it or not, a basket case.
For 6K?
I'd have to agree with Jim on this one...
Richard
Old June 22nd 08, 10:41 PM posted to rec.aviation.marketplace,rec.aviation.homebuilt
RST Engineering
Perhaps so. I failed to include the whole sig.
A&P, IA
2500 hours in taildraggers without a groundloop.
45 years in the airplane fixin' business.
Bill Berle
Old June 23rd 08, 12:22 AM posted to rec.aviation.marketplace,rec.aviation.homebuilt
A&P, IA
Show off!
In 450 taildragger hours I have exactly one ground loop.
And in an 11AC at that.
Sanded through the skin under the wing tip bow.
A little duct tape and flew it home.
Like they say, there's them that has,
and them that's gonna...
Richard
Old June 23rd 08, 12:33 AM posted to rec.aviation.marketplace,rec.aviation.homebuilt
Jim Logajan
A&P, IA
Hmmm, none of that explains your initial post. I think you need to add this
to your sig:
ESP that gives you the ability to provide the history of an aircraft that
was described in a single paragraph.
I'd be interested in knowing the quality of the welds - and which bridge
the aircraft ran into. ;-)
(Okay, the above is not particularly diplomatic, but I think you over-
reached and could have done a better job diplomacy-wise yourself and still
managed to raise legit condition issues. It isn't like the Usenet aviation
groups are currently overflowing on the decency/diplomacy front so much so
that a bit of snideness is needed to balance it.)
Old June 23rd 08, 01:39 AM posted to rec.aviation.marketplace,rec.aviation.homebuilt
RST Engineering
Jim ...
In the first place, this thread belongs in rec.aviation.marketplace. It is
NOT a homebuilt and it is off-topic. I didn't say anything about that.
In the second place, this fellow has a history of abusing this newsgroup
trying to peddle sows' ears at silk purse prices. An 11AC with a possible
busted spar isn't a bargain at giveaway prices, much less the asking price.
So, we have to come up with an engine, some more welding (or re-welding,
depending as you say on the quality, and a question in the back of my mind
as to how the "90% complete" number came to be and why the last 10% hasn't
been done), either a lot of woodwork or a hell of a lot of woodwork
depending, struts, and a complete fabric cover. Plus a lot of bits and
pieces to hold it all together. Would'ja say, roughly, $15k in work?
That's my best estimate, figuring that the spar is a 50-50 proposition.
Somewhere between $12 and $18?
--Aristotle
"Jim Logajan" wrote in message
this
to your sig:
Old June 23rd 08, 03:30 AM posted to rec.aviation.marketplace,rec.aviation.homebuilt
Sallie
On Sun, 22 Jun 2008 14:41:03 -0700, "RST Engineering"
A&P, IA
Oh, that makes a difference!
Bill Berle
Old June 23rd 08, 11:50 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
A&P, IA
2500 hours without a groundloop....
hmmmm no experience in bent aeroplanes.
pity that :-)
me?
400 hours in a Tailwind. no experience with forced landings, no
experience with groundloops, dreadfull really. :-)
45 years in the airplane fixing business....
what havent you got that project fixed yet :-)
Stealth ( its in the statistics) Pilot
Aeronca Chief Gear Alignment? Richard Lamb Restoration 1 July 8th 03 06:04 PM
