Hangarbabe - 1 attachment (1/2)
Old June 27th 08, 07:17 PM posted to alt.binaries.pictures.aviation
Peter Hucker[_2_]
Default Hangarbabe - 1 attachment (1/2)
Works ok here. Stop using freebie Windows software.
On Fri, 27 Jun 2008 10:34:15 -0400, "Bill McAllister"
If only we could see it
"werner" wrote in message
76.253...
http://www.petersparrots.com http://www.insanevideoclips.com http://www.petersphotos.com
The pretty secretary wasn't saying much on the phone, just sitting there listening and smiling sweetly.
Finally, she hung up the phone and said to the girl at the next desk,
"That was my boyfriend. His boss must have walked in.
He said he wanted to thank me for 'giving his firm a shot at my prime location.'"
Old June 27th 08, 07:31 PM posted to alt.binaries.pictures.aviation
Ron
"Peter Hucker" wrote in message
It's not the freebie. The Freebie works just fine. It's the user, who
doesn't know how to combine multi-part messages in OE.
Ron
Non urinat in ventum
Old July 1st 08, 07:50 PM posted to alt.binaries.pictures.aviation
Peter Hucker[_2_]
Combine? I can't rememebr when I last had to do that. Do you start
your car by manual crank too?
The A-Z of tools:
a. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying....
b. WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere across the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say "Ouch".
c. ELECTRIC HAND DRILL: Normally used for spinning steel pop rivets in their holes until you die of old age....
d. PLIERS: Used to round off bolt heads....
e. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes....
f. VICE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand....
g. OXY-ACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of....
h. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 inch socket you've been searching for for the last 15 minutes....
i. HYDRAULIC FLOOR JACK: Used for lowering a car to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender....
j. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack....
k. TWEEZERS: A tool for removing wood splinters....
l. PHONE: Tool for calling your neighbour to see if he has another hydraulic floor jack....
m. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-do off your boot....
n. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit....
o. TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup....
p. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect....
q. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle....
r. BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulphuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought....
s. AVIATION METAL SNIPS: See hacksaw....
t. TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under motorcycles at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading....
u. PHILIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads...
v. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact
wrench that grips rusty bolts last tightened 40 years ago by someone in Sindelfingen, and rounds them off.
w. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed t
Old July 1st 08, 11:37 PM posted to alt.binaries.pictures.aviation
Bob Harrington
Aack! Where's the rest of w, x, y and z ?!? ={
Peter Hucker wrote in
The A-Z of tools:
of....
buildup....
thought....
Old July 2nd 08, 07:48 PM posted to alt.binaries.pictures.aviation
Peter Hucker[_2_]
Stupid tag program.
bracket you needed to remove in order to replace a 50 cent part....
x. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short....
y. HAMMER: Originally employed as a weapon of war, the hammer nowadays
is used as a kind of divining rod to locate expensive parts not far
from the object we are trying to hit....
z. MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on boxes containing seats and motorcycle jackets...
On Tue, 01 Jul 2008 22:37:34 GMT, Bob Harrington
The A-Z of tools:
of....
buildup....
thought....
There was an old priest who got sick of all the people in his parish who kept confessing to adultery.
One Sunday, in the pulpit, he said, "If I hear one more person confess to adultery, I'll quit!"
Everyone liked him, so they came up with a code word.
Someone who had committed adultery would say instead that they had "fallen."
This seemed to satisfy the old priest and things went well until the priest passed away at a ripe old age.
A few days after the new priest arrived, he visited the mayor of the town and seemed very concerned.
"Mayor, you have to do something about the sidewalks in town. When people come into the confessional, they keep telling me they've fallen."
The mayor started to laugh, realizing that no one had told the new priest about the code word.
But, before he could explain, the priest shook an accusing finger at him and shouted,
"I don't know what you're laughing about, because your wife has already fallen three times this week!"
Old July 3rd 08, 03:28 AM posted to alt.binaries.pictures.aviation
Bob Harrington
Stupid tag program.
Thank you!
Here it is all betterer:
The A-Z of tools:
of....
buildup....
thought....
Old July 2nd 08, 03:27 PM posted to alt.binaries.pictures.aviation
Ray S. & Nayda Katzaman
Peter,
My isp cut your comments here, can you provide the complete w and x, y and z.
Ray
Old July 2nd 08, 07:49 PM posted to alt.binaries.pictures.aviation
Peter Hucker[_2_]
On Wed, 02 Jul 2008 09:27:33 -0500, "Ray S. & Nayda Katzaman"
Peter,
Ray
It was a fault at my end.
Loose or missing nuts. Spank the monkey (Y/N)?
Old July 2nd 08, 10:22 PM posted to alt.binaries.pictures.aviation
Many thanks.
Ray
Old June 27th 08, 11:50 PM posted to alt.binaries.pictures.aviation
Chezelwig[_2_]
Hate to say it, but Unison on my Mac shows the file as being there, but
when I try to download it, I get a "File Not Found" message.
6.253...
Hangarbabe - 1 attachment (1/2) heavyhorses Aviation Photos 1 June 26th 08 11:14 PM
Hangarbabe - 1 attachment (2/2) werner Aviation Photos 0 June 26th 08 03:11 PM
Glory - 1 attachment Bertie the Bunyip[_24_] Aviation Photos 0 March 23rd 08 01:01 AM
AT THE T-LINE - 1 attachment Jim John Aviation Photos 0 July 7th 07 09:31 PM
Mxs goes flying! - 1 attachment Marc CYBW[_2_] Piloting 11 June 14th 07 11:15 PM
