MD-80 split elevators
Old June 29th 08, 12:40 AM posted to rec.aviation.ifr
tscottme[_2_]
Default MD-80 split elevators
Anyone know why the elevators on MD-80s, while parked or taxiing on the
ground, are almost always split? By that I mean the elevator on the left
side is up and elevator on right side of rudder is down. I don't recall
seeing thie elevators split left/down and right/up and I don't recall 737s
showing split elevators, but that may just be a faulty memory.
Scott
"while there are Muslims who are moderate, there is no moderate Islam"
http://www.jihadwatch.org
Old June 29th 08, 01:14 AM posted to rec.aviation.ifr
Robert Moore
the ground, are almost always split? By that I mean the elevator on
the left side is up and elevator on right side of rudder is down. I
don't recall seeing thie elevators split left/down and right/up and I
don't recall 737s showing split elevators, but that may just be a
faulty memory.
Speaking for B-707s, the elevators are not connected to each other and
are not even connected to the control column, they free float. They are
positioned by airflow over the control tabs which are pilot controlled.
At rest on the ground, the wind positions them, at random.
The MD-80 might be similiar.
Bob Moore
ATP B-727, B-707, L-188
Old June 29th 08, 05:13 AM posted to rec.aviation.ifr
tscottme[_2_]
Thanks Bob, I recall somethign similar about the MD-80 aero surfaces. I
believe the MD-80 uses a jackscrew to adjust the flying tail and aerodynamic
forces to trim.
I've definitely seen the trailing edge of the tail feathers swing up and
downdue to wind when the aircraft I was refeiling was parked at the gate.
Perhaps I am only remembering the left/up and right/down phenomenon and that
is reinforced by the networks' habit of reusing the same stock footage of a
line of taxiing aircraft.
Scott
"Robert Moore" wrote in message
. 15.205...
faulty memory.
Bob Moore
Old June 29th 08, 07:24 PM posted to rec.aviation.ifr
Sam Spade
forces to trim.
Jammed MD-80 jacksrews caused one bird to nose dive into the ocean off
So California.
How to split a tracklog of several flights for OLC? db Soaring 2 April 5th 07 10:36 AM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 11:43 AM
Anyone want to split room for SSA Convention Jeff Landfield Soaring 1 January 27th 04 06:05 PM
Rogue's Gallery Split 3 Ways! Jay Honeck Piloting 8 December 22nd 03 07:53 PM
Split Cycle Engine Technology Canzie Rotorcraft 1 October 24th 03 03:34 PM
