Hello,
We found this engine under the Central South Italian adriatic sea coast. We would like to know to what airplane it may belong. People from the area say B-17 flying fortress but I dont think so because from the image I see it is a 7 cylinder engine and the B-17 used the 9 cylinder, I think it belongs to a smaller airplane. What engine you think it is? To what world war II plane it may belong? I could dive again in that site, what kind of further info you may need to try to identify the engine and possible airplane type? Look at the pics he http://s288.photobucket.com/albums/l...view=slideshow Mario |
On Jun 29, 8:12*pm, Mario wrote:
Hello, We found this engine under the Central South Italian adriatic sea coast. We would like to know to what airplane it may belong. People from the area say B-17 flying fortress but I dont think so because from the image I see it is a 7 cylinder engine and the B-17 used the 9 cylinder, I think it belongs to a smaller airplane. What engine you think it is? To what world war II plane it may belong? I could dive again in that site, what kind of further info you may need to try to identify the engine and possible airplane type? Look at the pics hehttp://s288.photobucket.com/albums/l...i-motore/?albu... Mario A bit of googling suggests 7 cylinder radials were quite common. Here are a few suggestions you might want to look further into 1. The Cessna T50 was a US transport aircraft during WW2 2. The British Airspeed Oxford and Avron Anson both used 7 cylinder radials Good luck with your search. Did you not find any other parts of the aircraft? Terry PPL Downunder |
Mario wrote
I see it is a 7 cylinder engine I don't think so....to me, it looks like a twin row 14 cylinder Pratt and Whitney 1830 Twin Wasp widely used on the C-47 during WW11. Look at the number of spark plug wires at the front of the engine. The R1830 Twin Wasp The Pratt and Whitney R-1830 Twin Wasp engine was one of the most efficient and reliable engines of the 1930s. It was introduced in 1932 with either a 6.1 or 6.5 compression ratio and 775 or 825 horsepower respectively, at 2,400 rpm. To reach its designed power the R-1830 needed the highest octane gasoline available. Using improved fuel the R-1830 reached 1,000 hp and later 1,200 hp. It has 14 cylinders in two banks of seven. The R-1830 was used on B-24s, C-47s and the Grumman F4F-4 Wildcat, until it was phased out by Grumman. Pratt and Whitney built 13,464 R-1830-90C engines for the C-47 aircraft. It was also used in a variety of British aircraft including the Royal Air Force Catalinas, Short Sunderland Vs, Maryland bombers, and Bristol Beauforts Check the picture at this site... http://www.maltaaviationmuseum.com/engines.asp Bob Moore |
Robert Moore wrote in
. 15.205: Mario wrote I see it is a 7 cylinder engine I don't think so....to me, it looks like a twin row 14 cylinder Pratt and Whitney 1830 Twin Wasp widely used on the C-47 during WW11. Look at the number of spark plug wires at the front of the engine. The R1830 Twin Wasp The Pratt and Whitney R-1830 Twin Wasp engine was one of the most efficient and reliable engines of the 1930s. It was introduced in 1932 with either a 6.1 or 6.5 compression ratio and 775 or 825 horsepower respectively, at 2,400 rpm. To reach its designed power the R-1830 needed the highest octane gasoline available. Using improved fuel the R-1830 reached 1,000 hp and later 1,200 hp. It has 14 cylinders in two banks of seven. The R-1830 was used on B-24s, C-47s and the Grumman F4F-4 Wildcat, until it was phased out by Grumman. Pratt and Whitney built 13,464 R-1830-90C engines for the C-47 aircraft. It was also used in a variety of British aircraft including the Royal Air Force Catalinas, Short Sunderland Vs, Maryland bombers, and Bristol Beauforts Check the picture at this site... http://www.maltaaviationmuseum.com/engines.asp Yeah, it's an 1830 I think. the cylinder head fins sure look right for one. Looks like the magnesium geabox casing is long gone. You'll probably find the gears lying in the bottom underneath the engine. Bertie |
Engine-out procedures and eccentric forces on engine pylons | Mxsmanic | Piloting | 18 | May 26th 07 01:03 AM |
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg | [email protected] | Aviation Photos | 1 | April 11th 07 04:48 PM |
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 01:38 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
