Transmission feedback on C206 Towplane
Old June 29th 08, 04:57 PM posted to rec.aviation.soaring
Default Transmission feedback on C206 Towplane
Got a Cessna 206 that emits a steady tone during transmission only.
The pitch increases with rpm to a point where ATC refuses service. No
tone is emitted on battery power only (Alt. off). No problem
yesterday, problem today. Noise remains with audio panel on/off, using
L/R trans switch, speaker on/off, swapping headsets(Bose). Aircraft
has 95 amp alt. (belt drive), noise filter. Please email me if more
infor. is needed.
Thanks
R
Old June 29th 08, 10:01 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Sun, 29 Jun 2008 08:57:09 -0700 (PDT), "
infor. is needed.
Thanks
R
Sounds like a bad noise filter on the alternator.
rj
Old June 29th 08, 10:34 PM posted to rec.aviation.soaring
Take the alternator off and have your local alternator shop check the
"diodes" in it. They are not certified to repair it but they can sure
check it out for you. Bad diodes will cause a hum that changes in
pitch with rpm. They can also cause the alternator output to be
unstable as seen in a quivering amp meter.
Old June 30th 08, 03:30 PM posted to rec.aviation.soaring
Gary Boggs
I had a problem like this and it turned out to be a bad ground on the
ptt.
"diodes" in it. *They are not certified to repair it but they can sure
check it out for you. *Bad diodes will cause a hum that changes in
pitch with rpm. *They can also cause the alternator output to be
Micro Air transmission-garbled [email protected] Soaring 7 June 17th 07 03:50 PM
C206 rental - KS, OK, noth TX - where? grumman_driver Piloting 3 April 10th 06 06:12 PM
Subaru flywheel pto without transmission [email protected] Home Built 2 November 26th 05 08:00 AM
JPI 800 & GMA 340 into C206 in EASA countries? Jouni Laukkanen Owning 3 August 4th 05 07:30 AM
Transmission design? Otto Gyro Rotorcraft 1 November 7th 03 04:41 PM
